Computer dosen't recognize usb
I have tryied three computers with  my wizard 220x none of them recognize the usb port when I go to options then  devises in the Zadig driver installer .
 My question is why would it not be recognized on three difrent computers. I have a dedicated data cord for the drone and computer . I bought another just to be sure .
 still the computers don't recognize it .
 Thanks for any feedback. This is getting very frustrating .
 Fisher King
Check impulserc driver fixer, otherwise open zadig, hold boot button before powering on through usb and see if you can reflash.
I believe wizard use spf3 fc. You only need cp210x driver. Zadig is the incorrect driver.
  • Fisherking
Good catch voodoo, thank you
Similar problem on my bardwell fc can’t get it up to speed with newest bf.
damn, i'm embarrassed... this nearly identical to the post i just put up. i promise to never again post prior to making sure the topic isn't already being discussed if no one rakes me over the coals for doing exactly what the forum guidelines (and forum members) ask people not to do... sorry Sad
(01-Jul-2018, 04:26 AM)beelzebait Wrote: damn, i'm embarrassed... this nearly identical to the post i just put up. i promise to never again post prior to making sure the topic isn't already being discussed if no one rakes me over the coals for doing exactly what the forum guidelines (and forum members) ask people not to do... sorry Sad
Although they seems to be similar questions, the answer is different because your FC uses different driver to the SPF3. I asked a question in your thread, can you go there and give me an answer.
try unplugging the rx and running impulserc fixer without the rx.
i just had a similar issue, turns out for some reason my rx was a second thing trying to connect, after unplugging that, everything worked, more or less.
i still have to use impluserc, and still can only get it typing bl into cli, but it does work...
[-] The following 1 user Likes Jakefpv's post:
  • Fisherking
I tried the boards unconnected from everything. not sure if I tried it unplugged with the impulse driver .
I will have to try
[-] The following 1 user Likes Fisherking's post:
  • Jakefpv
Yes unplug the rx and then run impulse driver.
  Trouble connecting taranis X-lite pro to Win 11 USB skipSSnova 7 2,308 05-May-2024, 05:46 PM
Last Post: BadRaven
  GPS warmup with USB powerbank before flight Roy Maas 6 602 17-Sep-2023, 01:49 PM
Last Post: Cyberess
  USB data intermittent or no connection jokhm 5 203 15-Sep-2023, 04:34 AM
Last Post: Lemonyleprosy
  computer minimum? FromTheSky 10 1,077 27-Mar-2023, 12:16 PM
Last Post: nigelz
  Tinyhawk Freestyle 2: FC only powers up via USB, not by battery maison_m 1 302 04-Jan-2023, 06:39 PM
