Posts: 909 Threads: 59 Likes Received: 543 in 318 posts Likes Given: 730 Joined: Nov 2018 Reputation: 26 First off I see no issues with the Mobula it flies great. I just wanted to change one of my switches. So I connected the Mobula to BF and noticed an odd flag in "Arming disable flags" " Paralyze " I then went to the config tab and there was red text that said " no gyro/acc found " but it was showing up above as connected. And on the opening page, the on screen model was responding to me moving the quad as I would expect it to respond. The OSD page would not populate And neither would the Modes page, in fact it then freezes and nothing else works except "disconnect" The CLI works fine. All my other quads seem to connect fine and all pages are useable. I thought it may be something odd with this early version of BF4.0 they used on the Mobula so I hooked it up to my laptop which still has BF 10.4 on it. Everything works fine, all tabs are accessible. So I thought I would update the laptop to 10.5.1 and see if a fresh version would do it , nope. All the same problems. I gave a quick look on github and did not see anything like this. Has anyone heard of issues like this ? Or should I just rollback the laptop to 10.4 for the Mobula ? Thanks Scott Posts: 21,415 Threads: 595 Likes Received: 9,038 in 6,689 posts Likes Given: 1,428 Joined: Jun 2018 Reputation: 796 There are known issues with early versions of BF4.0 (prior to the final release) and the 10.5.x Betaflight Configurator exactly like what you are seeing. I suggest you upgrade to the latest release version of BF4.0. In fact BF4.0.1 is now out so just flash that. Obviously, don't forget to take a dump backup of your current settings. • Posts: 909 Threads: 59 Likes Received: 543 in 318 posts Likes Given: 730 Joined: Nov 2018 Reputation: 26 Thanks Snow I thought I read somewhere that you shouldn't switch versions on the Mobula. I know it had issues with 3.5.1. The 4.0 it is on has really high cpu load but it doesn't seem to affect it. I tried finding where I read that but it escapes me. I thought it was on Happy Model's website but I can't find it now. I can't say for certain but I think I have used 10.5.1 before with it. It may have been CLI only though. I guess with a dump and diff it wouldn't hurt to try. I think 4.0.2 will be out soon. I am not really having any issues so I may wait for the newer version. Scott • Posts: 21,415 Threads: 595 Likes Received: 9,038 in 6,689 posts Likes Given: 1,428 Joined: Jun 2018 Reputation: 796 I can't answer your question about not upgrading from the factory loaded BF4.0 version but there were quite a few changes from the earlier pre-release Betaflight 4.0 versions until when the final 4.0 version was released, some of them to do with the way the tuning is coded and works. I know people have had issues with the release version of BF4.0 being different to the factory installed pre-release version on the Trashcan and they have had to bin the factory applied tuning and redo it from scratch. I haven't hit that issue yet because mine is still in pieces so I haven't flown it since BF4.0 final was released. Below is a link to the compatibility issue with the pre-release BF4.0 versions and BFC10.5.x. While the issue specifically mentions the Modes tab, the underlying issue also affects other parts of the BFC as well. https://github.com/betaflight/betaflight...ssues/1335 • Posts: 909 Threads: 59 Likes Received: 543 in 318 posts Likes Given: 730 Joined: Nov 2018 Reputation: 26 Thanks for that link, I looked for quite awhile this morning and did not find that. That sure sounds like the same issue. I think it is odd I have not noticed it until now. This is why I will wait for 4.0.2 https://github.com/betaflight/betaflight/releases Scott • Posts: 21,415 Threads: 595 Likes Received: 9,038 in 6,689 posts Likes Given: 1,428 Joined: Jun 2018 Reputation: 796 (04-May-2019, 10:32 PM)Scott_M Wrote: This is why I will wait for 4.0.2 https://github.com/betaflight/betaflight/releases ![[Image: POsynELl.jpg]](https://i.imgur.com/POsynELl.jpg) Scott Oh yes, of course. The Mobula 7 came with an F3 flight controller. I totally forgot about that. There is still nothing to stop you applying the final release of 4.0.0 if you wish which will (should) fix the issue, but I'm guessing 4.0.2 will be out within the next week with a bug as serious as that present in 4.0.1. • Posts: 4 Threads: 0 Likes Received: 0 in 0 posts Likes Given: 2 Joined: Oct 2019 Reputation: 0 Hello, First off, be aware that I’m a total noob who just got my first fpv whoop, mobula 7 v2. Paid a few bucks extra to have it setup and binded to a flysky fs-i6s. Been stuck with a problem and after a few hours of reading, searching, and learning, still no answer but came across this thread and I’m having the exact same issue as the original poster.... was flying good then suddenly stopped arming. A few small crashes but nothing major and now it won’t arm. I downloaded beta flight 10.6 and hooked it up and see that the paralyze flag is preventing arming. It says the solution is to reset the fc by power cycling it but I don’t know how to do that.... I know, total noob right? I know what a power cycle is but not how to do it with my fc. I tried everything I could think of..... plug in the battery, not arming. Disconnect, replug, still no. Plug in usb for power, unplug, still nothing. BF still shows paralyze flag.... Need some help here please.... if u need anymore info let me know but like I said, assume I’m a noob who doesn’t know anything.... Thanks • Posts: 12,098 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 27-Oct-2019, 07:42 AM (This post was last modified: 27-Oct-2019, 07:46 AM by voodoo614.) Can you type "version" in CLI and tell me what version of betaflight you have? If it is 4.0 then it could be a pre-lease firmware and it has some bugs. You want to make a dump and then update the firmware and restore all your settings. Can you post a dump here first? • Posts: 4 Threads: 0 Likes Received: 0 in 0 posts Likes Given: 2 Joined: Oct 2019 Reputation: 0 # # diff all # version # Betaflight / CRAZYBEEF4FS (C4FS) 4.0.0 Dec 11 2018 / 01:08:39 (3b479f92d) MSP API: 1.41 board_name CRAZYBEEF4FS manufacturer_id mcu_id 004700173437511430353933 signature # reset configuration to default settings defaults nosave # name # resources # mixer # servo # servo mix # feature # beeper # beacon # map # serial # led # color # mode_color # aux # adjrange # rxrange # vtx # rxfail # master # profile profile 0 # profile profile 1 # profile profile 2 # restore original profile selection profile 0 # rateprofile rateprofile 0 # rateprofile rateprofile 1 # rateprofile rateprofile 2 # rateprofile rateprofile 3 # rateprofile rateprofile 4 # rateprofile rateprofile 5 # restore original rateprofile selection rateprofile 0 # save configuration save # dump # version # Betaflight / CRAZYBEEF4FS (C4FS) 4.0.0 Dec 11 2018 / 01:08:39 (3b479f92d) MSP API: 1.41 board_name CRAZYBEEF4FS manufacturer_id # name name - # resources resource BEEPER 1 C15 resource MOTOR 1 B10 resource MOTOR 2 B06 resource MOTOR 3 B07 resource MOTOR 4 B08 resource MOTOR 5 NONE resource MOTOR 6 NONE resource MOTOR 7 NONE resource MOTOR 8 NONE resource SERVO 1 NONE resource SERVO 2 NONE resource SERVO 3 NONE resource SERVO 4 NONE resource SERVO 5 NONE resource SERVO 6 NONE resource SERVO 7 NONE resource SERVO 8 NONE resource PPM 1 A03 resource PWM 1 A02 resource PWM 2 A09 resource PWM 3 A10 resource PWM 4 NONE resource PWM 5 NONE resource PWM 6 NONE resource PWM 7 NONE resource PWM 8 NONE resource LED_STRIP 1 A00 resource SERIAL_TX 1 A09 resource SERIAL_TX 2 A02 resource SERIAL_TX 3 NONE resource SERIAL_TX 4 NONE resource SERIAL_TX 5 NONE resource SERIAL_TX 6 NONE resource SERIAL_TX 7 NONE resource SERIAL_TX 8 NONE resource SERIAL_TX 9 NONE resource SERIAL_TX 10 NONE resource SERIAL_TX 11 NONE resource SERIAL_RX 1 A10 resource SERIAL_RX 2 A03 resource SERIAL_RX 3 NONE resource SERIAL_RX 4 NONE resource SERIAL_RX 5 NONE resource SERIAL_RX 6 NONE resource SERIAL_RX 7 NONE resource SERIAL_RX 8 NONE resource SERIAL_RX 9 NONE resource SERIAL_RX 10 NONE resource SERIAL_RX 11 NONE resource LED 1 C13 resource LED 2 NONE resource LED 3 NONE resource RX_BIND 1 NONE resource RX_BIND_PLUG 1 B02 resource SPI_SCK 1 A05 resource SPI_SCK 2 B13 resource SPI_SCK 3 B03 resource SPI_MISO 1 A06 resource SPI_MISO 2 B14 resource SPI_MISO 3 B04 resource SPI_MOSI 1 A07 resource SPI_MOSI 2 B15 resource SPI_MOSI 3 B05 resource ESCSERIAL 1 NONE resource CAMERA_CONTROL 1 NONE resource ADC_BATT 1 B00 resource ADC_RSSI 1 NONE resource ADC_CURR 1 B01 resource ADC_EXT 1 NONE resource PINIO 1 NONE resource PINIO 2 NONE resource PINIO 3 NONE resource PINIO 4 NONE resource OSD_CS 1 B12 resource SPI_PREINIT_IPU 1 A04 resource SPI_PREINIT_IPU 2 NONE resource SPI_PREINIT_IPU 3 A15 resource SPI_PREINIT_IPU 4 B12 resource SPI_PREINIT_IPU 5 NONE resource SPI_PREINIT_IPU 6 NONE resource SPI_PREINIT_IPU 7 NONE resource SPI_PREINIT_IPU 8 NONE resource SPI_PREINIT_IPU 9 NONE resource SPI_PREINIT_IPU 10 NONE resource SPI_PREINIT_IPU 11 NONE resource SPI_PREINIT_OPU 1 NONE resource SPI_PREINIT_OPU 2 NONE resource RX_SPI_CS 1 A15 resource GYRO_EXTI 1 A01 resource GYRO_EXTI 2 NONE resource GYRO_CS 1 A04 resource GYRO_CS 2 NONE # mixer mixer QUADX mmix reset # servo servo 0 1000 2000 1500 100 -1 servo 1 1000 2000 1500 100 -1 servo 2 1000 2000 1500 100 -1 servo 3 1000 2000 1500 100 -1 servo 4 1000 2000 1500 100 -1 servo 5 1000 2000 1500 100 -1 servo 6 1000 2000 1500 100 -1 servo 7 1000 2000 1500 100 -1 # servo mix smix reset # feature feature -RX_PPM feature -INFLIGHT_ACC_CAL feature -RX_SERIAL feature -MOTOR_STOP feature -SERVO_TILT feature -SOFTSERIAL feature -GPS feature -RANGEFINDER feature -TELEMETRY feature -3D feature -RX_PARALLEL_PWM feature -RX_MSP feature -RSSI_ADC feature -LED_STRIP feature -DISPLAY feature -OSD feature -CHANNEL_FORWARDING feature -TRANSPONDER feature -AIRMODE feature -RX_SPI feature -SOFTSPI feature -ESC_SENSOR feature -ANTI_GRAVITY feature -DYNAMIC_FILTER feature TELEMETRY feature OSD feature RX_SPI feature ANTI_GRAVITY feature DYNAMIC_FILTER # beeper beeper GYRO_CALIBRATED beeper RX_LOST beeper RX_LOST_LANDING beeper DISARMING beeper ARMING beeper ARMING_GPS_FIX beeper BAT_CRIT_LOW beeper BAT_LOW beeper GPS_STATUS beeper RX_SET beeper ACC_CALIBRATION beeper ACC_CALIBRATION_FAIL beeper READY_BEEP beeper MULTI_BEEPS beeper DISARM_REPEAT beeper ARMED beeper SYSTEM_INIT beeper ON_USB beeper BLACKBOX_ERASE beeper CRASH_FLIP beeper CAM_CONNECTION_OPEN beeper CAM_CONNECTION_CLOSE beeper RC_SMOOTHING_INIT_FAIL # beacon beacon GYRO_CALIBRATED beacon -RX_LOST beacon RX_LOST_LANDING beacon DISARMING beacon ARMING beacon ARMING_GPS_FIX beacon BAT_CRIT_LOW beacon BAT_LOW beacon GPS_STATUS beacon -RX_SET beacon ACC_CALIBRATION beacon ACC_CALIBRATION_FAIL beacon READY_BEEP beacon MULTI_BEEPS beacon DISARM_REPEAT beacon ARMED beacon SYSTEM_INIT beacon ON_USB beacon BLACKBOX_ERASE beacon CRASH_FLIP beacon CAM_CONNECTION_OPEN beacon CAM_CONNECTION_CLOSE beacon RC_SMOOTHING_INIT_FAIL # map map AETR1234 # serial serial 20 1 115200 57600 0 115200 serial 0 0 115200 57600 0 115200 serial 1 0 115200 57600 0 115200 # led led 0 0,0::C:0 led 1 0,0::C:0 led 2 0,0::C:0 led 3 0,0::C:0 led 4 0,0::C:0 led 5 0,0::C:0 led 6 0,0::C:0 led 7 0,0::C:0 led 8 0,0::C:0 led 9 0,0::C:0 led 10 0,0::C:0 led 11 0,0::C:0 led 12 0,0::C:0 led 13 0,0::C:0 led 14 0,0::C:0 led 15 0,0::C:0 led 16 0,0::C:0 led 17 0,0::C:0 led 18 0,0::C:0 led 19 0,0::C:0 led 20 0,0::C:0 led 21 0,0::C:0 led 22 0,0::C:0 led 23 0,0::C:0 led 24 0,0::C:0 led 25 0,0::C:0 led 26 0,0::C:0 led 27 0,0::C:0 led 28 0,0::C:0 led 29 0,0::C:0 led 30 0,0::C:0 led 31 0,0::C:0 # color color 0 0,0,0 color 1 0,255,255 color 2 0,0,255 color 3 30,0,255 color 4 60,0,255 color 5 90,0,255 color 6 120,0,255 color 7 150,0,255 color 8 180,0,255 color 9 210,0,255 color 10 240,0,255 color 11 270,0,255 color 12 300,0,255 color 13 330,0,255 color 14 0,0,0 color 15 0,0,0 # mode_color mode_color 0 0 1 mode_color 0 1 11 mode_color 0 2 2 mode_color 0 3 13 mode_color 0 4 10 mode_color 0 5 3 mode_color 1 0 5 mode_color 1 1 11 mode_color 1 2 3 mode_color 1 3 13 mode_color 1 4 10 mode_color 1 5 3 mode_color 2 0 10 mode_color 2 1 11 mode_color 2 2 4 mode_color 2 3 13 mode_color 2 4 10 mode_color 2 5 3 mode_color 3 0 8 mode_color 3 1 11 mode_color 3 2 4 mode_color 3 3 13 mode_color 3 4 10 mode_color 3 5 3 mode_color 4 0 7 mode_color 4 1 11 mode_color 4 2 3 mode_color 4 3 13 mode_color 4 4 10 mode_color 4 5 3 mode_color 5 0 9 mode_color 5 1 11 mode_color 5 2 2 mode_color 5 3 13 mode_color 5 4 10 mode_color 5 5 3 mode_color 6 0 6 mode_color 6 1 10 mode_color 6 2 1 mode_color 6 3 0 mode_color 6 4 0 mode_color 6 5 2 mode_color 6 6 3 mode_color 6 7 6 mode_color 6 8 0 mode_color 6 9 0 mode_color 6 10 0 mode_color 7 0 3 # aux aux 0 0 0 900 900 0 0 aux 1 0 0 900 900 0 0 aux 2 0 0 900 900 0 0 aux 3 0 0 900 900 0 0 aux 4 0 0 900 900 0 0 aux 5 0 0 900 900 0 0 aux 6 0 0 900 900 0 0 aux 7 0 0 900 900 0 0 aux 8 0 0 900 900 0 0 aux 9 0 0 900 900 0 0 aux 10 0 0 900 900 0 0 aux 11 0 0 900 900 0 0 aux 12 0 0 900 900 0 0 aux 13 0 0 900 900 0 0 aux 14 0 0 900 900 0 0 aux 15 0 0 900 900 0 0 aux 16 0 0 900 900 0 0 aux 17 0 0 900 900 0 0 aux 18 0 0 900 900 0 0 aux 19 0 0 900 900 0 0 # adjrange adjrange 0 0 0 900 900 0 0 0 0 adjrange 1 0 0 900 900 0 0 0 0 adjrange 2 0 0 900 900 0 0 0 0 adjrange 3 0 0 900 900 0 0 0 0 adjrange 4 0 0 900 900 0 0 0 0 adjrange 5 0 0 900 900 0 0 0 0 adjrange 6 0 0 900 900 0 0 0 0 adjrange 7 0 0 900 900 0 0 0 0 adjrange 8 0 0 900 900 0 0 0 0 adjrange 9 0 0 900 900 0 0 0 0 adjrange 10 0 0 900 900 0 0 0 0 adjrange 11 0 0 900 900 0 0 0 0 adjrange 12 0 0 900 900 0 0 0 0 adjrange 13 0 0 900 900 0 0 0 0 adjrange 14 0 0 900 900 0 0 0 0 adjrange 15 0 0 900 900 0 0 0 0 adjrange 16 0 0 900 900 0 0 0 0 adjrange 17 0 0 900 900 0 0 0 0 adjrange 18 0 0 900 900 0 0 0 0 adjrange 19 0 0 900 900 0 0 0 0 adjrange 20 0 0 900 900 0 0 0 0 adjrange 21 0 0 900 900 0 0 0 0 adjrange 22 0 0 900 900 0 0 0 0 adjrange 23 0 0 900 900 0 0 0 0 adjrange 24 0 0 900 900 0 0 0 0 adjrange 25 0 0 900 900 0 0 0 0 adjrange 26 0 0 900 900 0 0 0 0 adjrange 27 0 0 900 900 0 0 0 0 adjrange 28 0 0 900 900 0 0 0 0 adjrange 29 0 0 900 900 0 0 0 0 # rxrange rxrange 0 1000 2000 rxrange 1 1000 2000 rxrange 2 1000 2000 rxrange 3 1000 2000 # vtx vtx 0 0 0 0 900 900 vtx 1 0 0 0 900 900 vtx 2 0 0 0 900 900 vtx 3 0 0 0 900 900 vtx 4 0 0 0 900 900 vtx 5 0 0 0 900 900 vtx 6 0 0 0 900 900 vtx 7 0 0 0 900 900 vtx 8 0 0 0 900 900 vtx 9 0 0 0 900 900 # rxfail rxfail 0 a rxfail 1 a rxfail 2 a rxfail 3 a rxfail 4 h rxfail 5 h rxfail 6 h rxfail 7 h rxfail 8 h rxfail 9 h rxfail 10 h rxfail 11 h rxfail 12 h rxfail 13 h rxfail 14 h rxfail 15 h rxfail 16 h rxfail 17 h # master set align_gyro = DEFAULT set gyro_hardware_lpf = NORMAL set gyro_sync_denom = 1 set gyro_lowpass_type = PT1 set gyro_lowpass_hz = 100 set gyro_lowpass2_type = PT1 set gyro_lowpass2_hz = 300 set gyro_notch1_hz = 0 set gyro_notch1_cutoff = 0 set gyro_notch2_hz = 0 set gyro_notch2_cutoff = 0 set gyro_calib_duration = 125 set gyro_calib_noise_limit = 48 set gyro_offset_yaw = 0 set gyro_overflow_detect = ALL set yaw_spin_recovery = ON set yaw_spin_threshold = 1950 set gyro_to_use = FIRST set dyn_fft_location = AFTER_STATIC_FILTERS set dyn_filter_width_percent = 40 set dyn_filter_range = MEDIUM set align_acc = DEFAULT set acc_hardware = AUTO set acc_lpf_hz = 10 set acc_trim_pitch = 0 set acc_trim_roll = 0 set acc_calibration = 0,0,0 set mid_rc = 1500 set min_check = 1050 set max_check = 1900 set rssi_channel = 0 set rssi_src_frame_errors = OFF set rssi_scale = 100 set rssi_offset = 0 set rssi_invert = OFF set rc_interp = AUTO set rc_interp_ch = RPYT set rc_interp_int = 19 set rc_smoothing_type = FILTER set rc_smoothing_input_hz = 0 set rc_smoothing_derivative_hz = 0 set rc_smoothing_debug_axis = ROLL set rc_smoothing_input_type = BIQUAD set rc_smoothing_derivative_type = BIQUAD set fpv_mix_degrees = 0 set max_aux_channels = 14 set serialrx_provider = SPEK1024 set serialrx_inverted = OFF set spektrum_sat_bind = 0 set spektrum_sat_bind_autoreset = ON set airmode_start_throttle_percent = 32 set rx_min_usec = 885 set rx_max_usec = 2115 set serialrx_halfduplex = OFF set rx_spi_protocol = FLYSKY_2A set rx_spi_bus = 3 set adc_device = 1 set input_filtering_mode = OFF set blackbox_p_ratio = 32 set blackbox_device = SERIAL set blackbox_record_acc = ON set blackbox_mode = NORMAL set min_throttle = 1070 set max_throttle = 2000 set min_command = 1000 set dshot_idle_value = 450 set dshot_burst = OFF set use_unsynced_pwm = OFF set motor_pwm_protocol = ONESHOT125 set motor_pwm_rate = 480 set motor_pwm_inversion = OFF set motor_poles = 14 set thr_corr_value = 0 set thr_corr_angle = 800 set failsafe_delay = 4 set failsafe_off_delay = 10 set failsafe_throttle = 1000 set failsafe_switch_mode = STAGE1 set failsafe_throttle_low_delay = 100 set failsafe_procedure = DROP set align_board_roll = 0 set align_board_pitch = 0 set align_board_yaw = 0 set gimbal_mode = NORMAL set bat_capacity = 0 set vbat_max_cell_voltage = 43 set vbat_full_cell_voltage = 41 set vbat_min_cell_voltage = 33 set vbat_warning_cell_voltage = 35 set vbat_hysteresis = 1 set current_meter = ADC set battery_meter = ADC set vbat_detect_cell_voltage = 30 set use_vbat_alerts = ON set use_cbat_alerts = OFF set cbat_alert_percent = 10 set vbat_cutoff_percent = 100 set force_battery_cell_count = 0 set vbat_scale = 110 set vbat_divider = 10 set vbat_multiplier = 1 set ibata_scale = 179 set ibata_offset = 0 set ibatv_scale = 0 set ibatv_offset = 0 set beeper_inversion = ON set beeper_od = OFF set beeper_frequency = 0 set beeper_dshot_beacon_tone = 1 set yaw_motors_reversed = OFF set crashflip_motor_percent = 0 set 3d_deadband_low = 1406 set 3d_deadband_high = 1514 set 3d_neutral = 1460 set 3d_deadband_throttle = 50 set 3d_limit_low = 1000 set 3d_limit_high = 2000 set 3d_switched_mode = OFF set servo_center_pulse = 1500 set servo_pwm_rate = 50 set servo_lowpass_hz = 0 set tri_unarmed_servo = ON set channel_forwarding_start = 4 set reboot_character = 82 set serial_update_rate_hz = 100 set imu_dcm_kp = 2500 set imu_dcm_ki = 0 set small_angle = 25 set auto_disarm_delay = 5 set gyro_cal_on_first_arm = OFF set gps_provider = NMEA set gps_sbas_mode = AUTO set gps_auto_config = ON set gps_auto_baud = OFF set gps_ublox_use_galileo = OFF set gps_rescue_angle = 32 set gps_rescue_initial_alt = 50 set gps_rescue_descent_dist = 200 set gps_rescue_ground_speed = 2000 set gps_rescue_throttle_p = 150 set gps_rescue_throttle_i = 20 set gps_rescue_throttle_d = 50 set gps_rescue_velocity_p = 80 set gps_rescue_velocity_i = 20 set gps_rescue_velocity_d = 15 set gps_rescue_yaw_p = 40 set gps_rescue_throttle_min = 1200 set gps_rescue_throttle_max = 1600 set gps_rescue_throttle_hover = 1280 set gps_rescue_sanity_checks = RESCUE_SANITY_ON set gps_rescue_min_sats = 8 set gps_rescue_min_dth = 100 set deadband = 0 set yaw_deadband = 0 set yaw_control_reversed = OFF set pid_process_denom = 4 set runaway_takeoff_prevention = ON set runaway_takeoff_deactivate_delay = 500 set runaway_takeoff_deactivate_throttle_percent = 25 set tlm_inverted = OFF set tlm_halfduplex = ON set frsky_default_lat = 0 set frsky_default_long = 0 set frsky_gps_format = 0 set frsky_unit = IMPERIAL set frsky_vfas_precision = 0 set hott_alarm_int = 5 set pid_in_tlm = OFF set report_cell_voltage = OFF set ibus_sensor = 1,2,3,0,0,0,0,0,0,0,0,0,0,0,0 set smartport_use_extra_sensors = OFF set mavlink_mah_as_heading_divisor = 0 set ledstrip_visual_beeper = OFF set ledstrip_grb_rgb = GRB set osd_units = METRIC set osd_warn_arming_disable = ON set osd_warn_batt_not_full = ON set osd_warn_batt_warning = ON set osd_warn_batt_critical = ON set osd_warn_visual_beeper = ON set osd_warn_crash_flip = ON set osd_warn_esc_fail = ON set osd_warn_core_temp = ON set osd_warn_fail_safe = ON set osd_rssi_alarm = 20 set osd_cap_alarm = 2200 set osd_alt_alarm = 100 set osd_esc_temp_alarm = -128 set osd_esc_rpm_alarm = -1 set osd_esc_current_alarm = -1 set osd_core_temp_alarm = 70 set osd_ah_max_pit = 20 set osd_ah_max_rol = 40 set osd_tim1 = 2560 set osd_tim2 = 2561 set osd_vbat_pos = 234 set osd_rssi_pos = 234 set osd_tim_1_pos = 234 set osd_tim_2_pos = 234 set osd_remaining_time_estimate_pos = 234 set osd_flymode_pos = 234 set osd_anti_gravity_pos = 234 set osd_g_force_pos = 234 set osd_throttle_pos = 234 set osd_vtx_channel_pos = 234 set osd_crosshairs_pos = 205 set osd_ah_sbar_pos = 206 set osd_ah_pos = 78 set osd_current_pos = 234 set osd_mah_drawn_pos = 234 set osd_craft_name_pos = 234 set osd_gps_speed_pos = 234 set osd_gps_lon_pos = 234 set osd_gps_lat_pos = 234 set osd_gps_sats_pos = 234 set osd_home_dir_pos = 234 set osd_home_dist_pos = 234 set osd_compass_bar_pos = 234 set osd_altitude_pos = 234 set osd_pid_roll_pos = 234 set osd_pid_pitch_pos = 234 set osd_pid_yaw_pos = 234 set osd_debug_pos = 234 set osd_power_pos = 234 set osd_pidrate_profile_pos = 234 set osd_warnings_pos = 2377 set osd_avg_cell_voltage_pos = 234 set osd_pit_ang_pos = 234 set osd_rol_ang_pos = 234 set osd_battery_usage_pos = 234 set osd_disarmed_pos = 234 set osd_nheading_pos = 234 set osd_esc_tmp_pos = 234 set osd_esc_rpm_pos = 234 set osd_rtc_date_time_pos = 234 set osd_adjustment_range_pos = 234 set osd_flip_arrow_pos = 234 set osd_core_temp_pos = 234 set osd_log_status_pos = 234 set osd_stat_rtc_date_time = OFF set osd_stat_tim_1 = OFF set osd_stat_tim_2 = ON set osd_stat_max_spd = ON set osd_stat_max_dist = OFF set osd_stat_min_batt = ON set osd_stat_endbatt = OFF set osd_stat_battery = OFF set osd_stat_min_rssi = ON set osd_stat_max_curr = ON set osd_stat_used_mah = ON set osd_stat_max_alt = OFF set osd_stat_bbox = ON set osd_stat_bb_no = ON set osd_stat_max_g_force = OFF set osd_stat_max_esc_temp = OFF set osd_stat_max_esc_rpm = OFF set task_statistics = ON set debug_mode = NONE set rate_6pos_switch = OFF set cpu_overclock = OFF set pwr_on_arm_grace = 5 set vtx_band = 4 set vtx_channel = 1 set vtx_power = 1 set vtx_low_power_disarm = OFF set vtx_freq = 5740 set vtx_pit_mode_freq = 0 set vtx_halfduplex = ON set vcd_video_system = AUTO set vcd_h_offset = 0 set vcd_v_offset = 0 set max7456_clock = DEFAULT set max7456_spi_bus = 2 set displayport_msp_col_adjust = 0 set displayport_msp_row_adjust = 0 set displayport_max7456_col_adjust = 0 set displayport_max7456_row_adjust = 0 set displayport_max7456_inv = OFF set displayport_max7456_blk = 0 set displayport_max7456_wht = 2 set esc_sensor_halfduplex = OFF set esc_sensor_current_offset = 0 set led_inversion = 0 set camera_control_mode = HARDWARE_PWM set camera_control_ref_voltage = 330 set camera_control_key_delay = 180 set camera_control_internal_resistance = 470 set camera_control_inverted = OFF set pinio_config = 1,1,1,1 set pinio_box = 255,255,255,255 set usb_hid_cdc = OFF set rcdevice_init_dev_attempts = 6 set rcdevice_init_dev_attempt_interval = 1000 set gyro_1_bustype = SPI set gyro_1_spibus = 1 set gyro_1_i2cBus = 0 set gyro_1_i2c_address = 0 set gyro_1_sensor_align = CW90 set gyro_2_bustype = SPI set gyro_2_spibus = 1 set gyro_2_i2cBus = 0 set gyro_2_i2c_address = 0 set gyro_2_sensor_align = DEFAULT # profile profile 0 set dterm_lowpass_type = PT1 set dterm_lowpass_hz = 100 set dterm_lowpass2_hz = 200 set dterm_notch_hz = 0 set dterm_notch_cutoff = 0 set vbat_pid_gain = OFF set pid_at_min_throttle = ON set anti_gravity_mode = SMOOTH set anti_gravity_threshold = 250 set anti_gravity_gain = 5000 set feedforward_transition = 0 set acc_limit_yaw = 0 set acc_limit = 0 set crash_dthreshold = 50 set crash_gthreshold = 400 set crash_setpoint_threshold = 350 set crash_time = 500 set crash_delay = 0 set crash_recovery_angle = 10 set crash_recovery_rate = 100 set crash_limit_yaw = 200 set crash_recovery = OFF set iterm_rotation = ON set smart_feedforward = OFF set iterm_relax = RP set iterm_relax_type = SETPOINT set iterm_relax_cutoff = 11 set iterm_windup = 40 set iterm_limit = 300 set pidsum_limit = 500 set pidsum_limit_yaw = 400 set yaw_lowpass_hz = 0 set throttle_boost = 5 set throttle_boost_cutoff = 15 set acro_trainer_angle_limit = 20 set acro_trainer_lookahead_ms = 50 set acro_trainer_debug_axis = ROLL set acro_trainer_gain = 75 set p_pitch = 50 set i_pitch = 50 set d_pitch = 27 set f_pitch = 60 set p_roll = 46 set i_roll = 45 set d_roll = 25 set f_roll = 60 set p_yaw = 45 set i_yaw = 100 set d_yaw = 0 set f_yaw = 100 set angle_level_strength = 50 set horizon_level_strength = 50 set horizon_transition = 75 set level_limit = 55 set horizon_tilt_effect = 75 set horizon_tilt_expert_mode = OFF set abs_control_gain = 0 set abs_control_limit = 90 set abs_control_error_limit = 20 # rateprofile rateprofile 0 set thr_mid = 50 set thr_expo = 0 set rates_type = BETAFLIGHT set roll_rc_rate = 100 set pitch_rc_rate = 100 set yaw_rc_rate = 100 set roll_expo = 0 set pitch_expo = 0 set yaw_expo = 0 set roll_srate = 70 set pitch_srate = 70 set yaw_srate = 70 set tpa_rate = 10 set tpa_breakpoint = 1650 set throttle_limit_type = OFF set throttle_limit_percent = 100 set roll_rate_limit = 1998 set pitch_rate_limit = 1998 set yaw_rate_limit = 1998 # • Posts: 21,415 Threads: 595 Likes Received: 9,038 in 6,689 posts Likes Given: 1,428 Joined: Jun 2018 Reputation: 796 (27-Oct-2019, 10:26 AM)Hawaiigrown Wrote: Code: # diff all # version # Betaflight / CRAZYBEEF4FS (C4FS) 4.0.0 Dec 11 2018 / 01:08:39 (3b479f92d) MSP API: 1.41 board_name CRAZYBEEF4FS manufacturer_id mcu_id 004700173437511430353933 signature # reset configuration to default settings defaults nosave # name # resources # mixer # servo # servo mix # feature # beeper # beacon # map # serial # led # color # mode_color # aux # adjrange # rxrange # vtx # rxfail # master # profile profile 0 # profile profile 1 # profile profile 2 # restore original profile selection profile 0 # rateprofile rateprofile 0 # rateprofile rateprofile 1 # rateprofile rateprofile 2 # rateprofile rateprofile 3 # rateprofile rateprofile 4 # rateprofile rateprofile 5 # restore original rateprofile selection rateprofile 0 # save configuration save
First of all, make sure you are on the latest version of the Betaflight Configurator (which as of today is 10.6.0). You can download and install that from HERE. Next, you're on a pre-release version of Betaflight 4.0. I suggest you update the firmware on it to at least version 4.0.6. In Betaflight Configurator go to the "Firmware Flasher" tab and select " CRAZYBEEF4FS (Legacy)" as the FC type and then 4.0.6 from the next dropdown. Then click the "Load Firmware [Online]" button at the bottom followed by "Flash Firmware". Make sure the "Full chip erase" option at the top is switched on before you flash the firmware. I would normally advise that you backup your current settings with the "diff all" CLI command first but as you can see from your diff above, no custom settings have been applied from defaults so there is no point doing that. It's a bit odd because these whoops nearly always have some custom setting changes that were applied at the factory (by Happymodel technicians). Posts: 4 Threads: 0 Likes Received: 0 in 0 posts Likes Given: 2 Joined: Oct 2019 Reputation: 0 Thanks for the reply, I tried to update the firmware to 4.1.0 but it didn't work. the log says failed to open serial port and it just gets stuck on the "initializing reboot to bootloader" after I click on flash firmware. • Posts: 21,415 Threads: 595 Likes Received: 9,038 in 6,689 posts Likes Given: 1,428 Joined: Jun 2018 Reputation: 796 27-Oct-2019, 06:21 PM (This post was last modified: 27-Oct-2019, 06:21 PM by SnowLeopardFPV.) (27-Oct-2019, 01:57 PM)Hawaiigrown Wrote: I tried to update the firmware to 4.1.0 but it didn't work. the log says failed to open serial port and it just gets stuck on the "initializing reboot to bootloader" after I click on flash firmware. I suggest you put the flight controller into boot mode manually by holding down the button on the board while plugging in the USB cable. Then in the Betaflight Configurator, go to the Firmware Flasher tab and ensure that "DFU" is the value shown in the dropdown box at the top. Ensure that both "No reboot sequence" and "Full chip erase" are switched on and then try to flash the same firmware again that I mentioned in my previous post. If you look up through the bottom of the Mobula frame you should be able to see the "BOOT" button on the bottom of the flight controller board. Use a non-metallic implement to keep that button held in while you are plugging in the USB cable... • Posts: 4 Threads: 0 Likes Received: 0 in 0 posts Likes Given: 2 Joined: Oct 2019 Reputation: 0 Thanks guys. Problem solved. Wasn’t in dshot600 that’s all • |
