Betaflight 2.8 Problems
I've just flashed the new version of Betaflight on my Naze32 and now the quad is completely un flyable. I was previously using 2.7.1 which was great, the only reason I am upgrading is to try the new rates and expo settings in Betaflight.
I was wondering what I could be doing wrong, I have configured the settings exactly the same as I always do. I am currently using BLHeli 14.6 but the same happens on 14.5 which is what I was using before.
Any ideas would be appreciated.
It's the same for me on blheli 14.4.
Quad is oscilating on my 2.7.1 pids, and feels very floaty at the same time. I also have a bit of drift now possibly due to deadband set to 0 as suggested - my input is only jumping by 1-2 and my deadband was set to 2 in 2.7.1.
Air mode is not working when enabled as a feature - I got a nice hairy moment when the quad dropped like a brick when I tried it first time and wrecked a brand new set of props when I set airmode_activate_throttle to 1050 - the quad just flipped violently on takeoff.
The new rates/expo system feels great though when you ignore the above.
do you guys mean Betaflight 2.8.0? would love to know if there is a solution as I am considering to update as well..
(05-Jun-2016, 07:45 PM)Oscar Wrote: do you guys mean Betaflight 2.8.0? would love to know if there is a solution as I am considering to update as well..
Yes Betaflight 2.8.0 I've had to revert back to 2.7.1 at the moment just so I can get my quad flying again. Currently I haven't seen a solution for it.
MY lisam210 and beerotor f3 flies very good on 2.8.0. The only bug I have found is that the failsafe land activates even though the quad is not armed or failsafe is set to drop. If I turn of the transmitter while the quad is unarmed, the motors starts spinning for a second. This can be quite scary and I have already destroyed a USB cable because of this
There is a couple of suggestions on this page of the RC Groups Betaflight thread http://www.rcgroups.com/forums/showthrea...&page=2018
I'll give this a try tomorrow and see what happens.
[-] The following 1 user Likes HamsterFPV's post:
  • Oscar
Right, I managed to get 2.8 set up for my quad, I only hovered it in the garden but it feels and looks ok now.
I'm running 4k/4k/4k on a f1 cc3d and little bee's 20a with multi shot 14.4.
I set gyro and dterm lowpass to 80, dropped d gains by 2, put the air mode on a switch, set the rates to 75 and its flying.
Edit: I'll test that failsafe bug tomorrow, but thanks for the warning.
(05-Jun-2016, 11:23 PM)artur_k Wrote: Right, I managed to get 2.8 set up for my quad, I only hovered it in the garden but feels and looks ok.
I set gyro and dterm lowpass to 80, dropped d gains by 2, put the air mode on a switch, set rates to 75 and its flying.
Are those the original Little Bees or the Pro versions?
Ill give those settings a try and see how it goes.
(05-Jun-2016, 11:29 PM)HamsterFPV Wrote: Are those the original Little Bees or the Pro versions?
Not pro, old f330s
I just loaded 2.8 on my spracingf3 in my zmr and it flew great. The only weird thing I noticed was when I was tuning trying to find oscillation points on roll and pitch I ended up maxing pitch out before I got any noticeable oscillations. My PID's seem quite high. I'm at 8.3 on roll and 13.0 on pitch. Will have to fly it and look at the BB and see what that looks like.
(07-Jun-2016, 04:17 PM)Rbei312 Wrote: I just loaded 2.8 on my spracingf3 in my zmr and it flew great. The only weird thing I noticed was when I was tuning trying to find oscillation points on roll and pitch I ended up maxing pitch out before I got any noticeable oscillations. My PID's seem quite high. I'm at 8.3 on roll and 13.0 on pitch. Will have to fly it and look at the BB and see what that looks like.
PID's seem higher in general on 2.8 Betaflight. Maybe it is something to do with the F1 boards as everyone who has problems seems to be running a Naze32 or a CC3D.
Stock PID's on rewrite were 4.5 on pitch and roll. Yaw I think was 10.
How do you set the F3 controller to run 4k/4k/4k? My littlebee 20Amps are flashed with multishot capable blheli and looptime is set to 250. I tried to set the pid_process_denom=1 in the CLI, but then I could not arm. I had to set it back to 2 to be able to arm. From what I understand, Im only running 2k to the motors now.
(07-Jun-2016, 06:45 PM)HamsterFPV Wrote: PID's seem higher in general on 2.8 Betaflight. Maybe it is something to do with the F1 boards as everyone who has problems seems to be running a Naze32 or a CC3D.
No more problems for me on CC3D, it's flying better than ever. Got my rates set higher than ever as well.
I think that problems are not specific to f1 boards but rather due to noisy / old frames - zmr/emax/qav. And more specific due to too high d gain/dterm noise.
2.8.1 just came out. Here is a message from Boris on 2.8.0
"2.8.0 VERSION HAS BEEN DEPRICATED DUE TO PROBLEMATIC ITERM TUNING. ALL ISSUES ARE SOLVED IN 2.8.1
YOU CAN DOWNLOAD 2.8.1 PRE RELEASE BELOW ALREADY BEFORE IT IS FULLY RELEASES"
  Problems upgrading to BF 4.x Jonnie Tesla 3 159 03-Mar-2024, 10:38 PM
  Bringing an old betaflight target into 4.4.0 husafreak 10 1,625 22-Nov-2023, 02:45 PM
  What happens when I load a Betaflight Preset Tune in my FC? husafreak 6 533 07-Nov-2023, 02:56 AM
Last Post: husafreak
  Help Problems with TBS Vendetta and Airmode Oki 3 198 29-Oct-2023, 06:13 PM
Last Post: Oki
  No betaflight connection with just USB aerokam 5 450 20-Oct-2023, 05:44 PM
