Threads: 11
Likes Received: 0 in 0 posts
Likes Given: 18
0 After a crash, I lost video and then tried to connect it to the BF to see what happened and by default the FC goes to the DFU mode. When I exit the DFU mode it works fine, I have video and all is ok. But when I unplug and plug again the USB I have the same issue, it goes again to DFU mode.
Any ideas if I can fix this? or I need new FC?
Threads: 125
Likes Given: 99
388 Check your boot button to see if you have a short (permanent close circuit). Use a DMM on continuity mode to check.
Threads: 125
Likes Given: 99
388 29-Jan-2021, 09:57 PM (This post was last modified: 29-Jan-2021, 09:58 PM by voodoo614.) Try to reflash with full chip erase. Remember to backup a dump file before you reflash.
Sorry for the delay in reply. A lot of time i do not get a notification.
Threads: 125
Likes Given: 99
388 I am not sure what is the problem then.
Threads: 125
Likes Given: 99
388 Good troubleshooting if you figured it out.
