Threads: 1
Likes Received: 0 in 0 posts
0 I cant give gas its locked when i disarm it, i cant figure it out its probably very easy, can someone help me?
I am new to the fpv drones i have am wizard x220s and a flysky i6x radio
Threads: 172
Likes Given: 4,753
103 i would conect to betaflight configurator, watch if you have movement on the throttle.
if the throttle moves normaly as it should, type "status" into the cli tab and post it here.
both with a conected battery and transmitter on.
Threads: 1
0 I did everything what you said, and yes my throttle was going up in betaflight, i types status in the cli but what do i do next?
Threads: 1
0 I disarmed my drone now the motors are spinning just good everything works but, if i want to give gas the throttle does nothing
Is this for safety maybe? So that you need to unlock your throttle
Threads: 172
Likes Given: 4,753
103 if you post the text you get by type status, there would be any the arming prevention information.
as you can arm it, get spining props, it wont be helpfull.
there shouldnt be any safty feature for throttle after arming.
i dont have ideas, what could that be?
did it fly befor or is the issue for your first flight?
do you use dshot as motorprotocoll?
can you spin up the motors in betaflight motortab (without props)?
"diff all" and "dump" would display all your settings and changes, you can post it here
