04-Apr-2020, 03:29 PM
As a fan of building toothpicks I always like the challenge of builds at this size.
My latest project is a 3s-4s toothpick, mainly to use up the 400-500mah batteries that I have lying around not getting used. Pathetic excuse for another build right? lol..
With a combination of parts lying around and some random purchases I got together this spec.
Here it is with the 4S pack ready for rippage.
In the pic below you can see the crossfire mini antenna and the baby ratel joystick control plug stick out the back.
Hope to get some DVR action soon.
To do list.
ph2t.
- BetaFPV HX115 - 3" frame
- T-motor 1106 6000kV motors
- GEMFAN Hurricane 3018-2 props (these are badass)
- NamelessRC 412T AIO FC, 2-4S
- A Buzzer - stashed under the RX which is under the FC
- CRSF nano RX with the mini immo-T antenna - so cool..
- CADDX Baby Ratel - this cam is nice, yet to test fully but if it's like the big Ratel then I'll be happy.
- AKK "backpack" VTX and MMCX dipole antenna - not my first choice and the antenna mount is not the best - i might change it out after a couple of crashes, will see how it performs.
- TPU canopy print sourced from thingyverse - it's a low profile canopy with a thick core. Works well to keep the jello out albeit it is quick heavy and not suited to light weight toothpicks or whoops.
To do list.
- Prelim PID tune put in place, reduced all PIDs using sliders to 0.9, 0.8 and stock on the three PID Profiles.
- Maiden flight will be a 4S tune on lowest PIDs for safety and reduce the chance of a flyaway.
- BF 4.1 installed
- RPM filters not installed yet - to confirm issue with the namelessrc FC and the BLheliS firmware before going forward.
- Fine tune baby ratel camera
- Might change out to a nano vtx depending on how well the akk vtx works out after a crash or several.
ph2t.
