Armattan Quads 4" Micro Long Range " Bobcat"
The Gecko 4 inch is supposed to weigh 45 grams and with no props in view I’m curious why the Gecko wasn’t a LR candidate?
If anyone has built Gecko 4” was you able to stay under 250 with battery?
Yea the more I look closely at this frame, the more worried I am about how to approach this. Closer inspection would suggest a whoop FC up front with a 20x20 in back is a no go. I think this frame is either dual 20x20's or single whoop. Hmmmm...
4" Long Range is new.
It works so wondefully because of space for Vista/DJI.
More nice frames will come.
But, the real problem isnt the easy for anyone to draw shape and get cut carbon fiber....
Caddx/DJI need to make a more integrated solution - they need to make a FC/ESC. Half DJI Air is power cir cuitry - redundant.
I dont like H frames. Gecko frame is ugly.
I like simplicity of unibody plate.
Whoop diamomd was to avoid props, and lets you get slightly smaller wheelbase. Not issue for LR.
#19
(16-Jan-2021, 06:38 PM)Rob3ddd Wrote: The Gecko 4 inch is supposed to weigh 45 grams and with no props in view I’m curious why the Gecko wasn’t a LR candidate?
Unless you use a FPV camera with narrow angle of view, you will get props in view with most Fpv camera including DJI HD camera.
I built  one with 1507/ Vista. 198g  dry weight.
With a small  650mah 4S, it's already over  by 30g.
With 1404 motors, you could shave 20g plus a few more grams with lighter props.
[Image: 20210117-120334-01.jpg]
[Image: 20210117-120105-01.jpg]
YouTube - Juicy FPV Journey
[-] The following 1 user Likes jasperfpv's post:
  • Rob3ddd
#20
(16-Jan-2021, 08:01 PM)the.ronin Wrote: Yea the more I look closely at this frame, the more worried I am about how to approach this.  Closer inspection would suggest a whoop FC up front with a 20x20 in back is a no go.  I think this frame is either dual 20x20's or single whoop.  Hmmmm...
Their spec says dual 20x20 or 16x16mm stack.
I wonder what those 4 oblong holes at the rear is for.
#21
Yea I was thinking of using a whoop adapter in the front 20x20. I was guessing those oblong holes were some sort of securing holes for a DJI Air Unit but I'm still flying analog so that was just a guess. I'm looking at some AIO 20x20's now since I'd really like to avoid a full 20x20 stack on this already heavy frame. But I can only find F4 ones.
#22
(17-Jan-2021, 04:06 AM)the.ronin Wrote: Yea I was thinking of using a whoop adapter in the front 20x20. I was guessing those oblong holes were some sort of securing holes for a DJI Air Unit but I'm still flying analog so that was just a guess. I'm looking at some AIO 20x20's now since I'd really like to avoid a full 20x20 stack on this already heavy frame. But I can only find F4 ones.
There's the Flywoo Goku HD 745 Evo:
https://www.racedayquads.com/products/fl...t-4in1-esc
20x20 mounting holes, but the board is
41x32. Still, not bad for a F7 FC with 7 UARTs, blackbox flash, baro, 9V and 5V BECs, and a 40A 32 bit ESC. Only 8.5g too.
  • the.ronin
#23
Oh nice find! You're right though that size might still be too big for it but might still work. Thanks!
  Long Range Setup für 2024 Kepnik 1 548 16-Mar-2024, 12:15 AM
Last Post: Phoenix.-
  Help Recommended ESCs for 7" quads?? BigBeard 2 266 07-Mar-2024, 12:37 PM
Last Post: MomoBrut
  5" Mid range motor sizing help B4tn 4 410 01-Mar-2024, 12:25 AM
Last Post: B4tn
  Build APEX 6 HD long range MomoBrut 34 4,160 15-Jan-2024, 02:23 PM
Last Post: Diver
  Build Best Long Range Antenna for O3 Airunit Akuzo 7 4,938 10-Jan-2024, 01:45 PM
Last Post: Klingus
