24-May-2023, 06:15 PM
I have problems with the blackbox on a Mobula 7 1S HD.
It has a separate blackbox, type OpenLager via serial.
In the Betaflight configurator it shows "No dataflash chip found" but everything is configured according to the instructions.
It is not possible to change the parameters under the blackbox tab, it must be done via the CLI. A bit like it only semi recognizes the module.
When I then do a testflight (several), files are actually written to the SD card (32GB PNY, FAT32).
One "LAGER.CFG" with some parameters and then a number of "LOG001", "LOG002" etc.
But these are completely empty.
Very grateful if anyone has an idea that can give me a push in the right direction to maybe be able to solve this?
- scuse me while i kiss the sky -
