FC USB passthru question
Trying to use a burned up AIO FC to play DRL with the CLI USB passthrough command described on Oscar's site. Betaflight receiver tab shows its connected and working, keeping Betaflight open while I try to set up the game, using a Mac so not sure if its a driver issue but I cannot get DRL to recognize the hardware. Where am I going wrong?
https://oscarliang.com/betaflight-fc-fpv-simulator/
just to get sure;
you are using an f4/f7 flightcontroller? not an f3
you use bf 3.4 or higher?
you typed in the usb hid command? you also typed "save"...
did you reconect after bf settup? you arent connected to bf while your trys in the sim?
i never had any fc driver issue on a mac, my experience was allways plug and play....
# diff all
# Betaflight / MATEKF411 (MK41) 4.1.1 Nov 15 2019 / 12:34:58 (1e5e3d369) MSP API: 1.42
# start the command batch
batch start
defaults nosave
board_name MATEKF411
mcu_id 002b00433339511838383538
signature
feature -DYNAMIC_FILTER
map TAER1234
# master
set gyro_sync_denom = 32
set min_check = 1171
set max_check = 1828
set serialrx_provider = SPEK2048
set motor_pwm_protocol = OFF
set small_angle = 180
set deadband = 1
set pid_process_denom = 16
set usb_hid_cdc = ON
profile 1
profile 2
rateprofile 1
rateprofile 2
rateprofile 3
rateprofile 4
rateprofile 5
rateprofile 2
# save configuration
save
# status
MCU F411 Clock=96MHz (PLLP-HSE), Vref=3.29V, Core temp=47degC
Stack size: 2048, Stack address: 0x2001fff0
Config size: 3570, Max available config: 16384
GYRO=MPU6000, ACC=MPU6000
System Uptime: 94 seconds, Current Time: 2020-09-18T22:37:47.105+00:00
CPU:4%, cycle time: 4005, GYRO rate: 249, RX rate: 91, System rate: 10
Voltage: 1 * 0.01V (0S battery - NOT PRESENT)
I2C Errors: 3
Arming disable flags: CLI MSP
Betafpv f4 aio 2s, BF 4.1 legacy.
Yes to saving after HID command, then it reboots and I am running BF while trying DRL.
I thought it was the gateway to using the FC usb, but will try giving the command + save, allowing the reboot and then close BF and open DRL.
After trying, nothing changed.
.txt   BfpvF4AIO CLIdiagn.txt (Size: 1.27 KB / Downloads: 77)
  Boxer Toggle Switches Follow up to previous thread question soky157 0 132 14-Feb-2024, 03:28 AM
Last Post: soky157
  Tutorial Taranis Q X7 USB Battery Mod StoneFPV 1 1,514 18-Jan-2019, 02:53 PM
Last Post: Oscar
