CLI dump for the DarwinFPV 18650 3inch
Review: https://oscarliang.com/darwinfpv-18650-3inch/
# Betaflight / STM32F411 (S411) 4.2.5 Nov 22 2020 / 18:38:45 (afdac08b3) MSP API: 1.43
# config: YES
# start the command batch
batch start
defaults nosave
board_name MATEKF411
manufacturer_id MTKS
mcu_id 006200274e56500220363955
signature
# name: DarwinFPV
feature LED_STRIP
# beacon
beacon RX_SET
serial 1 2048 115200 57600 0 115200
led 0 9,5::CB:4
aux 0 0 0 1700 2100 0 0
aux 1 1 1 1700 2100 0 0
aux 2 13 2 1700 2100 0 0
# vtxtable
vtxtable bands 6
vtxtable channels 8
vtxtable band 3 BOSCAM_E E FACTORY 5705 5685 5665    0 5885 5905    0    0
vtxtable band 6 IMD6     I CUSTOM  5732 5765 5828 5840 5866 5740    0    0
vtxtable powerlevels 3
vtxtable powervalues 0 1 2
vtxtable powerlabels 25 100 200
# master
set acc_calibration = -11,40,-59,1
set min_check = 1100
set blackbox_device = NONE
set dshot_idle_value = 300
set motor_poles = 12
set current_meter = NONE
set beeper_dshot_beacon_tone = 3
set vtx_band = 4
set vtx_channel = 1
set vtx_power = 3
set vtx_freq = 5740
set gyro_1_align_yaw = 1800
set name = DarwinFPV
profile 1
profile 2
rateprofile 1
rateprofile 2
rateprofile 3
rateprofile 4
rateprofile 5
# save configuration
save
  • hugnosed_bat
for which one?
will there come a review from you? :-)
(11-Aug-2021, 12:06 PM)hugnosed_bat Wrote: for which one?
The 18650 3inch Smile
Just published it.
  • hugnosed_bat
i know three pnps from darwin fpv next to that 1s-rangequad. the darwin 69 / 79 and the 129, all of them are with eachine parts, mostly the same parts like on the simular eachine tyro series. the boards look the same but they are rated differently. darwin boards are rated higher, this seems a cheat to me? wrong?
all electronics seems from eachines kitchen, only the frame of the darwin69/79 is different. i tried to find the 1-3s board in another eachine product but couldnt. im curious if the rating of 15a are the truth Undecided
does darwin fpv truly build bythemself or just buy low priced stuff still available and cheat on the ratings?
  Data Original CLI Dump for DarwinFPV Darwin129 Oscar 1 1,107 06-Apr-2023, 11:54 PM
Last Post: Oscar
  CLI Dump for Flywoo Hexplorer LR4 (Hexacopter) Oscar 2 1,928 08-Sep-2021, 11:58 AM
Last Post: kafie1980
  Tip & Trick Li-Ion 18650 Batteries and Low Voltage Cutoff iFly4rotors 54 11,027 04-Jun-2021, 11:41 AM
Last Post: iFly4rotors
  Build 1S 18650 NanoLongRange V-22 106 14,614 26-Apr-2021, 07:32 PM
Last Post: Kowalski4711
  CLI Dump from Flywoo Explorer LR Oscar 0 10,792 15-Aug-2020, 09:33 AM
Last Post: Oscar
