02-Sep-2023, 08:44 PM (This post was last modified: 29-Sep-2023, 10:52 PM by SnowLeopardFPV. Edit Reason: Added "EDIT" line. )
EDIT (29th September 2023): EdgeTX v2.9.1 is now available. See another thread HERE for details.
The final release of the EdgeTX v2.9.0 ("Providence") firmware was published earlier today. Full details are below.
Summary of changes since v2.8
Current for all merged PRs as of 03/07/2023 (v2.9 RC1)
Below is a summary of changes that affect the user interface and/or how EdgeTX functions. It does not cover all bug fixes. For a complete list of changes (including bug fixes), please read the release notes.
Color Screen Radios
- Release Notes: https://github.com/EdgeTX/edgetx/releases/tag/v2.9.0
- Installation Guide: https://github.com/.../edg.../wiki/EdgeTX-Installation-Guide
- Flash firmware via a Chrome based browser: https://buddy.edgetx.org/#/flash?version=v2.9.0
- SD Card Pack: https://github.com/EdgeTX/edgetx-sdcard/...tag/v2.9.0
- Sound Pack: https://github.com/EdgeTX/edgetx-sdcard-...tag/v2.9.0
- User Manual: https://edgetx.gitbook.io/edgetx-user-manual/v/v2.9
Quote:We are pleased to offer EdgeTX "Providence" v2.9.0. It is an important milestone for us as it marks the completion of the color screen UI changes started with 2.8.
Migration Information
This version removes support for direct "on radio" migration from versions before v2.6
This version of EdgeTX removes the ability to upgrade on-radio directly from OpenTX 2.3.15 or EdgeTX versions prior to 2.6 (which used the BIN format for storage of model and radio settings). It will however still be possible to migrate settings from older versions of OpenTX and EdgeTX via EdgeTX Companion. In some instances, particularly with some older OpenTX configurations, this is the more reliable mechanism for upgrading.
Highlights of this release include:More information with regards to changes, which is broken down into by screen type (Color LCD and B&W), is available in the user manual here.
- LVGL re-write for the color screen interface is now complete. In doing so, there have been numerous improvements to the curves, special functions, logical switches and telemetry screens. Many thanks to @philmoz for doing a lot of the heavy lifting here.
- Various tabs can be turned on or off globally or on a per-model basis on both colorlcd and B&W radios. Have a helicopter that needs the heli tab, but don't want it showing on all your models? Or don't want to see it at all? The new "Enabled Features" button in the radio setup and model setup screens has got you covered! It looked like this during development.
- Numerous improvements to USB joystick support (allowing for greater control of how your radio controls are presented to the computer), as well as the ability to use your radio in conjunction to the radio simulator that is part of EdgeTX Companion.
- Support added for the Flysky FRM303 AFHDS3 RF module for some radios (NV14/EL18 native, TX16S with a mod, others to be documented). More information about the FRM303 here.
- Support added for the Multiplex MLink JR type module. See #3352 for more information.
- Numerous DSM telemetry fixes thanks to @frankiearzu via #3615, #3366, #3126 and #3690
- B&W screen radios: The time is now shown on the main screen between the horizontal trim sliders.
- B&W screen radios: Some of the longer and less commonly used sections in the model settings are now collapsed by default - i.e. timers, throttle settings, pre-flight checks, greatly reducing the amount of scrolling necessary.
- Support for Hebrew was added to radio firmware for color LCD radios and a voice pack is also available.
- If you have noise or buzzing when using high RF power outputs and no audio is playing, there is now a mute option for most radios - see #3703, #3710
- For those using the FrSky R9M 2019 in ACCESS mode in conjunction with the hardware mod, a separate firmware is no longer required. Simply choose the "External Module" option in Radio Settings -> Hardware against the relevant Serial / AUX port. #2562
Full Changelog: v2.8.5...v2.9.0
UI/UX behavioral changes and/or new capabilities:Known Limitations and Issues
- Prior to 2.9, when you connected the radio to the computer, two drives would be shown - a firmware drive, and the SD card. As of 2.9, only the SD card drive is shown, since updating the firmware via the firmware drive is extremely unreliable on Windows systems, and only leads to confusion.
- B&W screen radios with haptic vibration motors gave a momentary buzz when the power-on delay has completed. Color LCD radios now also do the same.
- Another layout was added for color radios - 4+2B right side 3QRT+1QRT by @daniel-snowsurf in #3315
Supported radios
- Telemetry issue with FlySky FS-IA6B receivers: #3543
- External modules driven by PPM or S.BUS: incoming S.PORT telemetry is not processed anymore, as was the case with previous releases (see #3877).
The full list of supported radios and their support status can be viewed here on the EdgeTX website.
Installation Guide
https://github.com/EdgeTX/edgetx.github.io/wiki/EdgeTX-Installation-Guide
Flash firmware via Chrome based browser
Unofficial builds
Multilingual and custom builds will be available 24-48 hours after 2.9.0 is released. In the meantime, you can still build your own firmware online following this guide, or ask on Discord for someone to build one for you.
Color Screen Radios
- General Changes
- LVGL conversion of all pages is now complete.
- Adjusted padding and spacing on many pages and buttons for a better look.
- No more on-radio model conversions from .otx format. Users migrating from OpenTX will need to import their models to EdgeTX Companion. See EdgeTX Migration guide for instructions how to migrate from OpenTX to EdgeTX.
- Only SD card is mapped to device in USB Storage Mode.
- User interface page
- Long press the [SYS] button to go to the Radio Setup page.
- Model Select page
- Now named Manage Models instead of Model Select.
- Edit Labels option is now called Label Models.
- Added model quick select. When enabled in radio settings, this feature allows you to select a model as active model in the manage model screen by double tapping on it.
- External RF
- Added mode R9M ACCESS to enable R9M Access Mod. Compilation option is no longer needed.
- PPM Frames automatically adjust based on number of configured channels
- Trainer (Model Setup)
- Timers
- Added Beeps & Haptic and Voice & Haptic as options for countdown option
- Enabled Features
- New section in Model Setup - allows you to configure which tabs are visible in the selected model's radio setup and model settings area of EdgeTX.
- USB Joystick
- New section in Model Setup - allows users to select between Classic and Advanced Mode.
- Adds advanced joystick configuration options in Advanced Mode.
- Flight Modes
- New screen layout to allow better overview of configured flight modes.
- Inputs
- New screen layout, only shows configured inputs.
- New + button to add additional inputs.
- Curves
- Updated screen layout
- Moving the control sticks will update the stick position on the curve in real time.
- Logical switches
- Special Functions
- New screen layout, only shows configured special functions
- New + button to add special functions
- Lua Script function adds repeat option
- Telemetry
- Added option to Show Instance ID On/Off
- SD Card
- Added OTA flashing for FrSky X10s & X12s receivers for transmitters with internal ISRM/Access modules.
- Radio Setup
- Added Enabled Features settings to configure the Global settings for which tabs are visible in the Radio Setup and Model Settings area of EdgeTX.
- Added model quick select configuration option. When enabled, this feature allows you to select a model as active model in the manage model screen by double tapping on it.
- Image and Sound folders limited to 799 files each. If the folders contain more than 799 files, the file selection dropdown in model settings will not work properly. This is a limitation of LVGL.
- Trainer (Radio Settings)
- Changed mode options from += and := to Replaced and Add for easier configuration.
- Hardware
- Updated debug analog screen and touch screen response.
- Added External module option to Aux1 and Aux2 to enable configuring R9M Access Mod in Model Settings.
- Added Mute if no sound option - puts the transmitter in mute mode until a sound needs to be played. This prevents interference noise from high-powered TX modules from coming out of the transmitter speakers.
- Screen Settings
- Added 4x2B screen layout.
- Increased the max views from 5 to 10.
- Widgets
- Value widget added align left, center, right option for label and value.
- Text widget added align left, center, right option for label and value.
- Added Value2 widget to display telemetry data better.
- All widgets are now sorted alphabetical by name.
- Updated color picker for widgets, can select system theme colors. Colors are not applied until saved.
- Alerts
- Alerts now display a "press any key" prompt.
- Long press of the touchscreen can close an alert.
- All buttons can be used to close an alert. Buttons will not open other UI pages over the alert.
- Channel Monitor
- Logical switch page updated
- Statistics
- Small changes to labels on debug page.
- Languages
- Added Hebrew language support.
- New Hardware Support
- Flysky FRM303 Support (External RX Module)
- Segger RTT debug support
- General Changes
- Main View
- Added clock to main view pages.
- Model Settings
- Timer configuration options are hidden when timer is set to Off.
- Throttle configuration options are hidden in collapsible menu.
- Preflight Checklist configuration options are hidden in collapsible menu.
- Added Enabled Features option - allows you to configure which pages are visible in the selected model's radio setup and model settings area of EdgeTX; configuration options are hidden in collapsible menu.
- Adds USB Joystick mode- allows users to select between Classic and Advanced Mode; adds advanced joystick configuration options when in Advanced Mode.
- Added Bluetooth trainer mode with FrSky bluetooth module.
- Telemetry
- RSSI Source option was removed - set to "default" permanently
- Special Functions
- Lua Script function adds repeat option.
- Display
- Added clock to Telemetry screens.
- Radio Setup
- Rx channel ord option renamed to Def Chan Ord for better understanding.
- Hardware
- Audio Mute option added - puts the transmitter in mute mode until a sound needs to be played. This prevents interference noise from high-powered TX modules from coming out of the transmitter speakers.
- Language
- Added Hewbrew language support.
- RadioMaster Boxer
- Flysky digital gimbal support for Radio Master Boxer
- RadioMaster Boxer
