Threads: 33
Likes Received: 17 in 15 posts
Likes Given: 172
2 I have tryied three computers with my wizard 220x none of them recognize the usb port when I go to options then devises in the Zadig driver installer .
My question is why would it not be recognized on three difrent computers. I have a dedicated data cord for the drone and computer . I bought another just to be sure .
still the computers don't recognize it .
Thanks for any feedback. This is getting very frustrating .
Fisher King
Threads: 4
Likes Received: 52 in 47 posts
Likes Given: 88
5 Check impulserc driver fixer, otherwise open zadig, hold boot button before powering on through usb and see if you can reflash.
Threads: 125
Likes Given: 99
388 I believe wizard use spf3 fc. You only need cp210x driver. Zadig is the incorrect driver.
Threads: 4
Likes Given: 88
5 Good catch voodoo, thank you
Threads: 42
Likes Received: 90 in 64 posts
Likes Given: 184
3 Similar problem on my bardwell fc can’t get it up to speed with newest bf.
Threads: 42
Likes Given: 184
3 try unplugging the rx and running impulserc fixer without the rx.
i just had a similar issue, turns out for some reason my rx was a second thing trying to connect, after unplugging that, everything worked, more or less.
i still have to use impluserc, and still can only get it typing bl into cli, but it does work...
Threads: 33
Likes Given: 172
2 I tried the boards unconnected from everything. not sure if I tried it unplugged with the impulse driver .
I will have to try
Threads: 42
Likes Given: 184
3 Yes unplug the rx and then run impulse driver.
