Threads: 18
Likes Received: 6 in 3 posts
Likes Given: 10
0 Has anyone here used a Cricut machine to cut carbon fiber? I have access to that and a ShopBot, but I am trying to determine whether the ShopBot, which has much more expensive cutting tools, is my only option.
Additionally, does anyone happen to have STL files for a Diatone Taycan MX-C 3.0 upper and lower arm by chance? I found a lower on STL finder, but not an upper. I might be able to edit the lower arm STL to work, but I'd really rather just find one someone already made, you know?
Threads: 18
Likes Given: 10
0 The carbon fiber for the Taycans is 2.5mm. I read online that people were able to cut that thickness with Cricut. I'd prefer the ShopBot, but those diamond cutters are EXPENSIVE and I figured I'd check my options.
Threads: 18
Likes Given: 10
0 Yeah, I've got a bath set up for under water cutting, and will double the risk management by not allowing students into the room until well after the CNC is done. Mostly, I just want to try this at this point. I actually found the frame pieces on Diatone's website for $12, it would not be worth the effort and set up for that cost.
Threads: 392
Likes Received: 3,231 in 1,827 posts
Likes Given: 3,214
101 Unless you also like to spend your spare time giving yourself paper cuts and pouring lemon juice on it, I'd spend your resources on finding a good shop to cut the CF for you. The go-to guy is CNC Madness in Canada.
