31-Mar-2022, 07:48 PM
Ok, no more shouty caps
I was just looking online (ok, Amazon) at 5 volt LED light strips. I don't see any reason why they couldn't be used for drones!? They're WS2812B, addressable, and run on 5 volt. Hmmm...
Of what I've found, they have densities ranging from 60 to 144 LEDs per meter. The 60 per meter i think would look pretty weak at 12mm between LEDs. The 74 per meter are 8.78mm apart. The 96 are 5.44mm, the 100 are 5.09mm, and the most dense I've found are 144 per meter at a tiny 1.92mm between them!!
With Betaflight having programmability for 32 LEDs, I could see the 100per might be a good choice? As sweet as the 144's would look, I think I'd max out the 32 in Betaflight pretty quick and maybe not cover much 'ground'.
I see most (all) of the LED strips can be cut to length, so making them fit would be easy. The strips can be found from around 3 feet to over 16 feet. Obviously more than what could reasonably fit on a quad.
I'm doing on the math on what it would take for a full 360 wrap (or 2?) and what good looking density to pick to do so. How cool would a cinewhoop be all lit up?!!
I want to turn my Green Hornet into a UFO
I would have to keep an eye on the amperage draw, as the Green Hornet FC does have an LED pad. Good for about 2 amps? Unfortunately I'm not an ampologist, I'd have to Google how much they would draw. Could I make a relay type thing if too many amps? Run 64 of them in parallel....hmm?!
Comments welcome!
Comments welcome!
