ELRS Binded, but no input on Betaflight
Hello!
The story:
I'm a big newbie here, and im strugling on my first build. This is a Toothpick on 3S batteries made from whatever i could find available.
I got motors with KV and size adapted, got light 3S batteries, got multiple types of propelers to test, got a VTX, got an FC, got a Frame, and got myself an RX.
I soldered everything following the indication, turns out pretty much everything works, surprisingly. Everything but the RX.
I bought the EP2 elrs RX from HappyModel, cause i'm already using my elrs TX for my tinywhoop, and it works perfectly on it.
First problem i stumble on, is the EP2 getting stuck on Bootloader mode (Preventing Binding or Flashin) each time i power the FC. Red a bit on the internet, turns out that some FC mine included turn on with the T2 (from uart 2) on Low, unintentionaly putting the EP2 on Bootloader mode. The solution offered by the fabulous people of the internet was soldering a Pull Up resistor between a 3v output and the cable linkin T2(on FC) and R(on RX).
My FC doesnt have any 3v3 output, i used instead a 5v one to solder the pull up resistor.
Then, magic: the RX turns on with the FC and I can flash it, and i can Bind it with my Taranis's NanoTx.
My problem:
So it is bind, tellemetry seems to work beaucause each time i power or unplug the fc, the radiocontroler tells me "telemetry lost" "telemetry recovered"
But on Betaflight it shows me that the FC get no input from the RX.
What i tried to solve this:
-Using an OpenTx Model on my radio that work on my other drone with all the chanel and output configurated corectly
-Checking the cable soldering      FC RX —> ELRS TX     FC TX —> ELRS RX
-powering with battery instead of just usb
-updating every elrs module to 2.5.0
-updating my FC to last update
-turning on SERIAL_RX on UART2 in Betaflight ports section.
-set the Receiver protocol to SERIAL_RX and CRSF.
asdf
- Trying serialrx_inverted On and Off
The Info on my build:
FC: Succex-D Whoop  On BTFL 4.3.0
RX: EP2 HappyModel   RX On elrs2.5.0
TX: Betafpv NanoElrs  TX On 2.5.0
Radiocontroler: Taranis X9 Lite  On 2.3.15-otx (1004ef7c)
Im letting here a Dump File and some picture of the wirring:
[Image: 8iMkLP0l.jpg]
[Image: S2laKXYl.jpg]
[Image: 5D5MtRrl.jpg]
I don't if the problem is between the TX and RX, between the RX and FC or the soldering  or even somewhere else i can't guess
I am now lost and desperate for help x)
Thank you in advance Big Grin
Vadimcherub
Dump:
# Betaflight / STM32F411 (S411) 4.3.0 Jun 14 2022 / 00:48:04 (229ac66) MSP API: 1.44
# config: manufacturer_id: IFRC, board_name: IFLIGHT_F411_PRO, version: 714fcb3f, date: 2021-12-07T06:25:44Z
# start the command batch
batch start
board_name IFLIGHT_F411_PRO
manufacturer_id IFRC
# name: -
# resources
resource BEEPER 1 B02
resource MOTOR 1 A00
resource MOTOR 2 B10
resource MOTOR 3 B06
resource MOTOR 4 B07
resource MOTOR 5 NONE
resource MOTOR 6 NONE
resource MOTOR 7 NONE
resource MOTOR 8 NONE
resource SERVO 1 NONE
resource SERVO 2 NONE
resource SERVO 3 NONE
resource SERVO 4 NONE
resource SERVO 5 NONE
resource SERVO 6 NONE
resource SERVO 7 NONE
resource SERVO 8 NONE
resource PPM 1 A03
resource PWM 1 NONE
resource PWM 2 NONE
resource PWM 3 NONE
resource PWM 4 NONE
resource PWM 5 NONE
resource PWM 6 NONE
resource PWM 7 NONE
resource PWM 8 NONE
resource LED_STRIP 1 A08
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 A02
resource SERIAL_TX 3 NONE
resource SERIAL_TX 4 NONE
resource SERIAL_TX 5 NONE
resource SERIAL_TX 6 NONE
resource SERIAL_TX 7 NONE
resource SERIAL_TX 8 NONE
resource SERIAL_TX 9 NONE
resource SERIAL_TX 10 NONE
resource SERIAL_TX 11 NONE
resource SERIAL_TX 12 NONE
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 A03
resource SERIAL_RX 3 NONE
resource SERIAL_RX 4 NONE
resource SERIAL_RX 5 NONE
resource SERIAL_RX 6 NONE
resource SERIAL_RX 7 NONE
resource SERIAL_RX 8 NONE
resource SERIAL_RX 9 NONE
resource SERIAL_RX 10 NONE
resource SERIAL_RX 11 NONE
resource SERIAL_RX 12 NONE
resource INVERTER 1 NONE
resource INVERTER 2 NONE
resource INVERTER 3 NONE
resource INVERTER 4 NONE
resource INVERTER 5 NONE
resource INVERTER 6 NONE
resource INVERTER 7 NONE
resource INVERTER 8 NONE
resource INVERTER 9 NONE
resource INVERTER 10 NONE
resource INVERTER 11 NONE
resource INVERTER 12 NONE
resource I2C_SCL 1 B08
resource I2C_SCL 2 NONE
resource I2C_SCL 3 NONE
resource I2C_SDA 1 B09
resource I2C_SDA 2 NONE
resource I2C_SDA 3 NONE
resource LED 1 C13
resource LED 2 C14
resource LED 3 NONE
resource RX_BIND 1 NONE
resource RX_BIND_PLUG 1 NONE
resource SPI_SCK 1 A05
resource SPI_SCK 2 B13
resource SPI_SCK 3 B03
resource SPI_MISO 1 A06
resource SPI_MISO 2 B14
resource SPI_MISO 3 B04
resource SPI_MOSI 1 A07
resource SPI_MOSI 2 B15
resource SPI_MOSI 3 B05
resource ESCSERIAL 1 NONE
resource ADC_BATT 1 B00
resource ADC_RSSI 1 NONE
resource ADC_CURR 1 B01
resource ADC_EXT 1 NONE
resource BARO_CS 1 NONE
resource BARO_EOC 1 NONE
resource BARO_XCLR 1 NONE
resource COMPASS_CS 1 NONE
resource COMPASS_EXTI 1 NONE
resource SDCARD_CS 1 NONE
resource SDCARD_DETECT 1 NONE
resource PINIO 1 NONE
resource PINIO 2 NONE
resource PINIO 3 NONE
resource PINIO 4 NONE
resource USB_MSC_PIN 1 NONE
resource FLASH_CS 1 A15
resource OSD_CS 1 B12
resource RX_SPI_CS 1 NONE
resource RX_SPI_EXTI 1 NONE
resource RX_SPI_BIND 1 NONE
resource RX_SPI_LED 1 NONE
resource GYRO_EXTI 1 A01
resource GYRO_EXTI 2 NONE
resource GYRO_CS 1 A04
resource GYRO_CS 2 NONE
resource USB_DETECT 1 C15
resource PULLUP 1 NONE
resource PULLUP 2 NONE
resource PULLUP 3 NONE
resource PULLUP 4 NONE
resource PULLDOWN 1 NONE
resource PULLDOWN 2 NONE
resource PULLDOWN 3 NONE
resource PULLDOWN 4 NONE
# timer
timer A03 AF3
# pin A03: TIM9 CH2 (AF3)
timer A00 AF1
# pin A00: TIM2 CH1 (AF1)
timer B10 AF1
# pin B10: TIM2 CH3 (AF1)
timer B06 AF2
# pin B06: TIM4 CH1 (AF2)
timer B07 AF2
# pin B07: TIM4 CH2 (AF2)
timer A08 AF1
# pin A08: TIM1 CH1 (AF1)
# dma
dma SPI_MOSI 1 NONE
dma SPI_MOSI 2 NONE
dma SPI_MOSI 3 NONE
dma SPI_MISO 1 NONE
dma SPI_MISO 2 NONE
dma SPI_MISO 3 NONE
dma SPI_TX 1 NONE
dma SPI_TX 2 NONE
dma SPI_TX 3 NONE
dma SPI_RX 1 NONE
dma SPI_RX 2 NONE
dma SPI_RX 3 NONE
dma ADC 1 1
dma ADC 2 NONE
dma ADC 3 NONE
dma UART_TX 1 NONE
dma UART_TX 2 NONE
dma UART_TX 3 NONE
dma UART_TX 4 NONE
dma UART_TX 5 NONE
dma UART_TX 6 NONE
dma UART_TX 7 NONE
dma UART_TX 8 NONE
dma UART_RX 1 NONE
dma UART_RX 2 NONE
dma UART_RX 3 NONE
dma UART_RX 4 NONE
dma UART_RX 5 NONE
dma UART_RX 6 NONE
dma UART_RX 7 NONE
dma UART_RX 8 NONE
dma pin A03 NONE
dma pin A00 0
# pin A00: DMA1 Stream 5 Channel 3
dma pin B10 0
dma pin B06 0
dma pin B07 0
dma pin A08 0
feature -RANGEFINDER
feature -OSD
feature -TRANSPONDER
feature -AIRMODE
feature -RX_SPI
feature -ESC_SENSOR
feature -ANTI_GRAVITY
feature RX_SERIAL
feature TELEMETRY
feature RSSI_ADC
feature OSD
feature AIRMODE
feature ANTI_GRAVITY
serial 0 8192 115200 57600 0 115200
# servo
servo 0 1000 2000 1500 100 -1
servo 1 1000 2000 1500 100 -1
servo 2 1000 2000 1500 100 -1
servo 3 1000 2000 1500 100 -1
servo 4 1000 2000 1500 100 -1
servo 5 1000 2000 1500 100 -1
servo 6 1000 2000 1500 100 -1
servo 7 1000 2000 1500 100 -1
# servo mixer
smix reset
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper ARMING_GPS_NO_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
beeper BLACKBOX_ERASE
beeper CRASH_FLIP
beeper CAM_CONNECTION_OPEN
beeper CAM_CONNECTION_CLOSE
beeper RC_SMOOTHING_INIT_FAIL
# beacon
beacon -RX_LOST
beacon -RX_SET
map AETR1234
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 0
mode_color 5 1 0
mode_color 5 2 0
mode_color 5 3 0
mode_color 5 4 0
mode_color 5 5 0
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 0 0 0 900 900 0 0
aux 1 0 0 900 900 0 0
aux 2 0 0 900 900 0 0
aux 3 0 0 900 900 0 0
aux 4 0 0 900 900 0 0
aux 5 0 0 900 900 0 0
aux 6 0 0 900 900 0 0
aux 7 0 0 900 900 0 0
aux 8 0 0 900 900 0 0
aux 9 0 0 900 900 0 0
aux 10 0 0 900 900 0 0
aux 11 0 0 900 900 0 0
aux 12 0 0 900 900 0 0
aux 13 0 0 900 900 0 0
aux 14 0 0 900 900 0 0
aux 15 0 0 900 900 0 0
aux 16 0 0 900 900 0 0
aux 17 0 0 900 900 0 0
aux 18 0 0 900 900 0 0
aux 19 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# vtxtable
vtxtable bands 0
vtxtable channels 0
vtxtable powerlevels 0
vtxtable powervalues
vtxtable powerlabels
# vtx
vtx 0 0 0 0 0 900 900
vtx 1 0 0 0 0 900 900
vtx 2 0 0 0 0 900 900
vtx 3 0 0 0 0 900 900
vtx 4 0 0 0 0 900 900
vtx 5 0 0 0 0 900 900
vtx 6 0 0 0 0 900 900
vtx 7 0 0 0 0 900 900
vtx 8 0 0 0 0 900 900
vtx 9 0 0 0 0 900 900
# rxfail
rxfail 3 a
rxfail 5 h
# master
set gyro_lpf1_type = PT1
set gyro_lpf1_static_hz = 250
set gyro_lpf2_type = PT1
set gyro_lpf2_static_hz = 500
set gyro_notch1_hz = 0
set gyro_notch1_cutoff = 0
set gyro_notch2_hz = 0
set gyro_notch2_cutoff = 0
set gyro_calib_duration = 125
set gyro_offset_yaw = 0
set yaw_spin_recovery = AUTO
set yaw_spin_threshold = 1950
set gyro_to_use = FIRST
set dyn_notch_count = 3
set dyn_notch_q = 300
set dyn_notch_min_hz = 150
set dyn_notch_max_hz = 600
set gyro_lpf1_dyn_min_hz = 250
set gyro_lpf1_dyn_expo = 5
set acc_hardware = AUTO
set acc_lpf_hz = 10
set acc_trim_pitch = 0
set acc_trim_roll = 0
set acc_calibration = -29,1,50,1
set align_mag = DEFAULT
set mag_align_roll = 0
set mag_align_pitch = 0
set mag_align_yaw = 0
set mag_bustype = SPI
set mag_i2c_device = 0
set mag_i2c_address = 0
set mag_spi_device = 0
set mag_hardware = NONE
set mag_calibration = 0,0,0
set baro_bustype = I2C
set baro_spi_device = 0
set baro_i2c_device = 1
set baro_i2c_address = 0
set baro_hardware = NONE
set baro_tab_size = 21
set baro_noise_lpf = 600
set baro_cf_vel = 985
set min_check = 1050
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 100
set rssi_offset = 0
set rssi_invert = OFF
set rc_smoothing = ON
set fpv_mix_degrees = 0
set max_aux_channels = 14
set serialrx_provider = CRSF
set serialrx_inverted = OFF
set spektrum_sat_bind = 0
set srxl2_unit_id = 1
set srxl2_baud_fast = ON
set sbus_baud_fast = OFF
set crsf_use_rx_snr = OFF
set serialrx_halfduplex = OFF
set rx_spi_bus = 0
set adc_device = 1
set blackbox_disable_rc = OFF
set blackbox_disable_mag = OFF
set blackbox_mode = NORMAL
set min_throttle = 1070
set max_throttle = 2000
set dshot_idle_value = 550
set dshot_burst = OFF
set dshot_bidir = OFF
set dshot_bitbang = OFF
set use_unsynced_pwm = OFF
set motor_pwm_rate = 480
set motor_pwm_inversion = OFF
set motor_poles = 14
set thr_corr_value = 0
set thr_corr_angle = 800
set failsafe_delay = 15
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_procedure = DROP
set align_board_yaw = 0
set gimbal_mode = NORMAL
set bat_capacity = 0
set vbat_hysteresis = 1
set current_meter = ADC
set battery_meter = ADC
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set vbat_cutoff_percent = 100
set vbat_sag_lpf_period = 2
set ibat_lpf_period = 10
set vbat_scale = 110
set vbat_divider = 10
set vbat_multiplier = 1
set ibata_scale = 400
set ibata_offset = 0
set ibatv_scale = 0
set ibatv_offset = 0
set beeper_inversion = ON
set beeper_od = OFF
set beeper_frequency = 0
set yaw_motors_reversed = OFF
set mixer_type = LEGACY
set crashflip_expo = 35
set 3d_limit_low = 1000
set 3d_limit_high = 2000
set 3d_switched_mode = OFF
set servo_center_pulse = 1500
set servo_pwm_rate = 50
set servo_lowpass_hz = 0
set tri_unarmed_servo = ON
set small_angle = 25
set gps_provider = NMEA
set gps_sbas_mode = NONE
set gps_sbas_integrity = OFF
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_ublox_mode = AIRBORNE
set gps_use_3d_speed = OFF
set gps_rescue_angle = 32
set gps_rescue_alt_buffer = 15
set gps_rescue_yaw_p = 40
set gps_rescue_min_sats = 8
set gps_rescue_min_dth = 100
set gps_rescue_use_mag = ON
set deadband = 0
set yaw_deadband = 0
set pid_process_denom = 2
set tlm_inverted = OFF
set tlm_halfduplex = ON
set frsky_default_lat = 0
set frsky_default_long = 0
set frsky_gps_format = 0
set frsky_unit = METRIC
set frsky_vfas_precision = 0
set hott_alarm_int = 5
set pid_in_tlm = OFF
set report_cell_voltage = OFF
set ledstrip_grb_rgb = GRB
set ledstrip_profile = STATUS
set ledstrip_brightness = 100
set sdcard_mode = OFF
set sdcard_spi_bus = 0
set sdio_clk_bypass = OFF
set sdio_use_cache = OFF
set sdio_use_4bit_width = OFF
set osd_units = METRIC
set osd_warn_crash_flip = ON
set osd_warn_esc_fail = ON
set osd_warn_core_temp = ON
set osd_warn_fail_safe = ON
set osd_warn_rssi = OFF
set osd_warn_rssi_dbm = OFF
set osd_warn_over_cap = OFF
set osd_rssi_alarm = 20
set osd_rssi_dbm_alarm = -60
set osd_cap_alarm = 2200
set osd_alt_alarm = 100
set osd_distance_alarm = 0
set osd_esc_temp_alarm = -128
set osd_esc_rpm_alarm = -1
set osd_core_temp_alarm = 70
set osd_ah_max_pit = 20
set osd_ah_max_rol = 40
set osd_ah_invert = OFF
set osd_logo_on_arming = OFF
set osd_tim1 = 2560
set osd_tim2 = 2561
set osd_vbat_pos = 234
set osd_rssi_pos = 234
set osd_rssi_dbm_pos = 234
set osd_tim_1_pos = 234
set osd_tim_2_pos = 234
set osd_flymode_pos = 234
set osd_g_force_pos = 234
set osd_throttle_pos = 234
set osd_vtx_channel_pos = 234
set osd_crosshairs_pos = 205
set osd_ah_sbar_pos = 206
set osd_ah_pos = 78
set osd_current_pos = 234
set osd_mah_drawn_pos = 234
set osd_motor_diag_pos = 234
set osd_craft_name_pos = 234
set osd_gps_speed_pos = 234
set osd_gps_lon_pos = 234
set osd_gps_lat_pos = 234
set osd_gps_sats_pos = 234
set osd_home_dir_pos = 234
set osd_home_dist_pos = 234
set osd_flight_dist_pos = 234
set osd_compass_bar_pos = 234
set osd_altitude_pos = 234
set osd_pid_roll_pos = 234
set osd_pid_pitch_pos = 234
set osd_pid_yaw_pos = 234
set osd_debug_pos = 234
set osd_power_pos = 234
set osd_warnings_pos = 14665
set osd_pit_ang_pos = 234
set osd_rol_ang_pos = 234
set osd_disarmed_pos = 234
set osd_nheading_pos = 234
set osd_nvario_pos = 234
set osd_esc_tmp_pos = 234
set osd_esc_rpm_pos = 234
set osd_flip_arrow_pos = 234
set osd_core_temp_pos = 234
set osd_log_status_pos = 234
set osd_rcchannels_pos = 234
set osd_camera_frame_pos = 35
set osd_efficiency_pos = 234
set osd_stat_tim_1 = OFF
set osd_stat_tim_2 = ON
set osd_stat_max_spd = ON
set osd_stat_max_dist = OFF
set osd_stat_min_batt = ON
set osd_stat_endbatt = OFF
set osd_stat_battery = OFF
set osd_stat_min_rssi = ON
set osd_stat_max_curr = ON
set osd_stat_used_mah = ON
set osd_stat_max_alt = OFF
set osd_stat_bbox = ON
set osd_stat_bb_no = ON
set osd_stat_max_fft = OFF
set osd_stat_total_time = OFF
set osd_stat_total_dist = OFF
set osd_profile = 1
set osd_profile_1_name = -
set osd_profile_2_name = -
set osd_profile_3_name = -
set osd_framerate_hz = 12
set system_hse_mhz = 8
set task_statistics = ON
set debug_mode = NONE
set rate_6pos_switch = OFF
set cpu_overclock = 108MHZ
set pwr_on_arm_grace = 5
set enable_stick_arming = OFF
set vtx_band = 0
set vtx_channel = 0
set vtx_power = 0
set vtx_softserial_alt = OFF
set vtx_freq = 0
set vtx_pit_mode_freq = 0
set vtx_halfduplex = ON
set vcd_video_system = AUTO
set vcd_h_offset = 0
set vcd_v_offset = 0
set max7456_clock = NOMINAL
set max7456_spi_bus = 2
set max7456_preinit_opu = OFF
set displayport_msp_serial = -1
set frsky_spi_autobind = OFF
set frsky_spi_tx_id = 0,0,0
set frsky_spi_offset = 0
set frsky_x_rx_num = 0
set led_inversion = 0
set pinio_config = 1,1,1,1
set usb_hid_cdc = OFF
set usb_msc_pin_pullup = ON
set flash_spi_bus = 3
set rcdevice_feature = 0
set gyro_1_bustype = SPI
set gyro_1_spibus = 1
set gyro_1_i2cBus = 0
set gyro_1_i2c_address = 0
set gyro_1_sensor_align = CW0
set gyro_1_align_roll = 0
set gyro_1_align_pitch = 0
set gyro_1_align_yaw = 0
set gyro_2_bustype = SPI
set gyro_2_spibus = 0
set gyro_2_i2cBus = 0
set gyro_2_i2c_address = 0
set gyro_2_sensor_align = CW0
set gyro_2_align_roll = 0
set gyro_2_align_pitch = 0
set gyro_2_align_yaw = 0
set i2c1_pullup = OFF
set i2c1_clockspeed_khz = 800
set i2c2_pullup = OFF
set i2c2_clockspeed_khz = 800
set i2c3_pullup = OFF
set i2c3_clockspeed_khz = 800
set mco2_on_pc9 = OFF
set spektrum_spi_protocol = 0
set spektrum_spi_mfg_id = 0,0,0,0
set spektrum_spi_num_channels = 0
set scheduler_relax_rx = 1
set scheduler_relax_osd = 1
set rpm_filter_harmonics = 3
set rpm_filter_q = 500
set rpm_filter_min_hz = 100
set rpm_filter_lpf_hz = 150
set flysky_spi_tx_id = 0
set stats_total_flights = 0
set stats_total_time_s = 0
set stats_total_dist_m = 0
set name = -
set display_name = -
set position_alt_gps_min_sats = 10
set position_alt_baro_fallback_sats = 7
set box_user_1_name = -
set box_user_2_name = -
set box_user_3_name = -
set box_user_4_name = -
# profile 0
set profile_name = -
set dterm_lpf1_dyn_expo = 5
set dterm_lpf1_type = PT1
set dterm_lpf1_static_hz = 75
set dterm_lpf2_type = PT1
set dterm_notch_hz = 0
set dterm_notch_cutoff = 0
set vbat_sag_compensation = 0
set pid_at_min_throttle = ON
set anti_gravity_gain = 3500
set acc_limit_yaw = 0
set acc_limit = 0
set crash_dthreshold = 50
set crash_gthreshold = 400
set crash_time = 500
set crash_delay = 0
set crash_recovery_angle = 10
set crash_recovery_rate = 100
set crash_limit_yaw = 200
set crash_recovery = OFF
set iterm_rotation = OFF
set iterm_relax = RP
set iterm_relax_cutoff = 15
set iterm_windup = 85
set iterm_limit = 400
set pidsum_limit = 500
set pidsum_limit_yaw = 400
set yaw_lowpass_hz = 100
set throttle_boost = 5
set acro_trainer_gain = 75
set p_pitch = 47
set i_pitch = 84
set d_pitch = 46
set f_pitch = 125
set p_roll = 45
set i_roll = 80
set d_roll = 40
set f_roll = 120
set p_yaw = 45
set i_yaw = 80
set d_yaw = 0
set f_yaw = 120
set angle_level_strength = 50
set horizon_transition = 75
set level_limit = 55
set horizon_tilt_effect = 75
set abs_control_gain = 0
set abs_control_limit = 90
set abs_control_cutoff = 11
set use_integrated_yaw = OFF
set d_min_roll = 30
set d_min_pitch = 34
set d_min_yaw = 0
set d_max_gain = 37
set d_max_advance = 20
set motor_output_limit = 100
set launch_angle_limit = 0
set launch_control_gain = 40
set thrust_linear = 0
set feedforward_boost = 15
set dyn_idle_min_rpm = 0
set dyn_idle_p_gain = 50
set dyn_idle_i_gain = 50
set dyn_idle_d_gain = 50
set level_race_mode = OFF
set simplified_i_gain = 100
set simplified_d_gain = 100
set simplified_pi_gain = 100
# rateprofile 0
set rateprofile_name = -
set thr_mid = 50
set thr_expo = 0
set rates_type = ACTUAL
set quickrates_rc_expo = OFF
set roll_rc_rate = 7
set pitch_rc_rate = 7
set yaw_rc_rate = 7
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 67
set pitch_srate = 67
set yaw_srate = 67
set tpa_rate = 65
set tpa_breakpoint = 1350
set tpa_mode = D
set throttle_limit_type = OFF
set roll_rate_limit = 1998
set pitch_rate_limit = 1998
set yaw_rate_limit = 1998
set roll_level_expo = 0
set pitch_level_expo = 0
# end the command batch
batch end
.txt   Dump.txt (Size: 28.56 KB / Downloads: 36)
Wire the receiver to UART1. It's broken out via a connector for the DJI system. Just take the RX and TX lines from that and connect them to your receiver, and change UART1 to SerialRX in BF.
(16-Jun-2022, 06:31 PM)V-22 Wrote: Wire the receiver to UART1. It's broken out via a connector for the DJI system. Just take the RX and TX lines from that and connect them to your receiver, and change UART1 to SerialRX in BF.
Well, first thank you for answering that fast.
I though about swaping UART 1 and 2 back when i was troubling to get rid of Bootloader mod. Didnt do it tho, cause UART 1 is showed to be dedicated to AnalogVideoOut (Wich i am using for my AnalogVtx). But I guess it is worth trying, ill do that tomorrow when i leave work, i'll keep you informed!
Thanks!
I just realised i messed up the legend on my picture. Its UART2 not UART1. UART1 is supposely dedicated to AnalogVideoOut and SmartAudio. I actualy soldered my Analog Vtx on it, and it works with OSD just fine.
I though about swaping UART 1 and 2 back when i was troubling to get rid of Bootloader mod. But I guess it is worth trying, ill do that tomorrow when i leave work, i'll keep you informed!
PS: (There is a mysterious port next to UART2 with one G, one 5v and a pad named "TX-2" if you know what i can be, the official documentation dont tell anything about it)
Thanks!
It looks to me like your yellow wire is soldered to the Rx both on the receiver and the FC. I believe if you swap the yellow and white wires on the FC that should fix the problem.
[-] The following 2 users Like Kleinwest's post:
  • Vadimcherub, Pathfinder075
[Image: SucceX-d-whoop-aio-board-66_7_-1000x1000...1593647183]
(16-Jun-2022, 10:28 PM)Kleinwest Wrote: It looks to me like your yellow wire is soldered to the Rx both on the receiver and the FC.  I believe if you swap the yellow and white wires on the FC that should fix the problem.
And you were right Sir! I soldered them so many time that the last time I did, i managed to invert them.
I just corrected that, and.... Sadly I still get the same result.
Im gonna keep strugling, but this is one step forward! Thank you!
What is serialrx_inverted set to?
Okay, so i connected my EP2 RX to my UART1. This VTX UART has "Vout" "5" "G" "T1". I assumed T1 goes with my RX's EP2 and that Vout was a renamed R1.
At first it didnt even turned on, but i remembered that this UART wasnt powered by usb, only with battery. It actualy turned on when i plugged the battery, but still, no output recieved from my controler. I changed the UART1 to Serial RX in BTF, but I'm still stuck here ._.
[Image: tHvHMQLl.jpg]
Nevertheless thanks for your help, any try i can give is welcomed!
(17-Jun-2022, 08:12 PM)Kleinwest Wrote: What is serialrx_inverted set to?
I have tried Both, On and Off.
It is now on Off, and it doesnt seem to work eitherways.
Something off tho, since i updated the FC, the flashing light of the EP2 changed. It used to be blinking twice for no connection, and solid light for bind.
Now it goes, blink slow for no connection, and blink 3 time fast for bound with radio. I have no other trace of this light behavior on the internet forums.
Once again, thank you for your help!
Reading through this post, I think you have tried almost every common check and configuration by now.
I will suggest you get a new ELRS receiver as you current receiver might have faulty hardware.
Good evening everyone!
I am happy! For I finaly succeed in getting output from my EP2.
The 3 time blinking of the EP2 meant the error "model missmatch"
I changed the model for them to fit, and tadaaa, got output.
It was actualy working fine before i updated it, but is still had wrong wirring.
I added a seccond problem trying to solve the first one...
Anyway
I can't wait to make this little boy fly. This thread can be closed peacefully now.
Thank you all for your help, I wouldve been stuck on this for ages without you!
See you soon, in here, and in the air!
  Cannot clear CALIB arming flag in betaflight necbot 11 240 36 minutes ago
Last Post: necbot
  ELRS in a non standard way Pathfinder075 6 98 2 hours ago
  Mobula 7 1s analog Elrs Configurator Target soky157 11 183 19-Jun-2024, 07:13 AM
  GPS not in betaflight after Crash ToasterBox 0 60 19-Jun-2024, 03:38 AM
Last Post: ToasterBox
  Receiver doesn't show up in Betaflight asdvcd 3 176 10-Jun-2024, 11:22 PM
Last Post: asdvcd
