Threads: 1
Likes Received: 0 in 0 posts
0 20-Jan-2024, 09:43 PM (This post was last modified: 20-Jan-2024, 09:44 PM by voidbrain.) Hello, I have a Radiometer Zorro with ELRS 2.4 and an external module (Super G 2.4 Gemini).
When i want to connect the ext module to my radio i need to manually disable the internal ELRS.
Do you know if there is a a way (maybe a LUA script?) to automatically disable the internal TX if the ext module is connected?
It would be ok even if the check was just at the start up.
Threads: 4
Likes Received: 65 in 60 posts
Likes Given: 17
8 i (and probably most people) just use separate models for different modules. I think thats way faster than going and changing the rf settings each time.
Threads: 1
0 Thanks, this is a useful tip but still it has to be done manually.
No automation?
Threads: 72
Likes Received: 344 in 258 posts
Likes Given: 157
19 I have a X16S MAX (on 3.x currently) and Namimno Flash Module (on 2.x). Since I always set a TX model up per actual model usually copy/paste and rename, never had any issue, just select model with a couple of clicks.
More seems chasing diminishing returns for the effort!
