11-Jun-2021, 11:49 PM
The Challenge: To build a dual purpose Sub 250g flyer that's a capable freestyle monster as well as a cinematic fun flying machine.
Background: I recently had a baby girl, and I'm limited to yard flying most of the time now, and I felt I needed to go ahead and put together something easier and quieter to fly around. In the process of this, I also realized that a 3" can be a quite capable cinematic machine via a GoPro Lite and with adequate KV, should be tons of fun for freestyle as well. This sounds like a win win in my book. Who doesn't want a drone that can fit in your pocket, capture 4k stabilized footage, and freestyle anywhere, because its size doesn't offend anyone?
Quick 14 second teaser vid then on to the parts of the build!
Frame:
I saw this smaller frame designer, and have been wanting to support him for some time. I ended up grabbing his Moka Mikro HD frame in case I later went Digital.
Motors:
I really toiled over this one. There's the venerable 1105s, but they just are underpowered for freestyle it seems. They also aren't as efficient as I wish. Then there was the 1207 RCinPower motors that seemed perfect, but were NEVER in stock, and were known to have cooling issues due to the design. I initially settled on the Emax 1306B ,but they don't fit this frame with mounting for 9x9 only.
Finally I settled on the Xing 1404 4600KV. Due to the wider stator, the extra torque is great for slow flying and control of the quad with or without the gopro, and the KV allows plenty of power to recover from dives, loops, etc. I saw ummagawd both freestyles and flies gigs with these motors, although he now prefers the 1207KV due to the top end power.
The Heart:
I went with an Aikon F4 Stack. This stack was honestly intended to go into a racer, but I repurposed it. It is overkill, and I probably could save a bit of weight with a 25a AIO, but who cares for now. I have plenty of drones these days, but even more parts, so I'm going to start using parts instead of holding for another build
VTX:
I went with a TBS Pro Nano 32 - clean video, reliable, and only $30 so why not lol. It is TINY by the way, and it saves a bit of weight from other options. I also considered a tramp nano, which I use in my freestyle rig, but since I had this one sitting around, I used it.
FPV Cam:
Runcam Phoenix 2 Nano Cam - great color, great camera, and I'm a fan of the phoenix 2 line. CROSSFIRE EVERYTHING
probably no explanation needed here
HD Cam
GoPro Hero 6 Lite by way of the Beta V2 kit - not too many issues here, but it was nervewrecking to take apart the GoPro. All seems to work without issue, and I can reelsteady the footage if I want as well!
Here are some photos of the finished build
I'll maiden the drone in a few days once these rainstorms and heavy winds pass in the NorthEast. It was literally 90 degrees , but my lazy self didnt get the build finished in time, so I have to wait for the next window.
I hope you enjoyed the build thread! This was 216 until I shortened the cables for the build appropriately.
Frame:
- Full 3K premium quality and rigid carbon fiber.
- 3mm unibody T300 carbon.
- light weight with only 25g.
- 3mm top plate with 20x20 holes for Caddx Vista
- 3D print camera mount designed for both DJI HD and Caddx Nebula.
- 23mm large inside height , easy to fit Caddx Vista and Flight controller but you can change standoff to get more romes
- 16x16, 20x20mm and 25.5x25.5mm FC mounting hole(enough for all board style
Motors:
The Heart:
VTX:
FPV Cam:
HD Cam
