Threads: 36
Likes Received: 13 in 9 posts
Likes Given: 54
0 I have connected 4 LED strips (WS2812),
They are connected directly to the FC sockets (SucceX-E F4),
When I try to configure it in Betaflight, It claims that I have 32 (+1) LEDs, but after defining 32 LEDs on the wiring diagram, It lights all #1 LEDs in the same color, then, all the #2 LEDs in the same color, etc...
What am I missing ? each strip has actually 6 LEDs.
I want each strip to light in different color...
Threads: 589
Likes Received: 8,982 in 6,647 posts
Likes Given: 1,426
789 You need to chain each LED strip together, one after the other. Only the first strip actually connects to the FC.
So connect the first strip to the FC, then the second strip to the end of the first strip, then the third strip to the end of the second strip, and finally the fourth strip to the end of the third strip.
Threads: 36
Likes Given: 54
0 Off course I trust your knowledge, but it sounds weird, as there are 4 led sockets in the FC, so what are they there for ?
Threads: 589
Likes Given: 1,426
789 You can only use the individual sockets if you want all strips to behave exactly the same (i.e. they are wired in parallel, so LED 1 on ALL strips do whatever you programmed LED 1 to do in betaflight, LED 2 on ALL strips will do whatever you programmed as LED 2 to do in Betaflight, and so on). If you want every single LED to be individually programmable, you have to chain the strips together.
Have a watch of the following video...
Threads: 36
Likes Given: 54
0 Yep, that's exactly how they behave.
So I'll have to live with that behavior for now. very weird that Betaflight doesn't know to deal with 4 sockets...
At least my companion will be able to see the quad far away, even though he won't be able to know whether it is flying away or towards us.
Next time I'll wire them in series.
Thanks a lot
