Posts: 185 Threads: 81 Likes Received: 14 in 9 posts Likes Given: 17 Joined: Nov 2019 Reputation: 1 I am new to the whole FPV quad flying, I have flown my Mavic Air a lot but it comes as a set, the quad and the transmitter, so I bought a Beta 65 Pro 2 Whoop and as a transmitter I bought the FrSky X-Lite S and am having problems with binding them and am wondering what I am doing wrong??? I pushed on the bind button and the blinking green LED went solid like it is supposed to, then I went into my transmitter and pressed the bind button and the solid green light is supposed to start blinking again and it does not. Also next to the green LED there is a red LED flashing all the time and I can not find any reference to it as to whether it is supposed to be flashing or not. I have watched numerous YouTube videos on how to bind it but there is not a specific video on my two items but there are a few different videos and none of them work either. I am sure there is some info I am leaving out so I will answer any questions as they arise. Thanks Don • Posts: 21,294 Threads: 589 Likes Received: 8,982 in 6,647 posts Likes Given: 1,426 Joined: Jun 2018 Reputation: 789 The FrSky X-Lite S is an ACCESS equipped radio. You need to select D16 mode on the X-Lite when binding to the Beta 65 Pro 2. Just need to check - are you specifically selecting D16 mode when trying to bind? Also, is your X-Lite S an FCC version or an EU-LBT version? • Posts: 185 Threads: 81 Likes Received: 14 in 9 posts Likes Given: 17 Joined: Nov 2019 Reputation: 1 The mode says ACCST D16 And the module is ISRM-S 1.1.0/1.1.2FCC • Posts: 21,294 Threads: 589 Likes Received: 8,982 in 6,647 posts Likes Given: 1,426 Joined: Jun 2018 Reputation: 789 18-Nov-2019, 03:32 AM (This post was last modified: 27-Dec-2019, 10:31 AM by SnowLeopardFPV. Edit Reason: Typo corrections. ) OK, there did used to be a problem binding the new ACCESS equipped transmitters to SPI receivers using ACCST D16 mode but I thought they had fixed it. Maybe the bug is still outstanding. Try the following:- - Connect Betaflight Configurator to the flight controller and go to the "Configuration" tab.
- Ensure that the "Receiver Mode" is set to "SPI RX support" and that the "SPI Bus Receiver Provider" is set to "FRSKY_X", then click the "Save and Reboot" button.
- Reconnect to the flight controller and go to the "CLI" tab.
- Type the "bind_rx_spi" command to put the receiver into binding mode.
- Activate binding in the transmitter. Ignore the status of the green LED because it may not start blinking to indicate a successful bind like it is supposed to.
- In the CLI, type the "get frsky_x_rx_num" command and if the number returned matches that of the one in your transmitter then the bind has been successful.
- In the CLI, type the "save" command and when the flight controller reboots it should be connected with your transmitter.
• Posts: 185 Threads: 81 Likes Received: 14 in 9 posts Likes Given: 17 Joined: Nov 2019 Reputation: 1 • Posts: 21,294 Threads: 589 Likes Received: 8,982 in 6,647 posts Likes Given: 1,426 Joined: Jun 2018 Reputation: 789 So I guess the ACCESS D16 binding bug still exists. Thanks for posting back and letting us know the outcome • Posts: 185 Threads: 81 Likes Received: 14 in 9 posts Likes Given: 17 Joined: Nov 2019 Reputation: 1 I am still having issues, now in BetaFlight, I go to the Receiver tab, none of the values change when I move the controller sticks. I looked on YouTube and it showed how to change the Ports to the different UART's but that did not help. This new FrSky X-Lite S is being a real pain. Thanks for all your help. • Posts: 185 Threads: 81 Likes Received: 14 in 9 posts Likes Given: 17 Joined: Nov 2019 Reputation: 1 And also, on BetFPV's site it says "Do Not Flash The Firmware" but I see the version on my 65 is 4.0 and the version on BetaFlight is 4.1.1 which is a year newer so should I flash it to the newest firmware??? • Posts: 21,294 Threads: 589 Likes Received: 8,982 in 6,647 posts Likes Given: 1,426 Joined: Jun 2018 Reputation: 789 Is the status of the receiver still showing as bound? Please run both the "dump" and "diff all" commands at the CLI and copy/paste the results back here. The reason that BetaFPV say not to update the Betaflight firmware is because they often tune the quad at the factory so it flies nicely. If you update the firmware you will lose that tune and end up having to manually tune it again from scratch yourself, and unless you're have some experience in tuning, that could prove to be difficult. Unfortunately with the newest releases of Betaflight you can't just copy the tune settings from one version to the next. You have to re-tune from scratch again. Unless there is a specific feature or bug fix in the new firmware version that you want, then there probably isn't any reason to update it unless you have OCD about always being on the latest firmware version. Just fly it and enjoy it the way it came from the factory • Posts: 185 Threads: 81 Likes Received: 14 in 9 posts Likes Given: 17 Joined: Nov 2019 Reputation: 1 20-Nov-2019, 11:54 PM (This post was last modified: 20-Nov-2019, 11:55 PM by donwie63.) Here is the dump $M>ÿtARM;ANGLE;HORIZON;HEADFREE;FAILSAFE;HEADADJ;BEEPER;OSD DISABLE SW;TELEMETRY;BLACKBOX;AIR MODE;FPV ANGLE MIX;CAMERA CONTROL 1;CAMERA CONTROL 2;CAMERA CONTROL 3;FLIP OVER AFTER CRASH;PREARM;VTX PIT MODE;PARALYZE;ACRO TRAINER;DISABLE VTX CONTROL;LAUNCH CONTROL;î$M>! Entering CLI Mode, type 'exit' to return, or 'help' # # Building AutoComplete Cache ... Done! # # dump # version # Betaflight / MATEKF411RX (M41R) 4.0.0 Dec 14 2018 / 08:10:09 (6ad257571) MSP API: 1.41 board_name MATEKF411RX manufacturer_id # name name Pro series # resources resource BEEPER 1 C15 resource MOTOR 1 B10 resource MOTOR 2 B06 resource MOTOR 3 B07 resource MOTOR 4 B08 resource MOTOR 5 NONE resource MOTOR 6 NONE resource MOTOR 7 NONE resource MOTOR 8 NONE resource SERVO 1 NONE resource SERVO 2 NONE resource SERVO 3 NONE resource SERVO 4 NONE resource SERVO 5 NONE resource SERVO 6 NONE resource SERVO 7 NONE resource SERVO 8 NONE resource PPM 1 A03 resource PWM 1 A02 resource PWM 2 A09 resource PWM 3 A10 resource PWM 4 NONE resource PWM 5 NONE resource PWM 6 NONE resource PWM 7 NONE resource PWM 8 NONE resource LED_STRIP 1 A00 resource SERIAL_TX 1 A09 resource SERIAL_TX 2 A02 resource SERIAL_TX 3 NONE resource SERIAL_TX 4 NONE resource SERIAL_TX 5 NONE resource SERIAL_TX 6 NONE resource SERIAL_TX 7 NONE resource SERIAL_TX 8 NONE resource SERIAL_TX 9 NONE resource SERIAL_TX 10 NONE resource SERIAL_TX 11 NONE resource SERIAL_RX 1 A10 resource SERIAL_RX 2 A03 resource SERIAL_RX 3 NONE resource SERIAL_RX 4 NONE resource SERIAL_RX 5 NONE resource SERIAL_RX 6 NONE resource SERIAL_RX 7 NONE resource SERIAL_RX 8 NONE resource SERIAL_RX 9 NONE resource SERIAL_RX 10 NONE resource SERIAL_RX 11 NONE resource LED 1 C13 resource LED 2 NONE resource LED 3 NONE resource RX_BIND 1 NONE resource RX_BIND_PLUG 1 B02 resource SPI_SCK 1 A05 resource SPI_SCK 2 B13 resource SPI_SCK 3 B03 resource SPI_MISO 1 A06 resource SPI_MISO 2 B14 resource SPI_MISO 3 B04 resource SPI_MOSI 1 A07 resource SPI_MOSI 2 B15 resource SPI_MOSI 3 B05 resource ESCSERIAL 1 NONE resource CAMERA_CONTROL 1 NONE resource ADC_BATT 1 B00 resource ADC_RSSI 1 NONE resource ADC_CURR 1 B01 resource ADC_EXT 1 NONE resource PINIO 1 NONE resource PINIO 2 NONE resource PINIO 3 NONE resource PINIO 4 NONE resource OSD_CS 1 B12 resource RX_SPI_CS 1 A15 resource RX_SPI_BIND 1 B02 resource RX_SPI_LED 1 B09 resource GYRO_EXTI 1 A01 resource GYRO_EXTI 2 NONE resource GYRO_CS 1 A04 resource GYRO_CS 2 NONE # mixer mixer QUADX mmix reset # servo servo 0 1000 2000 1500 100 -1 servo 1 1000 2000 1500 100 -1 servo 2 1000 2000 1500 100 -1 servo 3 1000 2000 1500 100 -1 servo 4 1000 2000 1500 100 -1 servo 5 1000 2000 1500 100 -1 servo 6 1000 2000 1500 100 -1 servo 7 1000 2000 1500 100 -1 # servo mix smix reset # feature feature -RX_PPM feature -INFLIGHT_ACC_CAL feature -RX_SERIAL feature -MOTOR_STOP feature -SERVO_TILT feature -SOFTSERIAL feature -GPS feature -RANGEFINDER feature -TELEMETRY feature -3D feature -RX_PARALLEL_PWM feature -RX_MSP feature -RSSI_ADC feature -LED_STRIP feature -DISPLAY feature -OSD feature -CHANNEL_FORWARDING feature -TRANSPONDER feature -AIRMODE feature -RX_SPI feature -SOFTSPI feature -ESC_SENSOR feature -ANTI_GRAVITY feature -DYNAMIC_FILTER feature TELEMETRY feature OSD feature RX_SPI feature ANTI_GRAVITY feature DYNAMIC_FILTER # beeper beeper GYRO_CALIBRATED beeper RX_LOST beeper RX_LOST_LANDING beeper DISARMING beeper ARMING beeper ARMING_GPS_FIX beeper BAT_CRIT_LOW beeper BAT_LOW beeper GPS_STATUS beeper RX_SET beeper ACC_CALIBRATION beeper ACC_CALIBRATION_FAIL beeper READY_BEEP beeper MULTI_BEEPS beeper DISARM_REPEAT beeper ARMED beeper SYSTEM_INIT beeper ON_USB beeper BLACKBOX_ERASE beeper CRASH_FLIP beeper CAM_CONNECTION_OPEN beeper CAM_CONNECTION_CLOSE beeper RC_SMOOTHING_INIT_FAIL # beacon beacon GYRO_CALIBRATED beacon -RX_LOST beacon RX_LOST_LANDING beacon DISARMING beacon ARMING beacon ARMING_GPS_FIX beacon BAT_CRIT_LOW beacon BAT_LOW beacon GPS_STATUS beacon -RX_SET beacon ACC_CALIBRATION beacon ACC_CALIBRATION_FAIL beacon READY_BEEP beacon MULTI_BEEPS beacon DISARM_REPEAT beacon ARMED beacon SYSTEM_INIT beacon ON_USB beacon BLACKBOX_ERASE beacon CRASH_FLIP beacon CAM_CONNECTION_OPEN beacon CAM_CONNECTION_CLOSE beacon RC_SMOOTHING_INIT_FAIL # map map TAER1234 # serial serial 20 1 115200 57600 0 115200 serial 0 0 115200 57600 0 115200 serial 1 0 115200 57600 0 115200 # led led 0 0,0::C:0 led 1 0,0::C:0 led 2 0,0::C:0 led 3 0,0::C:0 led 4 0,0::C:0 led 5 0,0::C:0 led 6 0,0::C:0 led 7 0,0::C:0 led 8 0,0::C:0 led 9 0,0::C:0 led 10 0,0::C:0 led 11 0,0::C:0 led 12 0,0::C:0 led 13 0,0::C:0 led 14 0,0::C:0 led 15 0,0::C:0 led 16 0,0::C:0 led 17 0,0::C:0 led 18 0,0::C:0 led 19 0,0::C:0 led 20 0,0::C:0 led 21 0,0::C:0 led 22 0,0::C:0 led 23 0,0::C:0 led 24 0,0::C:0 led 25 0,0::C:0 led 26 0,0::C:0 led 27 0,0::C:0 led 28 0,0::C:0 led 29 0,0::C:0 led 30 0,0::C:0 led 31 0,0::C:0 # color color 0 0,0,0 color 1 0,255,255 color 2 0,0,255 color 3 30,0,255 color 4 60,0,255 color 5 90,0,255 color 6 120,0,255 color 7 150,0,255 color 8 180,0,255 color 9 210,0,255 color 10 240,0,255 color 11 270,0,255 color 12 300,0,255 color 13 330,0,255 color 14 0,0,0 color 15 0,0,0 # mode_color mode_color 0 0 1 mode_color 0 1 11 mode_color 0 2 2 mode_color 0 3 13 mode_color 0 4 10 mode_color 0 5 3 mode_color 1 0 5 mode_color 1 1 11 mode_color 1 2 3 mode_color 1 3 13 mode_color 1 4 10 mode_color 1 5 3 mode_color 2 0 10 mode_color 2 1 11 mode_color 2 2 4 mode_color 2 3 13 mode_color 2 4 10 mode_color 2 5 3 mode_color 3 0 8 mode_color 3 1 11 mode_color 3 2 4 mode_color 3 3 13 mode_color 3 4 10 mode_color 3 5 3 mode_color 4 0 7 mode_color 4 1 11 mode_color 4 2 3 mode_color 4 3 13 mode_color 4 4 10 mode_color 4 5 3 mode_color 5 0 0 mode_color 5 1 0 mode_color 5 2 0 mode_color 5 3 0 mode_color 5 4 0 mode_color 5 5 0 mode_color 6 0 6 mode_color 6 1 10 mode_color 6 2 1 mode_color 6 3 0 mode_color 6 4 0 mode_color 6 5 2 mode_color 6 6 3 mode_color 6 7 6 mode_color 6 8 0 mode_color 6 9 0 mode_color 6 10 0 mode_color 7 0 3 # aux aux 0 0 0 1350 2100 0 0 aux 1 1 1 1300 1700 0 0 aux 2 2 1 1700 2100 0 0 aux 3 28 2 900 1300 0 0 aux 4 35 2 1700 2100 0 0 aux 5 0 0 900 900 0 0 aux 6 0 0 900 900 0 0 aux 7 0 0 900 900 0 0 aux 8 0 0 900 900 0 0 aux 9 0 0 900 900 0 0 aux 10 0 0 900 900 0 0 aux 11 0 0 900 900 0 0 aux 12 0 0 900 900 0 0 aux 13 0 0 900 900 0 0 aux 14 0 0 900 900 0 0 aux 15 0 0 900 900 0 0 aux 16 0 0 900 900 0 0 aux 17 0 0 900 900 0 0 aux 18 0 0 900 900 0 0 aux 19 0 0 900 900 0 0 # adjrange adjrange 0 0 0 900 900 0 0 0 0 adjrange 1 0 0 900 900 0 0 0 0 adjrange 2 0 0 900 900 0 0 0 0 adjrange 3 0 0 900 900 0 0 0 0 adjrange 4 0 0 900 900 0 0 0 0 adjrange 5 0 0 900 900 0 0 0 0 adjrange 6 0 0 900 900 0 0 0 0 adjrange 7 0 0 900 900 0 0 0 0 adjrange 8 0 0 900 900 0 0 0 0 adjrange 9 0 0 900 900 0 0 0 0 adjrange 10 0 0 900 900 0 0 0 0 adjrange 11 0 0 900 900 0 0 0 0 adjrange 12 0 0 900 900 0 0 0 0 adjrange 13 0 0 900 900 0 0 0 0 adjrange 14 0 0 900 900 0 0 0 0 adjrange 15 0 0 900 900 0 0 0 0 adjrange 16 0 0 900 900 0 0 0 0 adjrange 17 0 0 900 900 0 0 0 0 adjrange 18 0 0 900 900 0 0 0 0 adjrange 19 0 0 900 900 0 0 0 0 adjrange 20 0 0 900 900 0 0 0 0 adjrange 21 0 0 900 900 0 0 0 0 adjrange 22 0 0 900 900 0 0 0 0 adjrange 23 0 0 900 900 0 0 0 0 adjrange 24 0 0 900 900 0 0 0 0 adjrange 25 0 0 900 900 0 0 0 0 adjrange 26 0 0 900 900 0 0 0 0 adjrange 27 0 0 900 900 0 0 0 0 adjrange 28 0 0 900 900 0 0 0 0 adjrange 29 0 0 900 900 0 0 0 0 # rxrange rxrange 0 1000 2000 rxrange 1 1000 2000 rxrange 2 1000 2000 rxrange 3 1000 2000 # vtx vtx 0 0 0 0 900 900 vtx 1 0 0 0 900 900 vtx 2 0 0 0 900 900 vtx 3 0 0 0 900 900 vtx 4 0 0 0 900 900 vtx 5 0 0 0 900 900 vtx 6 0 0 0 900 900 vtx 7 0 0 0 900 900 vtx 8 0 0 0 900 900 vtx 9 0 0 0 900 900 # rxfail rxfail 0 a rxfail 1 a rxfail 2 a rxfail 3 a rxfail 4 h rxfail 5 h rxfail 6 h rxfail 7 h rxfail 8 h rxfail 9 h rxfail 10 h rxfail 11 h rxfail 12 h rxfail 13 h rxfail 14 h rxfail 15 h rxfail 16 h rxfail 17 h # master set align_gyro = DEFAULT set gyro_hardware_lpf = NORMAL set gyro_sync_denom = 1 set gyro_lowpass_type = BIQUAD set gyro_lowpass_hz = 150 set gyro_lowpass2_type = PT1 set gyro_lowpass2_hz = 0 set gyro_notch1_hz = 0 set gyro_notch1_cutoff = 0 set gyro_notch2_hz = 0 set gyro_notch2_cutoff = 0 set gyro_calib_duration = 125 set gyro_calib_noise_limit = 48 set gyro_offset_yaw = 0 set gyro_overflow_detect = ALL set yaw_spin_recovery = ON set yaw_spin_threshold = 1950 set gyro_to_use = FIRST set dyn_notch_range = AUTO set dyn_notch_width_percent = 8 set dyn_notch_q = 120 set dyn_notch_min_hz = 150 set dyn_lpf_gyro_min_hz = 150 set dyn_lpf_gyro_max_hz = 450 set align_acc = DEFAULT set acc_hardware = AUTO set acc_lpf_hz = 10 set acc_trim_pitch = 0 set acc_trim_roll = 0 set acc_calibration = -330,-33,12 set mid_rc = 1500 set min_check = 1050 set max_check = 1900 set rssi_channel = 0 set rssi_src_frame_errors = OFF set rssi_scale = 100 set rssi_offset = 0 set rssi_invert = OFF set rc_interp = AUTO set rc_interp_ch = RPYT set rc_interp_int = 19 set rc_smoothing_type = FILTER set rc_smoothing_input_hz = 0 set rc_smoothing_derivative_hz = 0 set rc_smoothing_debug_axis = ROLL set rc_smoothing_input_type = BIQUAD set rc_smoothing_derivative_type = BIQUAD set rc_smoothing_auto_smoothness = 10 set fpv_mix_degrees = 35 set max_aux_channels = 14 set serialrx_provider = SPEK1024 set serialrx_inverted = OFF set spektrum_sat_bind = 0 set spektrum_sat_bind_autoreset = ON set airmode_start_throttle_percent = 32 set rx_min_usec = 885 set rx_max_usec = 2115 set serialrx_halfduplex = OFF set rx_spi_protocol = FRSKY_X set rx_spi_bus = 3 set rx_spi_led_inversion = ON set adc_device = 1 set adc_vrefint_calibration = 0 set adc_tempsensor_calibration30 = 0 set adc_tempsensor_calibration110 = 0 set input_filtering_mode = OFF set blackbox_p_ratio = 32 set blackbox_device = SERIAL set blackbox_record_acc = ON set blackbox_mode = NORMAL set min_throttle = 1070 set max_throttle = 2000 set min_command = 1000 set dshot_idle_value = 450 set dshot_burst = OFF set use_unsynced_pwm = OFF set motor_pwm_protocol = DSHOT600 set motor_pwm_rate = 480 set motor_pwm_inversion = OFF set motor_poles = 14 set thr_corr_value = 0 set thr_corr_angle = 800 set failsafe_delay = 4 set failsafe_off_delay = 10 set failsafe_throttle = 1000 set failsafe_switch_mode = STAGE1 set failsafe_throttle_low_delay = 100 set failsafe_procedure = DROP set align_board_roll = 0 set align_board_pitch = 0 set align_board_yaw = 0 set gimbal_mode = NORMAL set bat_capacity = 0 set vbat_max_cell_voltage = 43 set vbat_full_cell_voltage = 41 set vbat_min_cell_voltage = 33 set vbat_warning_cell_voltage = 35 set vbat_hysteresis = 1 set current_meter = NONE set battery_meter = ADC set vbat_detect_cell_voltage = 30 set use_vbat_alerts = ON set use_cbat_alerts = OFF set cbat_alert_percent = 10 set vbat_cutoff_percent = 100 set force_battery_cell_count = 0 set vbat_scale = 110 set vbat_divider = 10 set vbat_multiplier = 1 set ibata_scale = 179 set ibata_offset = 0 set ibatv_scale = 0 set ibatv_offset = 0 set beeper_inversion = ON set beeper_od = OFF set beeper_frequency = 0 set beeper_dshot_beacon_tone = 1 set yaw_motors_reversed = ON set crashflip_motor_percent = 0 set 3d_deadband_low = 1406 set 3d_deadband_high = 1514 set 3d_neutral = 1460 set 3d_deadband_throttle = 50 set 3d_limit_low = 1000 set 3d_limit_high = 2000 set 3d_switched_mode = OFF set servo_center_pulse = 1500 set servo_pwm_rate = 50 set servo_lowpass_hz = 0 set tri_unarmed_servo = ON set channel_forwarding_start = 4 set reboot_character = 82 set serial_update_rate_hz = 100 set imu_dcm_kp = 2500 set imu_dcm_ki = 0 set small_angle = 180 set auto_disarm_delay = 5 set gyro_cal_on_first_arm = OFF set gps_provider = NMEA set gps_sbas_mode = AUTO set gps_auto_config = ON set gps_auto_baud = OFF set gps_ublox_use_galileo = OFF set gps_rescue_angle = 32 set gps_rescue_initial_alt = 50 set gps_rescue_descent_dist = 200 set gps_rescue_ground_speed = 2000 set gps_rescue_throttle_p = 150 set gps_rescue_throttle_i = 20 set gps_rescue_throttle_d = 50 set gps_rescue_velocity_p = 80 set gps_rescue_velocity_i = 20 set gps_rescue_velocity_d = 15 set gps_rescue_yaw_p = 40 set gps_rescue_throttle_min = 1200 set gps_rescue_throttle_max = 1600 set gps_rescue_throttle_hover = 1280 set gps_rescue_sanity_checks = RESCUE_SANITY_ON set gps_rescue_min_sats = 8 set gps_rescue_min_dth = 100 set deadband = 0 set yaw_deadband = 0 set yaw_control_reversed = OFF set pid_process_denom = 1 set runaway_takeoff_prevention = ON set runaway_takeoff_deactivate_delay = 500 set runaway_takeoff_deactivate_throttle_percent = 20 set tlm_inverted = OFF set tlm_halfduplex = ON set frsky_default_lat = 0 set frsky_default_long = 0 set frsky_gps_format = 0 set frsky_unit = IMPERIAL set frsky_vfas_precision = 0 set hott_alarm_int = 5 set pid_in_tlm = OFF set report_cell_voltage = OFF set ibus_sensor = 1,2,3,0,0,0,0,0,0,0,0,0,0,0,0 set mavlink_mah_as_heading_divisor = 0 set telemetry_disabled_sensors = 491520 set ledstrip_visual_beeper = OFF set ledstrip_grb_rgb = GRB set osd_units = METRIC set osd_warn_arming_disable = ON set osd_warn_batt_not_full = ON set osd_warn_batt_warning = ON set osd_warn_batt_critical = ON set osd_warn_visual_beeper = ON set osd_warn_crash_flip = ON set osd_warn_esc_fail = ON set osd_warn_core_temp = OFF set osd_warn_rc_smoothing = OFF set osd_warn_fail_safe = OFF set osd_warn_launch_control = OFF set osd_rssi_alarm = 20 set osd_cap_alarm = 2200 set osd_alt_alarm = 100 set osd_esc_temp_alarm = -128 set osd_esc_rpm_alarm = -1 set osd_esc_current_alarm = -1 set osd_core_temp_alarm = 70 set osd_ah_max_pit = 20 set osd_ah_max_rol = 40 set osd_ah_invert = OFF set osd_tim1 = 2560 set osd_tim2 = 2561 set osd_vbat_pos = 2433 set osd_rssi_pos = 2241 set osd_link_quality_pos = 234 set osd_tim_1_pos = 234 set osd_tim_2_pos = 2455 set osd_remaining_time_estimate_pos = 234 set osd_flymode_pos = 2423 set osd_anti_gravity_pos = 234 set osd_g_force_pos = 234 set osd_throttle_pos = 2401 set osd_vtx_channel_pos = 234 set osd_crosshairs_pos = 2285 set osd_ah_sbar_pos = 206 set osd_ah_pos = 78 set osd_current_pos = 234 set osd_mah_drawn_pos = 234 set osd_motor_diag_pos = 234 set osd_craft_name_pos = 2441 set osd_gps_speed_pos = 234 set osd_gps_lon_pos = 234 set osd_gps_lat_pos = 234 set osd_gps_sats_pos = 234 set osd_home_dir_pos = 234 set osd_home_dist_pos = 234 set osd_flight_dist_pos = 234 set osd_compass_bar_pos = 234 set osd_altitude_pos = 234 set osd_pid_roll_pos = 234 set osd_pid_pitch_pos = 234 set osd_pid_yaw_pos = 234 set osd_debug_pos = 234 set osd_power_pos = 234 set osd_pidrate_profile_pos = 234 set osd_warnings_pos = 2378 set osd_avg_cell_voltage_pos = 234 set osd_pit_ang_pos = 234 set osd_rol_ang_pos = 234 set osd_battery_usage_pos = 234 set osd_disarmed_pos = 234 set osd_nheading_pos = 234 set osd_esc_tmp_pos = 234 set osd_esc_rpm_pos = 234 set osd_rtc_date_time_pos = 234 set osd_adjustment_range_pos = 234 set osd_flip_arrow_pos = 234 set osd_core_temp_pos = 234 set osd_log_status_pos = 234 set osd_stick_overlay_left_pos = 234 set osd_stick_overlay_right_pos = 234 set osd_stick_overlay_radio_mode = 2 set osd_stat_rtc_date_time = OFF set osd_stat_tim_1 = OFF set osd_stat_tim_2 = ON set osd_stat_max_spd = ON set osd_stat_max_dist = OFF set osd_stat_min_batt = ON set osd_stat_endbatt = OFF set osd_stat_battery = OFF set osd_stat_min_rssi = ON set osd_stat_max_curr = ON set osd_stat_used_mah = ON set osd_stat_max_alt = OFF set osd_stat_bbox = ON set osd_stat_bb_no = ON set osd_stat_max_g_force = OFF set osd_stat_max_esc_temp = OFF set osd_stat_max_esc_rpm = OFF set osd_stat_min_link_quality = OFF set osd_stat_flight_dist = OFF set osd_profile = 1 set system_hse_mhz = 8 set task_statistics = ON set debug_mode = NONE set rate_6pos_switch = OFF set cpu_overclock = OFF set pwr_on_arm_grace = 5 set vtx_band = 4 set vtx_channel = 4 set vtx_power = 1 set vtx_low_power_disarm = OFF set vtx_freq = 5800 set vtx_pit_mode_freq = 0 set vtx_halfduplex = ON set vcd_video_system = AUTO set vcd_h_offset = 0 set vcd_v_offset = 0 set max7456_clock = DEFAULT set max7456_spi_bus = 2 set max7456_preinit_opu = OFF set displayport_msp_col_adjust = 0 set displayport_msp_row_adjust = 0 set displayport_max7456_col_adjust = 0 set displayport_max7456_row_adjust = 0 set displayport_max7456_inv = OFF set displayport_max7456_blk = 0 set displayport_max7456_wht = 2 set esc_sensor_halfduplex = OFF set esc_sensor_current_offset = 0 set frsky_spi_autobind = OFF set frsky_spi_tx_id = 10,167 set frsky_spi_offset = -21 set frsky_spi_bind_hop_data = 6,219,199,179,159,162,6,85,164,8,87,166,10,89,168,12,91,170,14,93,172,16,95,174,18,97,176,20,99,178,22,101,180,24,103,182,26,105,184,28,107,186,30,109,188,32,111,0,0,0 set frsky_x_rx_num = 2 set frsky_spi_use_external_adc = OFF set led_inversion = 0 set camera_control_mode = HARDWARE_PWM set camera_control_ref_voltage = 330 set camera_control_key_delay = 180 set camera_control_internal_resistance = 470 set camera_control_inverted = OFF set pinio_config = 1,1,1,1 set pinio_box = 255,255,255,255 set usb_hid_cdc = OFF set rcdevice_init_dev_attempts = 6 set rcdevice_init_dev_attempt_interval = 1000 set gyro_1_bustype = SPI set gyro_1_spibus = 1 set gyro_1_i2cBus = 0 set gyro_1_i2c_address = 0 set gyro_1_sensor_align = CW180 set gyro_2_bustype = SPI set gyro_2_spibus = 1 set gyro_2_i2cBus = 0 set gyro_2_i2c_address = 0 set gyro_2_sensor_align = DEFAULT # profile profile 0 set dyn_lpf_dterm_min_hz = 150 set dyn_lpf_dterm_max_hz = 250 set dterm_lowpass_type = BIQUAD set dterm_lowpass_hz = 150 set dterm_lowpass2_type = BIQUAD set dterm_lowpass2_hz = 150 set dterm_notch_hz = 0 set dterm_notch_cutoff = 0 set vbat_pid_gain = OFF set pid_at_min_throttle = ON set anti_gravity_mode = SMOOTH set anti_gravity_threshold = 250 set anti_gravity_gain = 5000 set feedforward_transition = 0 set acc_limit_yaw = 0 set acc_limit = 0 set crash_dthreshold = 50 set crash_gthreshold = 400 set crash_setpoint_threshold = 350 set crash_time = 500 set crash_delay = 0 set crash_recovery_angle = 10 set crash_recovery_rate = 100 set crash_limit_yaw = 200 set crash_recovery = OFF set iterm_rotation = ON set smart_feedforward = OFF set iterm_relax = RP set iterm_relax_type = SETPOINT set iterm_relax_cutoff = 20 set iterm_windup = 100 set iterm_limit = 400 set pidsum_limit = 500 set pidsum_limit_yaw = 400 set yaw_lowpass_hz = 0 set throttle_boost = 5 set throttle_boost_cutoff = 15 set acro_trainer_angle_limit = 20 set acro_trainer_lookahead_ms = 50 set acro_trainer_debug_axis = ROLL set acro_trainer_gain = 75 set p_pitch = 50 set i_pitch = 75 set d_pitch = 32 set f_pitch = 60 set p_roll = 46 set i_roll = 65 set d_roll = 30 set f_roll = 60 set p_yaw = 45 set i_yaw = 100 set d_yaw = 0 set f_yaw = 100 set angle_level_strength = 50 set horizon_level_strength = 50 set horizon_transition = 75 set level_limit = 55 set horizon_tilt_effect = 75 set horizon_tilt_expert_mode = OFF set abs_control_gain = 0 set abs_control_limit = 90 set abs_control_error_limit = 20 set abs_control_cutoff = 11 set launch_control_mode = NORMAL set launch_trigger_allow_reset = ON set launch_trigger_throttle_percent = 20 set launch_angle_limit = 0 set launch_control_gain = 40 # rateprofile rateprofile 0 set thr_mid = 50 set thr_expo = 0 set rates_type = BETAFLIGHT set roll_rc_rate = 100 set pitch_rc_rate = 100 set yaw_rc_rate = 100 set roll_expo = 0 set pitch_expo = 0 set yaw_expo = 0 set roll_srate = 70 set pitch_srate = 70 set yaw_srate = 70 set tpa_rate = 50 set tpa_breakpoint = 1500 set tpa_mode = D set throttle_limit_type = OFF set throttle_limit_percent = 100 set roll_rate_limit = 1998 set pitch_rate_limit = 1998 set yaw_rate_limit = 1998 Here is diff all $M>ÿtARM;ANGLE;HORIZON;HEADFREE;FAILSAFE;HEADADJ;BEEPER;OSD DISABLE SW;TELEMETRY;BLACKBOX;AIR MODE;FPV ANGLE MIX;CAMERA CONTROL 1;CAMERA CONTROL 2;CAMERA CONTROL 3;FLIP OVER AFTER CRASH;PREARM;VTX PIT MODE;PARALYZE;ACRO TRAINER;DISABLE VTX CONTROL;LAUNCH CONTROL;î$M>! $M>ni Entering CLI Mode, type 'exit' to return, or 'help' # # Building AutoComplete Cache ... Done! # # diff all # version # Betaflight / MATEKF411RX (M41R) 4.0.0 Dec 14 2018 / 08:10:09 (6ad257571) MSP API: 1.41 board_name MATEKF411RX manufacturer_id mcu_id 003e00573337510c33393338 signature # reset configuration to default settings defaults nosave # name name Pro series # resources # mixer # servo # servo mix # feature # beeper # beacon # map map TAER1234 # serial # led # color # mode_color # aux aux 0 0 0 1350 2100 0 0 aux 1 1 1 1300 1700 0 0 aux 2 2 1 1700 2100 0 0 aux 3 28 2 900 1300 0 0 aux 4 35 2 1700 2100 0 0 # adjrange # rxrange # vtx # rxfail # master set acc_calibration = -330,-33,12 set fpv_mix_degrees = 35 set dshot_idle_value = 450 set motor_pwm_protocol = DSHOT600 set current_meter = NONE set yaw_motors_reversed = ON set small_angle = 180 set pid_process_denom = 1 set osd_warn_core_temp = OFF set osd_warn_rc_smoothing = OFF set osd_warn_fail_safe = OFF set osd_warn_launch_control = OFF set osd_vbat_pos = 2433 set osd_rssi_pos = 2241 set osd_tim_2_pos = 2455 set osd_flymode_pos = 2423 set osd_throttle_pos = 2401 set osd_crosshairs_pos = 2285 set osd_craft_name_pos = 2441 set osd_warnings_pos = 2378 set vtx_channel = 4 set vtx_freq = 5800 set frsky_spi_tx_id = 10,167 set frsky_spi_offset = -21 set frsky_spi_bind_hop_data = 6,219,199,179,159,162,6,85,164,8,87,166,10,89,168,12,91,170,14,93,172,16,95,174,18,97,176,20,99,178,22,101,180,24,103,182,26,105,184,28,107,186,30,109,188,32,111,0,0,0 set frsky_x_rx_num = 2 # profile profile 0 # profile profile 1 # profile profile 2 # restore original profile selection profile 0 # rateprofile rateprofile 0 # rateprofile rateprofile 1 # rateprofile rateprofile 2 # rateprofile rateprofile 3 # rateprofile rateprofile 4 # rateprofile rateprofile 5 # restore original rateprofile selection rateprofile 0 # save configuration save Write your command here. Press Tab for AutoComplete. • Posts: 185 Threads: 81 Likes Received: 14 in 9 posts Likes Given: 17 Joined: Nov 2019 Reputation: 1 And yes it is still bound Thanks for all your help Don • Posts: 21,294 Threads: 589 Likes Received: 8,982 in 6,647 posts Likes Given: 1,426 Joined: Jun 2018 Reputation: 789 Sorry for the delay in responding. I somehow missed your reply. All your Betaflight settings look to be correct for an SPI receiver so it is either a binding issue or a hardware issue. I suggest you start from scratch by deleting the model on your X-Lite S and creating a brand new one. Then re-bind that newly created model to the Beta65 Pro 2. • Posts: 185 Threads: 81 Likes Received: 14 in 9 posts Likes Given: 17 Joined: Nov 2019 Reputation: 1 Well.... So far that worked. Now I am trying to setup all the switches and go for a test flight. Thanks so much, so far this is the only help I have gotten, I contacted BetaFPV and they were no help at all. Again, Thanks Don • Posts: 21,294 Threads: 589 Likes Received: 8,982 in 6,647 posts Likes Given: 1,426 Joined: Jun 2018 Reputation: 789 That's great news. At least you can now go flying Manufacturers aren't always that helpful, plus there is usually a bit of a language barrier so it can sometimes make it difficult to get across what the issue is and get an appropriate resolution back. • Posts: 26 Threads: 4 Likes Received: 4 in 4 posts Likes Given: 7 Joined: Dec 2019 Reputation: 0 im new to fpv too .. if you like watching videos u might like my videos i started an fpv reality show • |
