2 of the motors are on reverse
Hi good morning, I replace the flight controller on my meteor 75 and I don’t know how to set un the new controller, doesn’t have USB port and have silverware firmware.
Is a BetaFPV Lite 1S Brushless Flight Controller, I don’t know how to make this motors spin correctly.
Thanks.
Just swap over any two of the 3 pins in the plug of the motors that are spinning the wrong way and that will reverse the motor direction.
Thank you so much, I’ll try that
No problem. Happy flying Smile
  SpeedyBee F405 V3 Testing Motors (Not Spinning) angent56 20 2,961 07-May-2024, 02:53 PM
Last Post: mstc
  Help Flight Controller only works with USB, motors turn on, but not on battery only Gabiru 3 2,107 16-Feb-2023, 06:48 PM
  Solved Motors Spin Up To Max - On the Bench or With Props CuriousGeorge 0 329 13-Mar-2021, 01:54 PM
Last Post: CuriousGeorge
  Help Motors stuttering - Is my gyro bad? mivo_ 4 939 21-Sep-2020, 07:45 PM
Last Post: mivo_
  Solved Motors 1 and 4 won't spin on new FC WormBurner 19 1,391 09-Jun-2020, 12:33 PM
Last Post: WormBurner
