Cineon C30 fall of the sky when doing rapid throttle move
Hey,
I build a Cineon C30 6S using betaflight 4.4
Everything works fine except when I move the throttle rapidly, the quad falls of the sky.
I have a capacitor of 470uF connected to the VCC input.
When i run each motor in the motor tab of betaflight i have no error.
I flashed bluejay and use RPM filter.
I was thinking of a esc desyn but when i look the log i'm not so sure, it's that
[Image: j4q8nQOl.jpg]
I don't have a clue and i don't know what to do. If someone can help me?
Thank you
Attached Files Thumbnail(s)
.zip   log.zip (Size: 592.42 KB / Downloads: 33)
I’ll try to remember to take a look at your log later tonight when I have the time, but it certainly sounds like a desync.
I’d suggest-
On the pid tuning tab in betaflight, set Dynamic Idle Min to 34.
On esc-configurator, decrease your startup/ramp up power and set demag compensation to high.
Take it for a flight, do some hard throttle movements, see if it fixes it.
If it doesn’t, try rolling back to Bluejay v0.16. There’s been some reports of the later versions of bluejay causing desyncs on some esc’s.
If that still doesn’t fix it, try disabling bidirectional dshot. It means that you won’t be able to use rpm filter or dynamic idle, but I’ve come across a few boards that have weird issues with bidirectional dshot.
Edit- another thing to try is either lower pitch props, or props with less blades. In my experience, most of my desyncs have been caused by overpropping- when the motor just can’t spin the prop up fast enough.
Edit edit- I initially said increase your startup power, but that’s not correct. You want to decrease it. I always get that backwards.
Dangerous operations.
(03-Jun-2023, 07:38 PM)Lemonyleprosy Wrote: I’ll try to remember to take a look at your log later tonight when I have the time, but it certainly sounds like a desync.
I’d suggest-
Thanks Lemonyleprosy,
I set Dynamic Idle to 34, changed minimum Startup Power from 1025 to 1010 and demag compensation to HIGH. I will test it tomorrow morning.
[Image: 65rbOzzl.png]
Is it normal that there is a gap in the log ?
When it comes to blackbox logs, I still consider myself a beginner, so keep that in mind.
Gaps can happen. You can increase your blackbox logging rate, and that should help get rid of the gaps, but, increasing your logging rate will increase the amount of memory used by the log (not a problem if you’re using an sd card, but if you’re using an onboard flash based blackbox logger, it might be), and it can increase your cpu load (not likely a problem if your using an f7/h7 fc).
I set Dynamic Idle to 34, changed minimum Startup Power from 1025 to 1010 and demag compensation to HIGH and know i don't have desync when doing small throttle move. But when i'm doing big throttle move i have something motor desync.
Should i reduce a little more minimum Startup Power?
Yup, you can go lower.
If your motors start struggling to spin up when you arm, you’ll know that you’ve gone too low.
  Quad fall of the sky when doing small throttle move Snyfir 11 842 09-Sep-2023, 10:28 PM
  “Floaty” drop throttle not responding issue Rob Axel 0 272 13-Jan-2023, 03:06 PM
  High KV motor with 6s Pack and Throttle Limit thrasher7811 14 9,468 22-Aug-2022, 07:15 AM
Last Post: romangpro
  Help Podracer build oscillating into the sky Sean Cleary 5 439 16-Jun-2022, 10:37 PM
  New GEPRC Smart 35 fell out from the sky without any apparent reason albertly 6 544 15-Jun-2022, 12:28 AM
Last Post: kafie1980
