Threads: 1
Likes Received: 0 in 0 posts
Likes Given: 1
0 19-Dec-2022, 03:27 PM Hello everyone,
I'm planning to build my first drone and I think it's best to buy a DJI 03 AIR unit.
I see that it can only be used with a DJI controller, but I wonder what about the glasses?
Which glasses are compatible with the O3 air unit?
Threads: 596
Likes Received: 9,039 in 6,690 posts
Likes Given: 1,428
796 You can use either the DJI FPV Goggles V2 or the new DJI Goggles 2 with the new O3 Air Unit. For the DJI FPV Goggles V2 you just need to flash new firmware to them to make them compatible.
If you already own a pair of the DJI FPV Goggles V1 then you are unfortunately out of luck as it is highly unlikely those will ever be compatible with the O3 Air Unit.
Threads: 4
Likes Received: 65 in 60 posts
Likes Given: 17
8 To add onto what snowleopard said, you also don't have to use the DJI controller. You can use other radios and control systems to allow better performance and range if you'd like
Threads: 1
Likes Given: 1
0 Hmm, I didn't know that. But can I use Radiomaster TX16s with O3 air unit?
Are only DJI googles compatible with O3 air unit? Or I can use any other?
Can you tell me which one do you suggest using (googles & controller)?
