10-Jul-2019, 10:49 AM
So I've decided to jump on the toothpick hype-wagon. But I've always wanted to try a 3D printed frame, so this seemed to be a great way to start. Small, simple, easy to print again if it breaks.
So here we go, first some specs:
Frame: 3D Printed in PETG, model: https://www.thingiverse.com/thing:3563189
Canopy: 3D Printed in TPU, model: https://www.thingiverse.com/thing:3578160
Stack: iFlight SucceX F4 Whoop FC + VTX
Motors: Kingkong 1103 7800KV (1mm shaft)
Props: Kingkong 65mm 2-blade (1mm hole)
Camera: Caddx EOS2
RX: Frsky XM
Now some pictures!
Frame printed with PETG:
Motors and RX:
FC+VTX stack:
The ESC has a standard whoop motor plugs, but I decided to solder directly, so I removed the plastic plugs and desoldered the pins. Now I can solder the motor wires directly:
Motors and XT30 pigtail soldered (who can notice what did I do wrong here?):
Then I sort of forgotten to take pictures
Now I have the camera and RX soldered, camera stuck in the canopy, motors fitted on frame (using 2 M2 screws for each):
And here's almost complete product. Antenna fitted in canopy, stack screwed in the frame:
Everything is done! RX bound, Betaflight set up, ready to rock'n'roll!
It's coming in quite light. 49g dry weight, 68g AUW with 300mAh 2S battery. Not baaaad.
I took it for a spin yesterday. It was quite windy, but I went for it anyway. It flies like a dream! Surprisingly smooth, rather powerful (see the throttle value on the OSD). I'm running props out and default PIDs that came with the FC (not sure if those are default, gotta check later). It came on 4.0.2 from the factory.
Here's a video from the maiden:
Strangely enough, I got an RXLOSS once or twice for a split second despite the quite high RSSI. Not long enough to failsafe, but long enough for me to feel it on the sticks. I think the RX antenna is not placed very well, gotta take a look at it.
Unfortunately, the crash at the end of the video resulted in a broken frame. As expected, 3D printed frames are not very strong. And especially on my printer, I think it's not doing such a good job with PETG - the layers don't stick together so well. I'm printing a new frame at the moment, using higher temp and 10% increased flow rate, let's see if that helps.
Camera: Caddx EOS2
RX: Frsky XM
Now some pictures!
Motors and RX:
FC+VTX stack:
