Threads: 6
Likes Received: 0 in 0 posts
0 I have a BetaFPV Meteor75 Micro and trying to get it setup into my RadioMaster Zorro 4-1 but cannot get it to Bind....im showing the receiver as an FRSKY_D, unless that is not correct?
Thanks for any help!
Threads: 125
Likes Given: 99
388 There are a few versions of the Meteor75. I am not sure how to tell them apart. Anyways, if you have the Frsky SPI version of the drone, you can actually pick the Frsky D or Frsky X protocol from BFC.
There is also the ELRS and TBS Crossfire version of this drone, which will not work with your radio internal built-in protocols. Unless you get the external module.
Threads: 6
0 10-Dec-2023, 05:55 AM (This post was last modified: 10-Dec-2023, 06:05 AM by TxFlyer.) ell I just received my new BetaFPV F4 1S SA Flight Controller / SPI Frsky board yesterday and have been trying to get it to bind to my RadioMaster Zorro 4-1 BUT still have not had any luck.....has anyone else been able to bind this FC with out having to use a BetaFPV module?
Here are the specs to the new FC.
Meteor75 / New FC:
F4 1S 5A AIO Brushless Flight Controller (SPI Frsky -V2.0 ) BMI270
version
# Betaflight / STM32F411 (S411) 4.2.11 Sep 29 2022 / 16:54:16 (norevision) MSP API: 1.43
board_name BETAFPVF411RX
manufacturer_id BEFH
I have attached a screen shot from BetaFlight:
Threads: 19
Likes Received: 604 in 416 posts
Likes Given: 755
31 How are you setting the quad up for bind? Being that it is a SPI FrSky, you should be able to put the quad into bind mode using the phrase "bind_rx" in the CLI in Betaflight. One more thing to remember about FrSky is that they changed their protocol awhile back from ACCST to ACCESS. The TX from one will not bind with the RX from the other.
