  • 2 Vote(s) - 3 Average
BF10.5.1 weirdness with Mobula7
First off I see no issues with the Mobula it flies great. I just wanted to change one of my switches.
So I connected the Mobula to BF  and noticed an odd flag in "Arming disable flags"    " Paralyze  "
[Image: 6tHYndll.jpg]
I then went to the config tab and there was red text that said " no gyro/acc found " but it was showing up above as connected.
[Image: p6sFBQrl.jpg]
And on the opening page, the on screen model was responding to me moving the quad as I would expect it to respond.
The OSD page would not populate
[Image: E8g5XlNl.jpg]
And neither would the Modes page, in fact it then freezes and nothing else works except "disconnect"
[Image: b9QJhZgl.jpg]
The CLI works fine.
All my other quads seem to connect fine and all pages are useable. I thought it may be something odd with this early version of BF4.0 they used on the Mobula so I hooked it up to my laptop which still has BF 10.4 on it. Everything works fine, all tabs are accessible.
So I thought I would update the laptop to 10.5.1 and see if a fresh version would do it , nope. All the same problems.
I gave a quick look on github and did not see anything like this.
Has anyone heard of issues like this ?  Or should I just rollback the laptop to 10.4 for the Mobula ?
Thanks
Scott
[-] The following 1 user Likes Scott_M's post:
  • man_per31
There are known issues with early versions of BF4.0 (prior to the final release) and the 10.5.x Betaflight Configurator exactly like what you are seeing. I suggest you upgrade to the latest release version of BF4.0. In fact BF4.0.1 is now out so just flash that.
Obviously, don't forget to take a dump backup of your current settings.
Thanks Snow
I thought I read somewhere that you shouldn't switch versions on the Mobula. I know it had issues with 3.5.1. The 4.0 it is on has really high cpu load but it doesn't seem to affect it. I tried finding where I read that but it escapes me. I thought it was on Happy Model's website but I can't find it now.
I can't say for certain but I think I have used 10.5.1 before with it. It may have been CLI only though.
I guess with a dump and diff it wouldn't hurt to try. I think 4.0.2 will be out soon. I am not really having any issues so I may wait for the newer version.
Scott
I can't answer your question about not upgrading from the factory loaded BF4.0 version but there were quite a few changes from the earlier pre-release Betaflight 4.0 versions until when the final 4.0 version was released, some of them to do with the way the tuning is coded and works.
I know people have had issues with the release version of BF4.0 being different to the factory installed pre-release version on the Trashcan and they have had to bin the factory applied tuning and redo it from scratch. I haven't hit that issue yet because mine is still in pieces so I haven't flown it since BF4.0 final was released.
Below is a link to the compatibility issue with the pre-release BF4.0 versions and BFC10.5.x. While the issue specifically mentions the Modes tab, the underlying issue also affects other parts of the BFC as well.
https://github.com/betaflight/betaflight...ssues/1335
Thanks for that link, I looked for quite awhile this morning and did not find that. That sure sounds like the same issue.
I think it is odd I have not noticed it until now.
This is why I will wait for 4.0.2  https://github.com/betaflight/betaflight/releases
[Image: POsynELl.jpg]
Scott
(04-May-2019, 10:32 PM)Scott_M Wrote: This is why I will wait for 4.0.2  https://github.com/betaflight/betaflight/releases
Scott
Oh yes, of course. The Mobula 7 came with an F3 flight controller. I totally forgot about that. There is still nothing to stop you applying the final release of 4.0.0 if you wish which will (should) fix the issue, but I'm guessing 4.0.2 will be out within the next week with a bug as serious as that present in 4.0.1.
Hello,
First off, be aware that I’m a total noob who just got my first fpv whoop, mobula 7 v2. Paid a few bucks extra to have it setup and binded to a flysky fs-i6s.
Been stuck with a problem and after a few hours of reading, searching, and learning, still no answer but came across this thread and I’m having the exact same issue as the original poster.... was flying good then suddenly stopped arming. A few small crashes but nothing major and now it won’t arm.
I downloaded beta flight 10.6 and hooked it up and see that the paralyze flag is preventing arming. It says the solution is to reset the fc by power cycling it but I don’t know how to do that.... I know, total noob right? I know what a power cycle is but not how to do it with my fc. I tried everything I could think of..... plug in the battery, not arming. Disconnect, replug, still no. Plug in usb for power, unplug, still nothing. BF still shows paralyze flag....
Need some help here please.... if u need anymore info let me know but like I said, assume I’m a noob who doesn’t know anything....
Thanks
Can you type "version" in CLI and tell me what version of betaflight you have? If it is 4.0 then it could be a pre-lease firmware and it has some bugs. You want to make a dump and then update the firmware and restore all your settings.
Can you post a dump here first?
# diff all
# Betaflight / CRAZYBEEF4FS (C4FS) 4.0.0 Dec 11 2018 / 01:08:39 (3b479f92d) MSP API: 1.41
board_name CRAZYBEEF4FS
manufacturer_id
mcu_id 004700173437511430353933
signature
defaults nosave
# name
# resources
# servo
# servo mix
# beeper
# beacon
# color
# mode_color
# rxrange
# vtx
# rxfail
# master
# profile
# profile
profile 1
# profile
profile 2
# rateprofile
# rateprofile
rateprofile 1
# rateprofile
rateprofile 2
# rateprofile
rateprofile 3
# rateprofile
rateprofile 4
# rateprofile
rateprofile 5
# save configuration
save
# dump
manufacturer_id
# name
name -
# resources
resource BEEPER 1 C15
resource MOTOR 1 B10
resource MOTOR 2 B06
resource MOTOR 3 B07
resource MOTOR 4 B08
resource MOTOR 5 NONE
resource MOTOR 6 NONE
resource MOTOR 7 NONE
resource MOTOR 8 NONE
resource SERVO 1 NONE
resource SERVO 2 NONE
resource SERVO 3 NONE
resource SERVO 4 NONE
resource SERVO 5 NONE
resource SERVO 6 NONE
resource SERVO 7 NONE
resource SERVO 8 NONE
resource PPM 1 A03
resource PWM 1 A02
resource PWM 2 A09
resource PWM 3 A10
resource PWM 4 NONE
resource PWM 5 NONE
resource PWM 6 NONE
resource PWM 7 NONE
resource PWM 8 NONE
resource LED_STRIP 1 A00
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 A02
resource SERIAL_TX 3 NONE
resource SERIAL_TX 4 NONE
resource SERIAL_TX 5 NONE
resource SERIAL_TX 6 NONE
resource SERIAL_TX 7 NONE
resource SERIAL_TX 8 NONE
resource SERIAL_TX 9 NONE
resource SERIAL_TX 10 NONE
resource SERIAL_TX 11 NONE
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 A03
resource SERIAL_RX 3 NONE
resource SERIAL_RX 4 NONE
resource SERIAL_RX 5 NONE
resource SERIAL_RX 6 NONE
resource SERIAL_RX 7 NONE
resource SERIAL_RX 8 NONE
resource SERIAL_RX 9 NONE
resource SERIAL_RX 10 NONE
resource SERIAL_RX 11 NONE
resource LED 1 C13
resource LED 2 NONE
resource LED 3 NONE
resource RX_BIND 1 NONE
resource RX_BIND_PLUG 1 B02
resource SPI_SCK 1 A05
resource SPI_SCK 2 B13
resource SPI_SCK 3 B03
resource SPI_MISO 1 A06
resource SPI_MISO 2 B14
resource SPI_MISO 3 B04
resource SPI_MOSI 1 A07
resource SPI_MOSI 2 B15
resource SPI_MOSI 3 B05
resource ESCSERIAL 1 NONE
resource ADC_BATT 1 B00
resource ADC_RSSI 1 NONE
resource ADC_CURR 1 B01
resource ADC_EXT 1 NONE
resource PINIO 1 NONE
resource PINIO 2 NONE
resource PINIO 3 NONE
resource PINIO 4 NONE
resource OSD_CS 1 B12
resource SPI_PREINIT_IPU 1 A04
resource SPI_PREINIT_IPU 2 NONE
resource SPI_PREINIT_IPU 3 A15
resource SPI_PREINIT_IPU 4 B12
resource SPI_PREINIT_IPU 5 NONE
resource SPI_PREINIT_IPU 6 NONE
resource SPI_PREINIT_IPU 7 NONE
resource SPI_PREINIT_IPU 8 NONE
resource SPI_PREINIT_IPU 9 NONE
resource SPI_PREINIT_IPU 10 NONE
resource SPI_PREINIT_IPU 11 NONE
resource SPI_PREINIT_OPU 1 NONE
resource SPI_PREINIT_OPU 2 NONE
resource RX_SPI_CS 1 A15
resource GYRO_EXTI 1 A01
resource GYRO_EXTI 2 NONE
resource GYRO_CS 1 A04
resource GYRO_CS 2 NONE
# servo
servo 0 1000 2000 1500 100 -1
servo 1 1000 2000 1500 100 -1
servo 2 1000 2000 1500 100 -1
servo 3 1000 2000 1500 100 -1
servo 4 1000 2000 1500 100 -1
servo 5 1000 2000 1500 100 -1
servo 6 1000 2000 1500 100 -1
servo 7 1000 2000 1500 100 -1
# servo mix
smix reset
feature -RANGEFINDER
feature -OSD
feature -TRANSPONDER
feature -AIRMODE
feature -RX_SPI
feature -SOFTSPI
feature -ESC_SENSOR
feature -ANTI_GRAVITY
feature -DYNAMIC_FILTER
feature TELEMETRY
feature OSD
feature RX_SPI
feature ANTI_GRAVITY
feature DYNAMIC_FILTER
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
beeper BLACKBOX_ERASE
beeper CRASH_FLIP
beeper CAM_CONNECTION_OPEN
beeper CAM_CONNECTION_CLOSE
beeper RC_SMOOTHING_INIT_FAIL
# beacon
beacon GYRO_CALIBRATED
beacon -RX_LOST
beacon RX_LOST_LANDING
beacon DISARMING
beacon ARMING
beacon ARMING_GPS_FIX
beacon BAT_CRIT_LOW
beacon BAT_LOW
beacon GPS_STATUS
beacon -RX_SET
beacon ACC_CALIBRATION
beacon ACC_CALIBRATION_FAIL
beacon READY_BEEP
beacon MULTI_BEEPS
beacon DISARM_REPEAT
beacon ARMED
beacon SYSTEM_INIT
beacon ON_USB
beacon BLACKBOX_ERASE
beacon CRASH_FLIP
beacon CAM_CONNECTION_OPEN
beacon CAM_CONNECTION_CLOSE
beacon RC_SMOOTHING_INIT_FAIL
map AETR1234
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 0 0 0 900 900 0 0
aux 1 0 0 900 900 0 0
aux 2 0 0 900 900 0 0
aux 3 0 0 900 900 0 0
aux 4 0 0 900 900 0 0
aux 5 0 0 900 900 0 0
aux 6 0 0 900 900 0 0
aux 7 0 0 900 900 0 0
aux 8 0 0 900 900 0 0
aux 9 0 0 900 900 0 0
aux 10 0 0 900 900 0 0
aux 11 0 0 900 900 0 0
aux 12 0 0 900 900 0 0
aux 13 0 0 900 900 0 0
aux 14 0 0 900 900 0 0
aux 15 0 0 900 900 0 0
aux 16 0 0 900 900 0 0
aux 17 0 0 900 900 0 0
aux 18 0 0 900 900 0 0
aux 19 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# vtx
vtx 0 0 0 0 900 900
vtx 1 0 0 0 900 900
vtx 2 0 0 0 900 900
vtx 3 0 0 0 900 900
vtx 4 0 0 0 900 900
vtx 5 0 0 0 900 900
vtx 6 0 0 0 900 900
vtx 7 0 0 0 900 900
vtx 8 0 0 0 900 900
vtx 9 0 0 0 900 900
# rxfail
rxfail 3 a
rxfail 5 h
# master
set align_gyro = DEFAULT
set gyro_sync_denom = 1
set gyro_lowpass_type = PT1
set gyro_lowpass_hz = 100
set gyro_lowpass2_type = PT1
set gyro_lowpass2_hz = 300
set gyro_notch1_hz = 0
set gyro_notch1_cutoff = 0
set gyro_notch2_hz = 0
set gyro_notch2_cutoff = 0
set gyro_calib_duration = 125
set gyro_offset_yaw = 0
set yaw_spin_recovery = ON
set yaw_spin_threshold = 1950
set gyro_to_use = FIRST
set dyn_fft_location = AFTER_STATIC_FILTERS
set dyn_filter_width_percent = 40
set dyn_filter_range = MEDIUM
set align_acc = DEFAULT
set acc_hardware = AUTO
set acc_lpf_hz = 10
set acc_trim_pitch = 0
set acc_trim_roll = 0
set acc_calibration = 0,0,0
set min_check = 1050
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 100
set rssi_offset = 0
set rssi_invert = OFF
set rc_interp = AUTO
set rc_interp_ch = RPYT
set rc_interp_int = 19
set rc_smoothing_input_hz = 0
set fpv_mix_degrees = 0
set max_aux_channels = 14
set serialrx_inverted = OFF
set spektrum_sat_bind = 0
set serialrx_halfduplex = OFF
set rx_spi_protocol = FLYSKY_2A
set rx_spi_bus = 3
set adc_device = 1
set blackbox_p_ratio = 32
set blackbox_device = SERIAL
set blackbox_record_acc = ON
set blackbox_mode = NORMAL
set min_throttle = 1070
set max_throttle = 2000
set dshot_idle_value = 450
set dshot_burst = OFF
set use_unsynced_pwm = OFF
set motor_pwm_protocol = ONESHOT125
set motor_pwm_rate = 480
set motor_pwm_inversion = OFF
set motor_poles = 14
set thr_corr_value = 0
set thr_corr_angle = 800
set failsafe_delay = 4
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_procedure = DROP
set align_board_yaw = 0
set gimbal_mode = NORMAL
set bat_capacity = 0
set vbat_hysteresis = 1
set current_meter = ADC
set battery_meter = ADC
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set vbat_cutoff_percent = 100
set vbat_scale = 110
set vbat_divider = 10
set vbat_multiplier = 1
set ibata_scale = 179
set ibata_offset = 0
set ibatv_scale = 0
set ibatv_offset = 0
set beeper_inversion = ON
set beeper_od = OFF
set beeper_frequency = 0
set yaw_motors_reversed = OFF
set 3d_limit_low = 1000
set 3d_limit_high = 2000
set 3d_switched_mode = OFF
set servo_center_pulse = 1500
set servo_pwm_rate = 50
set servo_lowpass_hz = 0
set tri_unarmed_servo = ON
set small_angle = 25
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_rescue_angle = 32
set gps_rescue_yaw_p = 40
set gps_rescue_min_sats = 8
set gps_rescue_min_dth = 100
set deadband = 0
set yaw_deadband = 0
set pid_process_denom = 4
set tlm_inverted = OFF
set tlm_halfduplex = ON
set frsky_default_lat = 0
set frsky_default_long = 0
set frsky_gps_format = 0
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set hott_alarm_int = 5
set pid_in_tlm = OFF
set report_cell_voltage = OFF
set smartport_use_extra_sensors = OFF
set ledstrip_grb_rgb = GRB
set osd_units = METRIC
set osd_warn_crash_flip = ON
set osd_warn_esc_fail = ON
set osd_warn_core_temp = ON
set osd_warn_fail_safe = ON
set osd_rssi_alarm = 20
set osd_cap_alarm = 2200
set osd_alt_alarm = 100
set osd_esc_temp_alarm = -128
set osd_esc_rpm_alarm = -1
set osd_core_temp_alarm = 70
set osd_ah_max_pit = 20
set osd_ah_max_rol = 40
set osd_tim1 = 2560
set osd_tim2 = 2561
set osd_vbat_pos = 234
set osd_rssi_pos = 234
set osd_tim_1_pos = 234
set osd_tim_2_pos = 234
set osd_flymode_pos = 234
set osd_g_force_pos = 234
set osd_throttle_pos = 234
set osd_vtx_channel_pos = 234
set osd_crosshairs_pos = 205
set osd_ah_sbar_pos = 206
set osd_ah_pos = 78
set osd_current_pos = 234
set osd_mah_drawn_pos = 234
set osd_craft_name_pos = 234
set osd_gps_speed_pos = 234
set osd_gps_lon_pos = 234
set osd_gps_lat_pos = 234
set osd_gps_sats_pos = 234
set osd_home_dir_pos = 234
set osd_home_dist_pos = 234
set osd_compass_bar_pos = 234
set osd_altitude_pos = 234
set osd_pid_roll_pos = 234
set osd_pid_pitch_pos = 234
set osd_pid_yaw_pos = 234
set osd_debug_pos = 234
set osd_power_pos = 234
set osd_warnings_pos = 2377
set osd_pit_ang_pos = 234
set osd_rol_ang_pos = 234
set osd_disarmed_pos = 234
set osd_nheading_pos = 234
set osd_esc_tmp_pos = 234
set osd_esc_rpm_pos = 234
set osd_flip_arrow_pos = 234
set osd_core_temp_pos = 234
set osd_log_status_pos = 234
set osd_stat_tim_1 = OFF
set osd_stat_tim_2 = ON
set osd_stat_max_spd = ON
set osd_stat_max_dist = OFF
set osd_stat_min_batt = ON
set osd_stat_endbatt = OFF
set osd_stat_battery = OFF
set osd_stat_min_rssi = ON
set osd_stat_max_curr = ON
set osd_stat_used_mah = ON
set osd_stat_max_alt = OFF
set osd_stat_bbox = ON
set osd_stat_bb_no = ON
set task_statistics = ON
set debug_mode = NONE
set rate_6pos_switch = OFF
set cpu_overclock = OFF
set pwr_on_arm_grace = 5
set vtx_band = 4
set vtx_channel = 1
set vtx_power = 1
set vtx_freq = 5740
set vtx_pit_mode_freq = 0
set vtx_halfduplex = ON
set vcd_video_system = AUTO
set vcd_h_offset = 0
set vcd_v_offset = 0
set max7456_clock = DEFAULT
set max7456_spi_bus = 2
set led_inversion = 0
set pinio_config = 1,1,1,1
set usb_hid_cdc = OFF
set gyro_1_bustype = SPI
set gyro_1_spibus = 1
set gyro_1_i2cBus = 0
set gyro_1_i2c_address = 0
set gyro_1_sensor_align = CW90
set gyro_2_bustype = SPI
set gyro_2_spibus = 1
set gyro_2_i2cBus = 0
set gyro_2_i2c_address = 0
# profile
set dterm_lowpass_type = PT1
set dterm_lowpass_hz = 100
set dterm_lowpass2_hz = 200
set dterm_notch_hz = 0
set dterm_notch_cutoff = 0
set vbat_pid_gain = OFF
set pid_at_min_throttle = ON
set anti_gravity_gain = 5000
set acc_limit_yaw = 0
set acc_limit = 0
set crash_dthreshold = 50
set crash_gthreshold = 400
set crash_time = 500
set crash_delay = 0
set crash_recovery_angle = 10
set crash_recovery_rate = 100
set crash_limit_yaw = 200
set crash_recovery = OFF
set iterm_rotation = ON
set smart_feedforward = OFF
set iterm_relax = RP
set iterm_relax_cutoff = 11
set iterm_windup = 40
set iterm_limit = 300
set pidsum_limit = 500
set pidsum_limit_yaw = 400
set yaw_lowpass_hz = 0
set throttle_boost = 5
set acro_trainer_gain = 75
set p_pitch = 50
set i_pitch = 50
set d_pitch = 27
set f_pitch = 60
set p_roll = 46
set i_roll = 45
set d_roll = 25
set f_roll = 60
set p_yaw = 45
set i_yaw = 100
set d_yaw = 0
set f_yaw = 100
set angle_level_strength = 50
set horizon_transition = 75
set level_limit = 55
set horizon_tilt_effect = 75
set abs_control_gain = 0
set abs_control_limit = 90
# rateprofile
set thr_mid = 50
set thr_expo = 0
set rates_type = BETAFLIGHT
set roll_rc_rate = 100
set pitch_rc_rate = 100
set yaw_rc_rate = 100
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set pitch_srate = 70
set yaw_srate = 70
set tpa_rate = 10
set tpa_breakpoint = 1650
set throttle_limit_type = OFF
set roll_rate_limit = 1998
set pitch_rate_limit = 1998
set yaw_rate_limit = 1998
(27-Oct-2019, 10:26 AM)Hawaiigrown Wrote:
# diff all
manufacturer_id
signature
defaults nosave
# name
# resources
# servo
# servo mix
# beeper
# beacon
# color
# mode_color
# rxrange
# vtx
# rxfail
# master
# profile
# profile
profile 1
# profile
profile 2
# rateprofile
# rateprofile
rateprofile 1
# rateprofile
rateprofile 2
# rateprofile
rateprofile 3
# rateprofile
rateprofile 4
# rateprofile
rateprofile 5
save
First of all, make sure you are on the latest version of the Betaflight Configurator (which as of today is 10.6.0). You can download and install that from HERE.
Next, you're on a pre-release version of Betaflight 4.0. I suggest you update the firmware on it to at least version 4.0.6. In Betaflight Configurator go to the "Firmware Flasher" tab and select "CRAZYBEEF4FS (Legacy)" as the FC type and then 4.0.6 from the next dropdown. Then click the "Load Firmware [Online]" button at the bottom followed by "Flash Firmware". Make sure the "Full chip erase" option at the top is switched on before you flash the firmware.
I would normally advise that you backup your current settings with the "diff all" CLI command first but as you can see from your diff above, no custom settings have been applied from defaults so there is no point doing that. It's a bit odd because these whoops nearly always have some custom setting changes that were applied at the factory (by Happymodel technicians).
  • Hawaiigrown
Thanks for the reply,
I tried to update the firmware to 4.1.0 but it didn't work. the log says failed to open serial port and it just gets stuck on the "initializing reboot to bootloader" after I click on flash firmware.
(27-Oct-2019, 01:57 PM)Hawaiigrown Wrote: I tried to update the firmware to 4.1.0 but it didn't work. the log says failed to open serial port and it just gets stuck on the "initializing reboot to bootloader" after I click on flash firmware.
I suggest you put the flight controller into boot mode manually by holding down the button on the board while plugging in the USB cable. Then in the Betaflight Configurator, go to the Firmware Flasher tab and ensure that "DFU" is the value shown in the dropdown box at the top. Ensure that both "No reboot sequence" and "Full chip erase" are switched on and then try to flash the same firmware again that I mentioned in my previous post.
If you look up through the bottom of the Mobula frame you should be able to see the "BOOT" button on the bottom of the flight controller board. Use a non-metallic implement to keep that button held in while you are plugging in the USB cable...
[Image: crazybee-f4-pro-v1-frsky-bottom-1024x852.jpg]
Thanks guys. Problem solved. Wasn’t in dshot600 that’s all
  Mobula7 Betaflight PID caution warning Kramesor 1 986 27-Dec-2022, 05:36 AM
Last Post: sevro
  Mobula7 1S ELRS - Upgrade to Betaflight 4.3.2 - 'Apply Custom Defaults' is missing Zorik_IL 4 2,776 15-Dec-2022, 07:55 AM
Last Post: Zorik_IL
