20-Jan-2024, 01:50 PM (This post was last modified: 13-Feb-2024, 11:28 PM by SnowLeopardFPV. Edit Reason: Added "EDIT" line. )
EDIT (13th February 2024): EdgeTX v2.9.4 is now available. See another thread HERE for details.
EdgeTX v2.9.3 ("Providence") was released earlier today. Details and links are below.
- Release Notes: https://github.com/EdgeTX/edgetx/releases/tag/v2.9.3
- Installation Guide: https://github.com/.../edg.../wiki/EdgeTX-Installation-Guide
- Flash firmware via a Chrome based browser: https://buddy.edgetx.org/#/flash?version=v2.9.3
- SD Card Pack: https://github.com/EdgeTX/edgetx-sdcard/...tag/v2.9.0
- Sound Pack: https://github.com/EdgeTX/edgetx-sdcard-...tag/v2.9.0
- User Manual: https://edgetx.gitbook.io/edgetx-user-manual/v/v2.9
Quote:We are pleased to offer EdgeTX "Providence" v2.9.3, which fixes several small but possibly quite annoying issues including inputs and mixer lists not being displayed properly, mix delays not working when switches were in the mix, Linux Companion not being able to check for updates, and a few other bits and pieces.
Warning
A bug in the behaviour of the 'delay' mixer option has been fixed whereby it would previously not function at all if the mix line was disabled for some flight modes/if there was mix line with a switch. Please check your model to make sure it behaves correctly if you use the delay option or had configured it in the past and it didn't seem to be working!
What's Changed
RadioCompanion Full Changelog: v2.9.2...v2.9.3
- fix: Enable external module power for SBUS trainer by @raphaelcoeffic in #4326
- fix: Mix delay not working when mix line has a switch by @philmoz in #4364
- fix: Properly scale PREC2 sensor values using "ratio" by @frankiearzu in #4083
- fix(telemetry): Inconsistent/wrong GPS distance calculation by @mha1 in #4442
- fix(color): New inputs disappear until restart by @philmoz in #4317 and #4330
- fix(color): Mixes list display incorrect after deleting all mixer lines by @philmoz in #4477
- fix(bw): Prevent points being drawn outside of LCD buffer (causing EM crash) in #4550
- feat: Allow Touch Screen Mod on Horus X10 Transmitters by @MRC3742 in #4151
- feat(X10E): Allow minimum backlight value to be much lower by @packetpilot in #4540
To learn more about new features, known issues, and other changes in 2.9.x, please see the release notes for v2.9.0
Supported radios
The full list of supported radios and their support status can be viewed here on the EdgeTX website.
Installation Guide
https://github.com/EdgeTX/edgetx.github....tion-Guide
Flash firmware via Chrome based browser
Unofficial builds
Multilingual and custom are available here. In the meantime, you can still build your own firmware online following this guide, request a specific build at #4000 or ask on Discord for someone to build one for you.
