Hi, I would like to ask you for help with my FC. I have been using the GOKU F745PRO (FLYWOOF745) for a long time without any problem, but I have never updated it.
Now due to upgrade to O3 Unit I had to update FC from betaflight 4.3 to the latest one. When I did so, one engine was not spinning and the others were remapped. The problem persists even though I downgraded back to 4.3.
I solved it for now by installing FLYWOOF745AIOV2 instead of the correct firmware.
So the drone flies great except for one thing, and that is that twice now FC simply stopped to work. The video, radio stopped working. The drone after unplug/plug battery works fine again. Once it dropped me like this before takeoff and once it disconnected in flight.
So I want to ask if bad firmware can be related to this sudden shutdown and if anyone has a solution to make the drone fly with the correct firmware.
Here is image of my fc and esc
I will be really glad for every advice
