DiaTone R349 Crossfire problems
349
Hi Guys,
I have just brought a Diatone 349 and am hoping to put on a crossfire and a cp antenna i have a axii 2 micro here that should work.
A few days ago i burnt out the diamond VTX on my crossfired lava x so i am going to rebuild it onto another frame later, but for now i thought i could use the crossfire nano rx from this on my new 349 so i have soldered channel 1 to Rx6 and channel 2 to TX6 i am getting great telemetry but no stick input in betaflight the transmitter and receiver both show bound (green) for extra information i am using the same model as the lava x used on my tranis and the receiver was working a couple days ago
Im not sure what to do next, any help would be greatly accepted.
cheers
my dump file
dump
# Betaflight / FURYF4OSD (FY4O) 3.5.1 Sep  8 2018 / 05:21:25 (d9fb5ca13) MSP API: 1.40
board_name FURYF4OSD
manufacturer_id
# name
name diatone
# resources
resource BEEPER 1 A08
resource MOTOR 1 A03
resource MOTOR 2 B00
resource MOTOR 3 B01
resource MOTOR 4 A02
resource MOTOR 5 NONE
resource MOTOR 6 NONE
resource MOTOR 7 NONE
resource MOTOR 8 NONE
resource SERVO 1 NONE
resource SERVO 2 NONE
resource SERVO 3 NONE
resource SERVO 4 NONE
resource SERVO 5 NONE
resource SERVO 6 NONE
resource SERVO 7 NONE
resource SERVO 8 NONE
resource PPM 1 C09
resource PWM 1 NONE
resource PWM 2 NONE
resource PWM 3 NONE
resource PWM 4 NONE
resource PWM 5 NONE
resource PWM 6 NONE
resource PWM 7 NONE
resource PWM 8 NONE
resource LED_STRIP 1 A00
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 NONE
resource SERIAL_TX 3 B10
resource SERIAL_TX 4 NONE
resource SERIAL_TX 5 NONE
resource SERIAL_TX 6 C06
resource SERIAL_TX 7 NONE
resource SERIAL_TX 8 NONE
resource SERIAL_TX 9 NONE
resource SERIAL_TX 10 NONE
resource SERIAL_TX 11 NONE
resource SERIAL_TX 12 NONE
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 NONE
resource SERIAL_RX 3 B11
resource SERIAL_RX 4 NONE
resource SERIAL_RX 5 NONE
resource SERIAL_RX 6 C07
resource SERIAL_RX 7 NONE
resource SERIAL_RX 8 NONE
resource SERIAL_RX 9 NONE
resource SERIAL_RX 10 NONE
resource SERIAL_RX 11 NONE
resource SERIAL_RX 12 NONE
resource INVERTER 1 C00
resource INVERTER 2 NONE
resource INVERTER 3 NONE
resource INVERTER 4 NONE
resource INVERTER 5 NONE
resource INVERTER 6 NONE
resource INVERTER 7 NONE
resource INVERTER 8 NONE
resource INVERTER 9 NONE
resource INVERTER 10 NONE
resource INVERTER 11 NONE
resource INVERTER 12 NONE
resource I2C_SCL 1 B06
resource I2C_SCL 2 NONE
resource I2C_SCL 3 NONE
resource I2C_SDA 1 B07
resource I2C_SDA 2 NONE
resource I2C_SDA 3 NONE
resource LED 1 B05
resource LED 2 B04
resource LED 3 NONE
resource RX_BIND 1 NONE
resource RX_BIND_PLUG 1 NONE
resource SPI_SCK 1 A05
resource SPI_SCK 2 B13
resource SPI_SCK 3 C10
resource SPI_MISO 1 A06
resource SPI_MISO 2 B14
resource SPI_MISO 3 C11
resource SPI_MOSI 1 A07
resource SPI_MOSI 2 B15
resource SPI_MOSI 3 C12
resource ESCSERIAL 1 C09
resource ADC_BATT 1 C01
resource ADC_RSSI 1 C02
resource ADC_CURR 1 C03
resource ADC_EXT 1 NONE
resource PINIO 1 NONE
resource PINIO 2 NONE
resource PINIO 3 NONE
resource PINIO 4 NONE
resource USB_MSC_PIN 1 NONE
resource FLASH_CS 1 B03
resource OSD_CS 1 B12
resource SPI_PREINIT_IPU 1 A04
resource SPI_PREINIT_IPU 2 B03
resource SPI_PREINIT_IPU 3 B12
resource SPI_PREINIT_IPU 4 NONE
resource SPI_PREINIT_IPU 5 NONE
resource SPI_PREINIT_IPU 6 NONE
resource SPI_PREINIT_IPU 7 NONE
resource SPI_PREINIT_IPU 8 NONE
resource SPI_PREINIT_IPU 9 NONE
resource SPI_PREINIT_IPU 10 NONE
resource SPI_PREINIT_IPU 11 NONE
resource SPI_PREINIT_OPU 1 NONE
resource SPI_PREINIT_OPU 2 NONE
# mixer
mixer QUADX
# servo
servo 0 1000 2000 1500 100 -1
servo 1 1000 2000 1500 100 -1
servo 2 1000 2000 1500 100 -1
servo 3 1000 2000 1500 100 -1
servo 4 1000 2000 1500 100 -1
servo 5 1000 2000 1500 100 -1
servo 6 1000 2000 1500 100 -1
servo 7 1000 2000 1500 100 -1
# servo mix
smix reset
feature -RANGEFINDER
feature -OSD
feature -TRANSPONDER
feature -AIRMODE
feature -RX_SPI
feature -SOFTSPI
feature -ESC_SENSOR
feature -ANTI_GRAVITY
feature -DYNAMIC_FILTER
feature RX_SERIAL
feature TELEMETRY
feature OSD
feature ANTI_GRAVITY
feature DYNAMIC_FILTER
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
beeper BLACKBOX_ERASE
beeper CRASH FLIP
beeper CAM_CONNECTION_OPEN
beeper CAM_CONNECTION_CLOSED
beeper RC_SMOOTHING_INIT_FAIL
# beacon
beacon GYRO_CALIBRATED
beacon -RX_LOST
beacon RX_LOST_LANDING
beacon DISARMING
beacon ARMING
beacon ARMING_GPS_FIX
beacon BAT_CRIT_LOW
beacon BAT_LOW
beacon GPS_STATUS
beacon -RX_SET
beacon ACC_CALIBRATION
beacon ACC_CALIBRATION_FAIL
beacon READY_BEEP
beacon MULTI_BEEPS
beacon DISARM_REPEAT
beacon ARMED
beacon SYSTEM_INIT
beacon ON_USB
beacon BLACKBOX_ERASE
beacon CRASH FLIP
beacon CAM_CONNECTION_OPEN
beacon CAM_CONNECTION_CLOSED
beacon RC_SMOOTHING_INIT_FAIL
# map
map AETR1234
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 0 0 0 1825 2100 0 0
aux 1 28 0 1825 2100 0 0
aux 2 0 0 900 900 0 0
aux 3 0 0 900 900 0 0
aux 4 0 0 900 900 0 0
aux 5 0 0 900 900 0 0
aux 6 0 0 900 900 0 0
aux 7 0 0 900 900 0 0
aux 8 0 0 900 900 0 0
aux 9 0 0 900 900 0 0
aux 10 0 0 900 900 0 0
aux 11 0 0 900 900 0 0
aux 12 0 0 900 900 0 0
aux 13 0 0 900 900 0 0
aux 14 0 0 900 900 0 0
aux 15 0 0 900 900 0 0
aux 16 0 0 900 900 0 0
aux 17 0 0 900 900 0 0
aux 18 0 0 900 900 0 0
aux 19 0 0 900 900 0 0
# adjrange
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# vtx
vtx 0 0 0 0 900 900
vtx 1 0 0 0 900 900
vtx 2 0 0 0 900 900
vtx 3 0 0 0 900 900
vtx 4 0 0 0 900 900
vtx 5 0 0 0 900 900
vtx 6 0 0 0 900 900
vtx 7 0 0 0 900 900
vtx 8 0 0 0 900 900
vtx 9 0 0 0 900 900
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# master
set align_gyro = DEFAULT
set gyro_32khz_hardware_lpf = NORMAL
set gyro_sync_denom = 1
set gyro_lowpass_type = PT1
set gyro_lowpass_hz = 100
set gyro_lowpass2_type = PT1
set gyro_lowpass2_hz = 300
set gyro_notch1_hz = 0
set gyro_notch1_cutoff = 0
set gyro_notch2_hz = 0
set gyro_notch2_cutoff = 0
set gyro_calib_duration = 125
set gyro_offset_yaw = 0
set yaw_spin_recovery = ON
set yaw_spin_threshold = 1950
set gyro_use_32khz = OFF
set dyn_notch_quality = 70
set dyn_notch_width_percent = 50
set align_acc = DEFAULT
set acc_hardware = AUTO
set acc_lpf_hz = 10
set acc_trim_roll = 0
set acc_calibration = -74,13,4
set min_check = 1050
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 100
set rssi_offset = 0
set rssi_invert = OFF
set rc_interp = AUTO
set rc_interp_ch = RPYT
set rc_interp_int = 19
set rc_smoothing_type = INTERPOLATION
set rc_smoothing_input_hz = 0
set fpv_mix_degrees = 0
set max_aux_channels = 14
set serialrx_provider = CRSF
set serialrx_inverted = OFF
set spektrum_sat_bind = 0
set airmode_start_throttle_percent = 32
set serialrx_halfduplex = OFF
set adc_device = 1
set blackbox_p_ratio = 32
set blackbox_record_acc = ON
set blackbox_mode = NORMAL
set min_throttle = 1070
set max_throttle = 2000
set dshot_idle_value = 300
set dshot_burst = OFF
set use_unsynced_pwm = OFF
set motor_pwm_rate = 480
set motor_pwm_inversion = OFF
set motor_poles = 14
set thr_corr_value = 0
set thr_corr_angle = 800
set failsafe_delay = 4
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_procedure = DROP
set align_board_yaw = 0
set gimbal_mode = NORMAL
set bat_capacity = 0
set vbat_max_cell_voltage = 45
set vbat_full_cell_voltage = 41
set vbat_hysteresis = 1
set current_meter = ADC
set battery_meter = ADC
set vbat_detect_cell_voltage = 30
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set vbat_cutoff_percent = 100
set vbat_scale = 110
set vbat_divider = 10
set vbat_multiplier = 1
set ibata_scale = 400
set ibata_offset = 0
set ibatv_scale = 0
set ibatv_offset = 0
set beeper_inversion = ON
set beeper_od = OFF
set beeper_frequency = 0
set yaw_motors_reversed = OFF
set 3d_limit_low = 1000
set 3d_limit_high = 2000
set 3d_switched_mode = OFF
set servo_center_pulse = 1500
set servo_pwm_rate = 50
set servo_lowpass_hz = 0
set tri_unarmed_servo = ON
set accxy_deadband = 40
set accz_deadband = 40
set acc_unarmedcal = ON
set small_angle = 60
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_rescue_angle = 32
set gps_rescue_yaw_p = 40
set gps_rescue_throttle_min = 1200
set gps_rescue_min_sats = 8
set deadband = 0
set yaw_deadband = 0
set pid_process_denom = 4
set runaway_takeoff_deactivate_throttle_percent = 25
set tlm_inverted = OFF
set tlm_halfduplex = ON
set frsky_default_lat = 0
set frsky_default_long = 0
set frsky_gps_format = 0
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set hott_alarm_int = 5
set pid_in_tlm = OFF
set report_cell_voltage = OFF
set smartport_use_extra_sensors = OFF
set ledstrip_grb_rgb = GRB
set osd_units = METRIC
set osd_warn_crash_flip = ON
set osd_warn_esc_fail = ON
set osd_warn_core_temp = OFF
set osd_rssi_alarm = 20
set osd_cap_alarm = 700
set osd_alt_alarm = 100
set osd_esc_temp_alarm = -128
set osd_esc_rpm_alarm = -1
set osd_core_temp_alarm = 70
set osd_ah_max_pit = 20
set osd_ah_max_rol = 40
set osd_tim1 = 2560
set osd_tim2 = 2561
set osd_vbat_pos = 2497
set osd_rssi_pos = 234
set osd_tim_1_pos = 234
set osd_tim_2_pos = 2519
set osd_flymode_pos = 234
set osd_g_force_pos = 234
set osd_throttle_pos = 234
set osd_vtx_channel_pos = 2456
set osd_crosshairs_pos = 205
set osd_ah_sbar_pos = 206
set osd_ah_pos = 78
set osd_current_pos = 233
set osd_mah_drawn_pos = 2508
set osd_craft_name_pos = 2091
set osd_gps_speed_pos = 234
set osd_gps_lon_pos = 234
set osd_gps_lat_pos = 234
set osd_gps_sats_pos = 234
set osd_home_dir_pos = 234
set osd_home_dist_pos = 234
set osd_compass_bar_pos = 234
set osd_altitude_pos = 234
set osd_pid_roll_pos = 234
set osd_pid_pitch_pos = 234
set osd_pid_yaw_pos = 234
set osd_debug_pos = 234
set osd_power_pos = 234
set osd_pidrate_profile_pos = 409
set osd_warnings_pos = 329
set osd_avg_cell_voltage_pos = 2433
set osd_pit_ang_pos = 234
set osd_rol_ang_pos = 234
set osd_disarmed_pos = 234
set osd_nheading_pos = 234
set osd_nvario_pos = 234
set osd_esc_tmp_pos = 234
set osd_esc_rpm_pos = 234
set osd_core_temp_pos = 234
set osd_stat_tim_1 = OFF
set osd_stat_tim_2 = ON
set osd_stat_max_spd = ON
set osd_stat_max_dist = OFF
set osd_stat_min_batt = ON
set osd_stat_endbatt = OFF
set osd_stat_battery = OFF
set osd_stat_min_rssi = ON
set osd_stat_max_curr = ON
set osd_stat_used_mah = ON
set osd_stat_max_alt = OFF
set osd_stat_bbox = ON
set osd_stat_bb_no = ON
set task_statistics = ON
set debug_mode = NONE
set rate_6pos_switch = OFF
set cpu_overclock = OFF
set pwr_on_arm_grace = 5
set vtx_band = 5
set vtx_channel = 3
set vtx_power = 1
set vtx_freq = 5732
set vtx_pit_mode_freq = 0
set vtx_halfduplex = ON
set vcd_video_system = AUTO
set vcd_h_offset = 0
set vcd_v_offset = 0
set max7456_clock = DEFAULT
set max7456_spi_bus = 2
set led_inversion = 0
set dashboard_i2c_bus = 1
set dashboard_i2c_addr = 60
set pinio_config = 1,1,1,1
set usb_hid_cdc = OFF
set usb_msc_pin_pullup = OFF
set flash_spi_bus = 3
set rcdevice_init_dev_attempts = 4
# profile
set dterm_lowpass_type = PT1
set dterm_lowpass_hz = 100
set dterm_lowpass2_hz = 200
set dterm_notch_hz = 0
set dterm_notch_cutoff = 0
set vbat_pid_gain = OFF
set pid_at_min_throttle = ON
set anti_gravity_gain = 5500
set feedforward_transition = 28
set acc_limit_yaw = 100
set acc_limit = 0
set crash_dthreshold = 50
set crash_gthreshold = 400
set crash_time = 500
set crash_delay = 0
set crash_recovery_angle = 10
set crash_recovery_rate = 100
set crash_limit_yaw = 200
set crash_recovery = OFF
set iterm_rotation = ON
set smart_feedforward = OFF
set iterm_relax = OFF
set iterm_relax_type = GYRO
set iterm_relax_cutoff = 11
set iterm_windup = 40
set iterm_limit = 150
set pidsum_limit = 500
set pidsum_limit_yaw = 400
set yaw_lowpass_hz = 0
set throttle_boost = 5
set acro_trainer_gain = 75
set p_pitch = 28
set i_pitch = 22
set d_pitch = 17
set f_pitch = 78
set p_roll = 22
set i_roll = 22
set d_roll = 19
set f_roll = 78
set p_yaw = 23
set i_yaw = 30
set d_yaw = 18
set f_yaw = 81
set p_level = 36
set i_level = 35
set d_level = 0
set level_limit = 55
set horizon_tilt_effect = 75
set abs_control_gain = 0
set abs_control_limit = 90
# rateprofile
set thr_mid = 50
set thr_expo = 0
set rates_type = BETAFLIGHT
set roll_rc_rate = 100
set pitch_rc_rate = 113
set yaw_rc_rate = 100
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set pitch_srate = 70
set yaw_srate = 70
set tpa_rate = 35
set tpa_breakpoint = 1650
set throttle_limit_type = OFF
Youtube
A Mistake is only a Mistake if you refuse to correct your error.
Turn serial rx on port 6 and off on port 1.
(03-May-2020, 02:00 PM)voodoo614 Wrote: Turn serial rx on port 6 and off on port 1.
Hey Voodoo614,
Pretty sure it is setup like that here's another dump maybe i posted the wrong dump file this is the current one.
I'm Sure i've been here before with this issue on another quad just can't remember :-)
Thanks for reading.
dump
manufacturer_id
# name
name diatone
# resources
resource PPM 1 C09
resource PWM 1 NONE
resource PWM 2 NONE
resource PWM 3 NONE
resource PWM 4 NONE
resource PWM 5 NONE
resource PWM 6 NONE
resource PWM 7 NONE
resource PWM 8 NONE
resource LED 1 B05
resource LED 2 B04
resource LED 3 NONE
# mixer
mixer QUADX
# servo
# servo mix
smix reset
feature -OSD
feature -AIRMODE
feature -RX_SPI
feature -SOFTSPI
feature -ESC_SENSOR
feature RX_SERIAL
feature TELEMETRY
feature OSD
# beeper
beeper RX_LOST
beeper DISARMING
beeper ARMING
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper READY_BEEP
beeper MULTI_BEEPS
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
beeper CRASH FLIP
# beacon
beacon -RX_LOST
beacon DISARMING
beacon ARMING
beacon BAT_CRIT_LOW
beacon BAT_LOW
beacon GPS_STATUS
beacon -RX_SET
beacon READY_BEEP
beacon MULTI_BEEPS
beacon ARMED
beacon SYSTEM_INIT
beacon ON_USB
beacon CRASH FLIP
# map
map TAER1234
serial 5 64 115200 57600 0 115200
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 0 0 0 1750 2025 0 0
# adjrange
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# vtx
vtx 0 0 0 0 900 900
vtx 1 0 0 0 900 900
vtx 2 0 0 0 900 900
vtx 3 0 0 0 900 900
vtx 4 0 0 0 900 900
vtx 5 0 0 0 900 900
vtx 6 0 0 0 900 900
vtx 7 0 0 0 900 900
vtx 8 0 0 0 900 900
vtx 9 0 0 0 900 900
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# master
set acc_lpf_hz = 10
set rssi_offset = 0
set adc_device = 1
set ibatv_scale = 0
set beeper_od = OFF
set small_angle = 180
set deadband = 0
set osd_tim1 = 2560
set osd_tim2 = 2561
set osd_ah_pos = 78
set vtx_band = 5
set vtx_channel = 3
set vtx_power = 1
set vtx_freq = 5732
# profile
set acc_limit = 0
set crash_delay = 0
set p_pitch = 28
set i_pitch = 22
set d_pitch = 17
set f_pitch = 78
set p_roll = 22
set i_roll = 22
set d_roll = 19
set f_roll = 78
set p_yaw = 23
set i_yaw = 30
set d_yaw = 18
set f_yaw = 81
set p_level = 36
set i_level = 35
set d_level = 0
# rateprofile
set thr_mid = 50
set thr_expo = 0
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set yaw_srate = 70
set tpa_rate = 35
#diff all
diff all
manufacturer_id
mcu_id 00360023534d501720313447
signature
defaults nosave
# name
name diatone
# resources
# mixer
# servo
# servo mix
feature TELEMETRY
# beeper
# beacon
# map
map TAER1234
# color
# mode_color
# adjrange
# rxrange
# vtx
# rxfail
# master
set vtx_band = 5
set vtx_channel = 3
set vtx_freq = 5732
# profile
set p_pitch = 28
set i_pitch = 22
set d_pitch = 17
set f_pitch = 78
set p_roll = 22
set i_roll = 22
set d_roll = 19
set f_roll = 78
set p_yaw = 23
set i_yaw = 30
set d_yaw = 18
set f_yaw = 81
set p_level = 36
set i_level = 35
set d_level = 0
# profile
profile 1
# profile
profile 2
# rateprofile
set tpa_rate = 35
# rateprofile
rateprofile 1
# rateprofile
rateprofile 2
# rateprofile
rateprofile 3
# rateprofile
rateprofile 4
# rateprofile
rateprofile 5
# save configuration
save
Youtube
Please post a photo of your wiring between the Crossfire Nano RX and the Mamba F405 FC.
(03-May-2020, 03:24 PM)SnowLeopardFPV Wrote: Please post a photo of your wiring between the Crossfire Nano RX and the Mamba F405 FC.
Hey SnowLeopardFPV,
I have Channel 1= Yellow wire connected to RX6
I have Channel 2= Green wire connected to TX6
1
2
above are pictures.
Does that help ?
Youtube
OK. Wiring looks OK, as do the Betaflight settings. I will take your word for it where the other end of the yellow and green wires connect to the Mamba F405. Your description for those are correct. Just check that you don't have any short circuits on the UART pads (solder balls or other debris that might be causing cross-contamination).
What version of the firmware are you running on your Crossfire Module and the Nano RX?
Can you please also run the Crossfire LUA Script on your transmitter and check that Channels 1 & 2 are set to "CRSF TX" and "CRSF RX" respectively in case something inadvertently got messed up. In fact, if you look at the following post, you can check if your Nano RX is configured with all the default settings...
https://intofpv.com/t-x9d?pid=84697#pid84697
Thank you Snow i will work through this and report back, many thanks.
Youtube
(03-May-2020, 05:44 PM)SnowLeopardFPV Wrote: OK. Wiring looks OK, as do the Betaflight settings. I will take your word for it where the other end of the yellow and green wires connect to the Mamba F405. Your description for those are correct. Just check that you don't have any short circuits on the UART pads (solder balls or other debris that might be causing cross-contamination).
Both Transmitter and receiver are using v3.23
I have confirmed channels are correct and have default settings like in the above post soldering looks ok.
Apart from setting the receiver back to defaults im at a loss  Cry
Youtube
Next things to try are another UART first, and if that doesn't work then re-flash the Betaflight firmware ensuring that the "Full chip erase" setting is switch on.
(04-May-2020, 10:00 AM)SnowLeopardFPV Wrote: Next things to try are another UART first, and if that doesn't work then re-flash the Betaflight firmware ensuring that the "Full chip erase" setting is switch on.
Thanks
Ok i will re solder to uart3 when i return from work.
@SnowLeopardFPV
looking at this diagram MAMBA STACK
I notice their are two pads labeled RX6 I have wired to the one on the back of the board, I wonder if i should have used the other RX6 pad on the front of the board and after closer inspection it seems the only uart available to me is uart6 as uart 3 is in use for Runcam camera, Am I correct ?
Youtube
(04-May-2020, 03:59 PM)sircolin Wrote: looking at this diagram MAMBA STACK
Bingo! That's probably why your Nano RX isn't working on UART6.
I assume you have a Mamba 4in1 ESC connected to the FC via an 8-wire harness (?) RX6 is used for ESC telemetry data from the ESC and although you don't have ESC telemetry explicitly switched on in Betaflight Configurator for the UART6 port, there will be some communication "talk" on the RX6 connection from the ESC that will be interfering with the data on the same RX6 connection that Crossfire Nano RX receiver is connected to.
So, either move your Nano TX to another UART, or remove the ESC telemetry wire from the wiring harness that goes between the ESC board and the FC if you don't care about ESC telemetry. That should then (hopefully) resolve your issue.
  • sircolin
(04-May-2020, 04:53 PM)SnowLeopardFPV Wrote: Bingo! That's probably why your Nano RX isn't working on UART6.
Yes The specs say it has a 25A all in one ESC i can do without esc telemetry so i will try this evening to remove a pin from the harness and see if it resolves things, I had a funny feeling something else was at play here.
Thanks for your time SnowLeopardFPV, I will of course update this tread.
Youtube
Ok So I've returned Home from a 14 hours shift at work and cut the wire i was unable to see the pin let alone remove it but a found a spare harness in the spares bag (I'm a Fiber Optic Engineer / Telecoms Engineer by trade and it goes again everything in my moral being to cut any cable (free the cables man! :-) )
but i cut the wrong wire lucky for me i was able to flip the cable over phww.
In any case my receiver is now receiving inputs from my transmitter amazing stuff.
Thanks for all your help once again, I'm not sure how many times I've already said that in the past in other posts.
It be great to buy you a coffee for your help or maybe donate a little to the forum upkeep can we do that here ?
you be pleased to know my next quad is pnp lol
Once again thanks
Youtube
Great news. As long as you stick to cutting the wrong wires on your quad by mistake and not my fibre optic internet connection then I'll be happy Big Grin
PNP quads Whistling Like we never have to deal with any issues for those on here Thinking Just please don't get an iFlight one with their F405 FC in it Dodgy
#15
advanced F4 flight controller to the powerful 12A 4-in-1 ESC, this stack has everything you need to push your micro racing quad to its absolute limit.
Don't forget there's a 200mW VTX on-board as well, and still just 8.8g for the whole stack.
But it sounds sooo gooood. ;-)
Well For one your be Happy is a Standard crossfired Larva X and I've had this one before, If it don't work it will be getting sent back! :-)
and for two i install capacity and only unplug fibers so your digital life safe with me ;-)
Have a Nice Evening.
Col
Youtube
  Binding Problems with my Meteor75 to my RadioMaster Zorro 4-1 TxFlyer 4 877 10-Dec-2023, 06:38 AM
Last Post: brettbrandon
  Tiny Whoop Arming Problems segler999 19 2,074 03-Nov-2023, 04:09 AM
Last Post: segler999
  Help New in the Hobby - Problems binding Meteor65 pro 2022 ELRS homemcoisa 35 2,806 21-Jun-2023, 09:27 PM
  Meteor 65 2022 Crossfire FW version issues reinholds 4 592 26-Apr-2023, 04:48 PM
Last Post: reinholds
  Help Meteor 75 crossfire problems Ditty_FPV 19 2,300 14-Aug-2022, 01:44 PM
Last Post: Shellodan
