Threads: 31
Likes Received: 3 in 3 posts
Likes Given: 2
0 Hi
I have a new betafpv micro elrs rx which has servo connections for a fixed wing. it is supposed to work in pwm. After binding successfully to my zorro elrs tx i get telemetry but no servo control on any channel. This seems to be not in pwm mode. Youtube setup tips seem to show settings via wifi but when i go into its wifi setup it looks diiferent and no mention of pwm channels. the software on both the rx and tx is elrs 3.3.0.
Any ideas please?
Threads: 69
Likes Received: 339 in 253 posts
Likes Given: 155
19 Sounds like its possibly got the Crossfire firmware option loaded?
Get the correct firmware from BetaFPV direct and flash that?
Threads: 2
Likes Received: 0 in 0 posts
0 Try checking your channels/Mixes
Threads: 49
Likes Received: 713 in 524 posts
Likes Given: 477
93 Do you have the correct firmware flashed? It should be "BetaFPV 2.4GHZ PWM RX". Show a screenshot of the receiver's webui.
Threads: 15
Likes Received: 76 in 49 posts
Likes Given: 155
4 There's a "Servos" option in the "Other Options" pull-down of the Betaflight Configurator's Update Firmware page. I suspect you need to rebuild Betaflight with this option selected.
Threads: 31
Likes Given: 2
0 Thanks. How does elrs configurator on the pc connect to a receiver?
Threads: 60
Likes Received: 1,019 in 735 posts
Likes Given: 96
52 There are several ways (Betaflight pass through or via UART, you can refer to expresslrs website) but wifi is probably the easiest in your case. You were already on the firmware update page as shown in your screenshot. Just first compile the firmware in configurator for the correct target which will create the bin file. Then connect to the RX via wifi and use the same webpage to load the compiled file.
Threads: 31
Likes Given: 2
0 Many thanks all it's now sorted. For some reason it was supplied with the wrong firmware.
