Motors stuttering - Is my gyro bad?
Hello there,
after having renewed my build with new motors T-Motor VELOX and FC Racerstar & Airbot AirF7, I few days ago I decided to take it on a field for a maiden flight and some lite PID tuning
Unfortunately, almost since the beginning I started having intermittent “jerks” here and there, while simply cruising around.
Sadly I brought my build back home and decided to have a look into blackbox explorer to find some clues.
While reviewing the log, I noticed a few suspect spikes on Gyro + PID yaw values.
After a brief research I read those symptoms I'm having could be related to a defective gyro, is this right?
Below I provide log for anyone who want to help me :-)
BB Log
Blackbox Explorer screenshot
Thanks!
Do you have a capacitor on the lipo pad?
(20-Sep-2020, 10:25 PM)voodoo614 Wrote: Do you have a capacitor on the lipo pad?
Yes sir, a LOW ESR 35v 470 mf provided with the very same ESC.
Have you noticed something wrong?
Yaw twitch usually is noise related. I usually run 1000uf on a 5 inch. Not sure what size quad you are using.
Maybe one of the residents Blackbox guru here can help you filter out the noise. The other thing to do is increase the filtration in the PID using the slider.
(21-Sep-2020, 05:48 PM)voodoo614 Wrote: Yaw twitch usually is noise related. I usually run 1000uf on a 5 inch. Not sure what size quad you are using.
I'm on 5 inch too...
Hope someone will help me Huh
  SpeedyBee F405 V3 Testing Motors (Not Spinning) angent56 20 2,961 07-May-2024, 02:53 PM
Last Post: mstc
  Avoid the updated JHEMCU GHF420AIO with the ICM42688-P Gyro Recursion 19 3,422 08-Mar-2024, 09:33 AM
Last Post: swequad
  Announcement PSA: BMI270 Gyro - Hardware / Tracking Issue SnowLeopardFPV 25 1,757 07-Feb-2024, 02:39 PM
Last Post: Luk5569
  Gyro Filteration marv23 5 288 16-Jan-2024, 12:53 PM
Last Post: marv23
  Help Replace ICM gyro with BMI270 romangpro 0 224 06-Dec-2023, 11:56 AM
Last Post: romangpro
