I have strange behavior i flashed newest BF to my newest XJB 145 and everything seems fine when the drone is connected to the usb. When I plugged it out and use only battery there are 3 esc beeps and nothing more. Leds are not flashing also and it won't arm.
I had exactly the same situation with ARFun 95. I broke it, replaced the tower FC and esc and after pluging the battery there was no life in it only 3 beeps.
Before crash everything was working fine. I realized that the FC could not be powered so I added the power from battery leads to the FC directly and now it is working but as far as I remember there was no such wires before.
FC led is not on with battery connected. If the 5V regulator is dead can I power it somehow different or now all i can do is buy new one for $30?
This is probably the one that I have: https://www.hglrc.com/collections/flight...k-rc-drone
I forget ... after my IBUS reciever didn't want to work with SBUS pad I had to connect it via RX3 (UART 3) port so I soldered really near the 6R8 (on the picture) so this is the voltage regulator right? As far as I remember i checked everything twice after soldering and all was working well even with battery connected
Strange that this is happening on my second drone after flashing BF. XJB is new so what is happening? Any help will be appriciated
This post is a mess I know but that are quick thoughts that came to me right know.
