07-Mar-2021, 08:14 AM
Hello,
I am totaly new to this hobby.. bough tinyhawk 2 and had lot of fun. Next I bought Taycan Diaton with mamba f405DJI MINI FC planned to use the goggles and radio from tiny hawks. So got together with mamba the reciever "EMAX Tiny 2.4GHz 8CH Mini SBUS Output RC Receiver Compatible FrSky D8".That should be only combination that would work with tinyhawks radio.
So when everything arrived I solder the Emax reciever to the free wires which were for R-XSR. I was able to bind the radio with reciever. But in Betaflight I am unable to switch reciever to SPI RX and Frsky_D. Do you know why ? Attached picutre where it is soldered. I think it should go somewhere else or settings in betaflight should be different
Side note.. when I was at begginig playing with settings I didn´t backup the betaflight and accidently restore default settings, so I copy settings from Joshua Bardwel. If anyone have settings backup can you share it with me ?
And it is normal that VTX board Mamba is going extremly hot when connectedt to PC and battery ?
Plan B is to buy R-XSR and Radiomaster TX12 .. do you think it will work or any better alternative.. I would prefer smaller radio.
Thank you in advance... hope next time I will not have such a noob questions.
