Posts: 24 Threads: 11 Likes Received: 1 in 1 posts Likes Given: 2 Joined: May 2020 Reputation: 0 05-Aug-2020, 06:02 PM (This post was last modified: 07-Aug-2020, 06:41 PM by AshBird78.) Hi all, I recently bought the Radiomaster TX16S to replace the transmitter that came with the novice 2 bundle. Sadly, I've no clue what I'm doing and after following along with a few videos, I have not managed to bind my Novice, or found how to set switch placement. Any help would be much appreciated because I'm lost and I can't wait to try this thing out. Cheers • Posts: 12,099 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 What receiver do you have? How are you trying to bind? Lets get it bound first. Then we can discuss BF setting to get the stick control working. • Posts: 24 Threads: 11 Likes Received: 1 in 1 posts Likes Given: 2 Joined: May 2020 Reputation: 0 06-Aug-2020, 07:06 AM (This post was last modified: 06-Aug-2020, 07:06 AM by AshBird78.) Thank you for the reply, appreciate you taking the time to help me out. It's got a Internal Frsky NON-EU receiver. Using the quad model, I set it to FrSky D8, then press and hold the button on my quad and hit bind on the transmitter, but nothing seems to happen. The instruction manual doesn't really cover anything and I can't seem to find anything more extensive online. • Posts: 21,263 Threads: 587 Likes Received: 8,969 in 6,637 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 788 06-Aug-2020, 09:24 AM (This post was last modified: 06-Aug-2020, 09:25 AM by SnowLeopardFPV.) To bind your receiver to the transmitter, do the following:- - Put your transmitter into FrSky D8 binding mode so that it chirps and leave it like that.
- With the LiPo and USB cable disconnected, press and hold down the bind button and then plug in a USB cable while still holding down the button. This should then cause the binding process to initiate and complete.
- Disconnect power from the flight controller by removing the USB cable.
- Take the transmitter out of binding mode.
- Re-apply power to the flight controller and it should then be bound to the transmitter.
There is also another way to do it using a CLI command described in the article below. You do all of the steps above, but instead of step 2 you do the steps in the article instead. Then you carry on with steps 3-5. This method is useful if you can't easily get to the bind button on the flight controller. You need to know what version of Betaflight is on your FC to use this method because the command to use changed between each version... https://brushlesswhoop.com/spi-bind-via-betaflight • Posts: 24 Threads: 11 Likes Received: 1 in 1 posts Likes Given: 2 Joined: May 2020 Reputation: 0 Thanks snowleopard. Are the quad and transmitter supposed to be connected by USB? • Posts: 21,263 Threads: 587 Likes Received: 8,969 in 6,637 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 788 06-Aug-2020, 09:34 AM (This post was last modified: 06-Aug-2020, 09:35 AM by SnowLeopardFPV.) No. You only need to connect the quad by USB to a computer, and that is only to give it power. You don't connect the transmitter to anything with any cables. Make sure you take TX16S at least a metre or two away from the Novice II when in binding mode, otherwise you can get issues if they are too close together (too much high powered RF data from the transmitter at close range can flood the receiver and overwhelm it which can then prevent the binding process completing properly). • Posts: 24 Threads: 11 Likes Received: 1 in 1 posts Likes Given: 2 Joined: May 2020 Reputation: 0 Something happened haha. First time I've had solid lights on the quad. How do you know when it's binded? Sorry for all the noob questions, I'm all at sea with this stuff. Hoping the info will stick as I go. • Posts: 21,263 Threads: 587 Likes Received: 8,969 in 6,637 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 788 Solid lights on the AIO whoop boards usually mean that the the transmitter is bound. If you go to the Receiver tab in Betaflight Configurator and wiggle the sticks, are you the channel bars moving? • Posts: 24 Threads: 11 Likes Received: 1 in 1 posts Likes Given: 2 Joined: May 2020 Reputation: 0 No, nothing on beta flight. The main lights that usually flash don't come on when I try to bind like that and 2 little red and white lights stay solid. • Posts: 12,099 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 • Posts: 24 Threads: 11 Likes Received: 1 in 1 posts Likes Given: 2 Joined: May 2020 Reputation: 0 # # diff # version # Betaflight / CRAZYBEEF4FR (C4FR) 4.0.4 Jun 30 2019 / 14:06:48 (f3a95efa3) MSP API: 1.41 # start the command batch batch start board_name CRAZYBEEF4FR manufacturer_id # name name NOVICE-II # resources # timer # dma # mixer # servo # servo mix # feature feature -TELEMETRY feature -AIRMODE feature MOTOR_STOP feature LED_STRIP # beeper beeper -ARMED # beacon # map map TAER1234 # serial serial 1 2048 115200 57600 0 115200 # led led 0 4,7::C:6 led 1 5,7::C:6 led 2 6,7::C:6 led 3 7,7::C:6 led 4 8,7::C:6 led 5 9,7::C:6 # color # mode_color # aux aux 0 0 0 1300 2100 0 0 aux 1 1 1 1125 1550 0 0 aux 2 13 3 1550 2100 0 0 aux 3 28 1 1550 2100 0 0 # adjrange adjrange 0 1 3 900 1300 12 3 0 0 adjrange 1 1 3 1300 1700 12 3 0 0 adjrange 2 1 3 1700 2100 12 3 0 0 # rxrange # vtx # rxfail # display_name # master set gyro_lowpass_type = PT1 set acc_calibration = 26,26,-126 set rx_spi_protocol = FRSKY_D set motor_pwm_protocol = DSHOT600 set vbat_max_cell_voltage = 440 set vbat_min_cell_voltage = 310 set vbat_warning_cell_voltage = 320 set ibata_scale = 1175 set small_angle = 180 set pid_process_denom = 1 set osd_warn_esc_fail = OFF set osd_vbat_pos = 2091 set osd_rssi_pos = 2081 set osd_tim_1_pos = 54 set osd_tim_2_pos = 2102 set osd_flymode_pos = 2456 set osd_g_force_pos = 65 set osd_throttle_pos = 2423 set osd_crosshairs_pos = 2253 set osd_current_pos = 2400 set osd_mah_drawn_pos = 2433 set osd_craft_name_pos = 2443 set osd_warnings_pos = 329 set osd_disarmed_pos = 2379 set vtx_band = 5 set vtx_channel = 2 set vtx_power = 3 set vtx_freq = 5695 set frsky_spi_tx_id = 56,13 set frsky_spi_offset = -22 set frsky_spi_bind_hop_data = 3,173,108,43,213,148,83,18,188,123,58,228,163,98,33,203,138,73,8,178,113,48,218,153,88,23,193,128,63,233,168,103,38,208,143,78,13,183,118,53,223,158,93,28,198,133,68,0,0,0 # profile profile 0 set dterm_lowpass_type = PT1 set p_pitch = 42 set i_pitch = 50 set d_pitch = 37 set f_pitch = 60 set p_roll = 40 set i_roll = 50 set d_roll = 32 set f_roll = 60 set p_yaw = 65 set i_yaw = 55 set f_yaw = 100 # rateprofile rateprofile 0 set roll_expo = 10 set pitch_expo = 10 set yaw_expo = 10 set roll_srate = 76 set pitch_srate = 76 # end the command batch batch end # • Posts: 21,263 Threads: 587 Likes Received: 8,969 in 6,637 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 788 OK, it looks like you have one of the Crazybee F4 Pro boards in the Novice II, so I can definitely confirm that when the 2 white and 2 red LEDs stop flashing and turn sold red/white it means it is bound to your transmitter. Can you please post a full "dump" rather than just a "diff". • Posts: 24 Threads: 11 Likes Received: 1 in 1 posts Likes Given: 2 Joined: May 2020 Reputation: 0 Sorry, is it obvious I'm googling my way through haha, # # dump # version # Betaflight / CRAZYBEEF4FR (C4FR) 4.0.4 Jun 30 2019 / 14:06:48 (f3a95efa3) MSP API: 1.41 # start the command batch batch start board_name CRAZYBEEF4FR manufacturer_id # name name NOVICE-II # resources resource BEEPER 1 C15 resource MOTOR 1 B10 resource MOTOR 2 B06 resource MOTOR 3 B07 resource MOTOR 4 B08 resource MOTOR 5 NONE resource MOTOR 6 NONE resource MOTOR 7 NONE resource MOTOR 8 NONE resource SERVO 1 NONE resource SERVO 2 NONE resource SERVO 3 NONE resource SERVO 4 NONE resource SERVO 5 NONE resource SERVO 6 NONE resource SERVO 7 NONE resource SERVO 8 NONE resource PPM 1 A03 resource PWM 1 A02 resource PWM 2 A09 resource PWM 3 A10 resource PWM 4 NONE resource PWM 5 NONE resource PWM 6 NONE resource PWM 7 NONE resource PWM 8 NONE resource LED_STRIP 1 A00 resource SERIAL_TX 1 A09 resource SERIAL_TX 2 A02 resource SERIAL_TX 3 NONE resource SERIAL_TX 4 NONE resource SERIAL_TX 5 NONE resource SERIAL_TX 6 NONE resource SERIAL_TX 7 NONE resource SERIAL_TX 8 NONE resource SERIAL_TX 9 NONE resource SERIAL_TX 10 NONE resource SERIAL_TX 11 NONE resource SERIAL_RX 1 A10 resource SERIAL_RX 2 A03 resource SERIAL_RX 3 NONE resource SERIAL_RX 4 NONE resource SERIAL_RX 5 NONE resource SERIAL_RX 6 NONE resource SERIAL_RX 7 NONE resource SERIAL_RX 8 NONE resource SERIAL_RX 9 NONE resource SERIAL_RX 10 NONE resource SERIAL_RX 11 NONE resource LED 1 C13 resource LED 2 NONE resource LED 3 NONE resource RX_BIND 1 NONE resource RX_BIND_PLUG 1 B02 resource SPI_SCK 1 A05 resource SPI_SCK 2 B13 resource SPI_SCK 3 B03 resource SPI_MISO 1 A06 resource SPI_MISO 2 B14 resource SPI_MISO 3 B04 resource SPI_MOSI 1 A07 resource SPI_MOSI 2 B15 resource SPI_MOSI 3 B05 resource ESCSERIAL 1 NONE resource CAMERA_CONTROL 1 NONE resource ADC_BATT 1 B00 resource ADC_RSSI 1 NONE resource ADC_CURR 1 B01 resource ADC_EXT 1 NONE resource PINIO 1 NONE resource PINIO 2 NONE resource PINIO 3 NONE resource PINIO 4 NONE resource OSD_CS 1 B12 resource RX_SPI_CS 1 A15 resource RX_SPI_EXTI 1 C14 resource RX_SPI_BIND 1 B02 resource RX_SPI_LED 1 B09 resource GYRO_EXTI 1 A01 resource GYRO_EXTI 2 NONE resource GYRO_CS 1 A04 resource GYRO_CS 2 NONE # timer timer A03 AF3 # pin A03: TIM9 CH2 (AF3) timer B10 AF1 # pin B10: TIM2 CH3 (AF1) timer B06 AF2 # pin B06: TIM4 CH1 (AF2) timer B07 AF2 # pin B07: TIM4 CH2 (AF2) timer B08 AF2 # pin B08: TIM4 CH3 (AF2) timer A00 AF2 # pin A00: TIM5 CH1 (AF2) timer A02 AF3 # pin A02: TIM9 CH1 (AF3) timer A09 AF1 # pin A09: TIM1 CH2 (AF1) timer A10 AF1 # pin A10: TIM1 CH3 (AF1) # dma dma SPI_TX 1 NONE dma SPI_TX 2 NONE dma SPI_TX 3 NONE dma SPI_RX 1 NONE dma SPI_RX 2 NONE dma SPI_RX 3 NONE dma ADC 1 0 # ADC 1: DMA2 Stream 0 Channel 0 dma ADC 2 NONE dma ADC 3 NONE dma UART_TX 1 NONE dma UART_TX 2 NONE dma UART_TX 3 NONE dma UART_TX 4 NONE dma UART_TX 5 NONE dma UART_TX 6 NONE dma UART_TX 7 NONE dma UART_TX 8 NONE dma UART_RX 1 NONE dma UART_RX 2 NONE dma UART_RX 3 NONE dma UART_RX 4 NONE dma UART_RX 5 NONE dma UART_RX 6 NONE dma UART_RX 7 NONE dma UART_RX 8 NONE dma pin A03 NONE dma pin B10 0 # pin B10: DMA1 Stream 1 Channel 3 dma pin B06 0 # pin B06: DMA1 Stream 0 Channel 2 dma pin B07 0 # pin B07: DMA1 Stream 3 Channel 2 dma pin B08 0 # pin B08: DMA1 Stream 7 Channel 2 dma pin A00 0 # pin A00: DMA1 Stream 2 Channel 6 dma pin A02 NONE dma pin A09 0 # pin A09: DMA2 Stream 6 Channel 0 dma pin A10 0 # pin A10: DMA2 Stream 6 Channel 0 # mixer mixer QUADX mmix reset # servo servo 0 1000 2000 1500 100 -1 servo 1 1000 2000 1500 100 -1 servo 2 1000 2000 1500 100 -1 servo 3 1000 2000 1500 100 -1 servo 4 1000 2000 1500 100 -1 servo 5 1000 2000 1500 100 -1 servo 6 1000 2000 1500 100 -1 servo 7 1000 2000 1500 100 -1 # servo mix smix reset # feature feature -RX_PPM feature -INFLIGHT_ACC_CAL feature -RX_SERIAL feature -MOTOR_STOP feature -SERVO_TILT feature -SOFTSERIAL feature -GPS feature -RANGEFINDER feature -TELEMETRY feature -3D feature -RX_PARALLEL_PWM feature -RX_MSP feature -RSSI_ADC feature -LED_STRIP feature -DISPLAY feature -OSD feature -CHANNEL_FORWARDING feature -TRANSPONDER feature -AIRMODE feature -RX_SPI feature -SOFTSPI feature -ESC_SENSOR feature -ANTI_GRAVITY feature -DYNAMIC_FILTER feature MOTOR_STOP feature LED_STRIP feature OSD feature RX_SPI feature ANTI_GRAVITY feature DYNAMIC_FILTER # beeper beeper GYRO_CALIBRATED beeper RX_LOST beeper RX_LOST_LANDING beeper DISARMING beeper ARMING beeper ARMING_GPS_FIX beeper ARMING_GPS_NO_FIX beeper BAT_CRIT_LOW beeper BAT_LOW beeper GPS_STATUS beeper RX_SET beeper ACC_CALIBRATION beeper ACC_CALIBRATION_FAIL beeper READY_BEEP beeper MULTI_BEEPS beeper DISARM_REPEAT beeper -ARMED beeper SYSTEM_INIT beeper ON_USB beeper BLACKBOX_ERASE beeper CRASH_FLIP beeper CAM_CONNECTION_OPEN beeper CAM_CONNECTION_CLOSE beeper RC_SMOOTHING_INIT_FAIL # beacon beacon -RX_LOST beacon -RX_SET # map map TAER1234 # serial serial 20 1 115200 57600 0 115200 serial 0 0 115200 57600 0 115200 serial 1 2048 115200 57600 0 115200 # led led 0 4,7::C:6 led 1 5,7::C:6 led 2 6,7::C:6 led 3 7,7::C:6 led 4 8,7::C:6 led 5 9,7::C:6 led 6 0,0::C:0 led 7 0,0::C:0 led 8 0,0::C:0 led 9 0,0::C:0 led 10 0,0::C:0 led 11 0,0::C:0 led 12 0,0::C:0 led 13 0,0::C:0 led 14 0,0::C:0 led 15 0,0::C:0 led 16 0,0::C:0 led 17 0,0::C:0 led 18 0,0::C:0 led 19 0,0::C:0 led 20 0,0::C:0 led 21 0,0::C:0 led 22 0,0::C:0 led 23 0,0::C:0 led 24 0,0::C:0 led 25 0,0::C:0 led 26 0,0::C:0 led 27 0,0::C:0 led 28 0,0::C:0 led 29 0,0::C:0 led 30 0,0::C:0 led 31 0,0::C:0 # color color 0 0,0,0 color 1 0,255,255 color 2 0,0,255 color 3 30,0,255 color 4 60,0,255 color 5 90,0,255 color 6 120,0,255 color 7 150,0,255 color 8 180,0,255 color 9 210,0,255 color 10 240,0,255 color 11 270,0,255 color 12 300,0,255 color 13 330,0,255 color 14 0,0,0 color 15 0,0,0 # mode_color mode_color 0 0 1 mode_color 0 1 11 mode_color 0 2 2 mode_color 0 3 13 mode_color 0 4 10 mode_color 0 5 3 mode_color 1 0 5 mode_color 1 1 11 mode_color 1 2 3 mode_color 1 3 13 mode_color 1 4 10 mode_color 1 5 3 mode_color 2 0 10 mode_color 2 1 11 mode_color 2 2 4 mode_color 2 3 13 mode_color 2 4 10 mode_color 2 5 3 mode_color 3 0 8 mode_color 3 1 11 mode_color 3 2 4 mode_color 3 3 13 mode_color 3 4 10 mode_color 3 5 3 mode_color 4 0 7 mode_color 4 1 11 mode_color 4 2 3 mode_color 4 3 13 mode_color 4 4 10 mode_color 4 5 3 mode_color 5 0 0 mode_color 5 1 0 mode_color 5 2 0 mode_color 5 3 0 mode_color 5 4 0 mode_color 5 5 0 mode_color 6 0 6 mode_color 6 1 10 mode_color 6 2 1 mode_color 6 3 0 mode_color 6 4 0 mode_color 6 5 2 mode_color 6 6 3 mode_color 6 7 6 mode_color 6 8 0 mode_color 6 9 0 mode_color 6 10 0 mode_color 7 0 3 # aux aux 0 0 0 1300 2100 0 0 aux 1 1 1 1125 1550 0 0 aux 2 13 3 1550 2100 0 0 aux 3 28 1 1550 2100 0 0 aux 4 0 0 900 900 0 0 aux 5 0 0 900 900 0 0 aux 6 0 0 900 900 0 0 aux 7 0 0 900 900 0 0 aux 8 0 0 900 900 0 0 aux 9 0 0 900 900 0 0 aux 10 0 0 900 900 0 0 aux 11 0 0 900 900 0 0 aux 12 0 0 900 900 0 0 aux 13 0 0 900 900 0 0 aux 14 0 0 900 900 0 0 aux 15 0 0 900 900 0 0 aux 16 0 0 900 900 0 0 aux 17 0 0 900 900 0 0 aux 18 0 0 900 900 0 0 aux 19 0 0 900 900 0 0 # adjrange adjrange 0 1 3 900 1300 12 3 0 0 adjrange 1 1 3 1300 1700 12 3 0 0 adjrange 2 1 3 1700 2100 12 3 0 0 adjrange 3 0 0 900 900 0 0 0 0 adjrange 4 0 0 900 900 0 0 0 0 adjrange 5 0 0 900 900 0 0 0 0 adjrange 6 0 0 900 900 0 0 0 0 adjrange 7 0 0 900 900 0 0 0 0 adjrange 8 0 0 900 900 0 0 0 0 adjrange 9 0 0 900 900 0 0 0 0 adjrange 10 0 0 900 900 0 0 0 0 adjrange 11 0 0 900 900 0 0 0 0 adjrange 12 0 0 900 900 0 0 0 0 adjrange 13 0 0 900 900 0 0 0 0 adjrange 14 0 0 900 900 0 0 0 0 adjrange 15 0 0 900 900 0 0 0 0 adjrange 16 0 0 900 900 0 0 0 0 adjrange 17 0 0 900 900 0 0 0 0 adjrange 18 0 0 900 900 0 0 0 0 adjrange 19 0 0 900 900 0 0 0 0 adjrange 20 0 0 900 900 0 0 0 0 adjrange 21 0 0 900 900 0 0 0 0 adjrange 22 0 0 900 900 0 0 0 0 adjrange 23 0 0 900 900 0 0 0 0 adjrange 24 0 0 900 900 0 0 0 0 adjrange 25 0 0 900 900 0 0 0 0 adjrange 26 0 0 900 900 0 0 0 0 adjrange 27 0 0 900 900 0 0 0 0 adjrange 28 0 0 900 900 0 0 0 0 adjrange 29 0 0 900 900 0 0 0 0 # rxrange rxrange 0 1000 2000 rxrange 1 1000 2000 rxrange 2 1000 2000 rxrange 3 1000 2000 # vtx vtx 0 0 0 0 900 900 vtx 1 0 0 0 900 900 vtx 2 0 0 0 900 900 vtx 3 0 0 0 900 900 vtx 4 0 0 0 900 900 vtx 5 0 0 0 900 900 vtx 6 0 0 0 900 900 vtx 7 0 0 0 900 900 vtx 8 0 0 0 900 900 vtx 9 0 0 0 900 900 # rxfail rxfail 0 a rxfail 1 a rxfail 2 a rxfail 3 a rxfail 4 h rxfail 5 h rxfail 6 h rxfail 7 h rxfail 8 h rxfail 9 h rxfail 10 h rxfail 11 h rxfail 12 h rxfail 13 h rxfail 14 h rxfail 15 h rxfail 16 h rxfail 17 h # display_name display_name - # master set gyro_hardware_lpf = NORMAL set gyro_sync_denom = 1 set gyro_lowpass_type = PT1 set gyro_lowpass_hz = 150 set gyro_lowpass2_type = PT1 set gyro_lowpass2_hz = 150 set gyro_notch1_hz = 0 set gyro_notch1_cutoff = 0 set gyro_notch2_hz = 0 set gyro_notch2_cutoff = 0 set gyro_calib_duration = 125 set gyro_calib_noise_limit = 48 set gyro_offset_yaw = 0 set gyro_overflow_detect = ALL set yaw_spin_recovery = ON set yaw_spin_threshold = 1950 set gyro_to_use = FIRST set dyn_notch_range = AUTO set dyn_notch_width_percent = 8 set dyn_notch_q = 120 set dyn_notch_min_hz = 150 set dyn_lpf_gyro_min_hz = 150 set dyn_lpf_gyro_max_hz = 450 set gyro_filter_debug_axis = ROLL set acc_hardware = AUTO set acc_lpf_hz = 10 set acc_trim_pitch = 0 set acc_trim_roll = 0 set acc_calibration = 26,26,-126 set mid_rc = 1500 set min_check = 1050 set max_check = 1900 set rssi_channel = 0 set rssi_src_frame_errors = OFF set rssi_scale = 100 set rssi_offset = 0 set rssi_invert = OFF set rc_interp = AUTO set rc_interp_ch = RPYT set rc_interp_int = 19 set rc_smoothing_type = FILTER set rc_smoothing_input_hz = 0 set rc_smoothing_derivative_hz = 0 set rc_smoothing_debug_axis = ROLL set rc_smoothing_input_type = BIQUAD set rc_smoothing_derivative_type = BIQUAD set rc_smoothing_auto_smoothness = 10 set fpv_mix_degrees = 0 set max_aux_channels = 14 set serialrx_provider = SPEK1024 set serialrx_inverted = OFF set spektrum_sat_bind = 0 set spektrum_sat_bind_autoreset = ON set airmode_start_throttle_percent = 25 set rx_min_usec = 885 set rx_max_usec = 2115 set serialrx_halfduplex = OFF set rx_spi_protocol = FRSKY_D set rx_spi_bus = 3 set rx_spi_led_inversion = OFF set adc_device = 1 set adc_vrefint_calibration = 0 set adc_tempsensor_calibration30 = 0 set adc_tempsensor_calibration110 = 0 set input_filtering_mode = OFF set blackbox_p_ratio = 32 set blackbox_device = SERIAL set blackbox_record_acc = ON set blackbox_mode = NORMAL set min_throttle = 1070 set max_throttle = 2000 set min_command = 1000 set dshot_idle_value = 550 set dshot_burst = OFF set dshot_bidir = OFF set use_unsynced_pwm = OFF set motor_pwm_protocol = DSHOT600 set motor_pwm_rate = 480 set motor_pwm_inversion = OFF set motor_poles = 14 set thr_corr_value = 0 set thr_corr_angle = 800 set failsafe_delay = 4 set failsafe_off_delay = 10 set failsafe_throttle = 1000 set failsafe_switch_mode = STAGE1 set failsafe_throttle_low_delay = 100 set failsafe_procedure = DROP set align_board_roll = 0 set align_board_pitch = 0 set align_board_yaw = 0 set gimbal_mode = NORMAL set bat_capacity = 0 set vbat_max_cell_voltage = 440 set vbat_full_cell_voltage = 410 set vbat_min_cell_voltage = 310 set vbat_warning_cell_voltage = 320 set vbat_hysteresis = 1 set current_meter = ADC set battery_meter = ADC set vbat_detect_cell_voltage = 300 set use_vbat_alerts = ON set use_cbat_alerts = OFF set cbat_alert_percent = 10 set vbat_cutoff_percent = 100 set force_battery_cell_count = 0 set vbat_lpf_period = 30 set ibat_lpf_period = 10 set vbat_scale = 110 set vbat_divider = 10 set vbat_multiplier = 1 set ibata_scale = 1175 set ibata_offset = 0 set ibatv_scale = 0 set ibatv_offset = 0 set beeper_inversion = ON set beeper_od = OFF set beeper_frequency = 0 set beeper_dshot_beacon_tone = 1 set yaw_motors_reversed = OFF set crashflip_motor_percent = 0 set 3d_deadband_low = 1406 set 3d_deadband_high = 1514 set 3d_neutral = 1460 set 3d_deadband_throttle = 50 set 3d_limit_low = 1000 set 3d_limit_high = 2000 set 3d_switched_mode = OFF set servo_center_pulse = 1500 set servo_pwm_rate = 50 set servo_lowpass_hz = 0 set tri_unarmed_servo = ON set channel_forwarding_start = 4 set reboot_character = 82 set serial_update_rate_hz = 100 set imu_dcm_kp = 2500 set imu_dcm_ki = 0 set small_angle = 180 set auto_disarm_delay = 5 set gyro_cal_on_first_arm = OFF set gps_provider = NMEA set gps_sbas_mode = AUTO set gps_auto_config = ON set gps_auto_baud = OFF set gps_ublox_use_galileo = OFF set gps_set_home_point_once = OFF set gps_rescue_angle = 32 set gps_rescue_initial_alt = 50 set gps_rescue_descent_dist = 200 set gps_rescue_ground_speed = 2000 set gps_rescue_throttle_p = 150 set gps_rescue_throttle_i = 20 set gps_rescue_throttle_d = 50 set gps_rescue_velocity_p = 80 set gps_rescue_velocity_i = 20 set gps_rescue_velocity_d = 15 set gps_rescue_yaw_p = 40 set gps_rescue_throttle_min = 1200 set gps_rescue_throttle_max = 1600 set gps_rescue_throttle_hover = 1280 set gps_rescue_sanity_checks = RESCUE_SANITY_ON set gps_rescue_min_sats = 8 set gps_rescue_min_dth = 100 set gps_rescue_allow_arming_without_fix = OFF set deadband = 0 set yaw_deadband = 0 set yaw_control_reversed = OFF set pid_process_denom = 1 set runaway_takeoff_prevention = ON set runaway_takeoff_deactivate_delay = 500 set runaway_takeoff_deactivate_throttle_percent = 20 set thrust_linear = 0 set transient_throttle_limit = 15 set tlm_inverted = OFF set tlm_halfduplex = ON set frsky_default_lat = 0 set frsky_default_long = 0 set frsky_gps_format = 0 set frsky_unit = IMPERIAL set frsky_vfas_precision = 0 set hott_alarm_int = 5 set pid_in_tlm = OFF set report_cell_voltage = OFF set ibus_sensor = 1,2,3,0,0,0,0,0,0,0,0,0,0,0,0 set mavlink_mah_as_heading_divisor = 0 set telemetry_disabled_voltage = OFF set telemetry_disabled_current = OFF set telemetry_disabled_fuel = OFF set telemetry_disabled_mode = OFF set telemetry_disabled_acc_x = OFF set telemetry_disabled_acc_y = OFF set telemetry_disabled_acc_z = OFF set telemetry_disabled_pitch = OFF set telemetry_disabled_roll = OFF set telemetry_disabled_heading = OFF set telemetry_disabled_altitude = OFF set telemetry_disabled_vario = OFF set telemetry_disabled_lat_long = OFF set telemetry_disabled_ground_speed = OFF set telemetry_disabled_distance = OFF set telemetry_disabled_esc_current = ON set telemetry_disabled_esc_voltage = ON set telemetry_disabled_esc_rpm = ON set telemetry_disabled_esc_temperature = ON set telemetry_disabled_temperature = OFF set ledstrip_visual_beeper = OFF set ledstrip_visual_beeper_color = WHITE set ledstrip_grb_rgb = GRB set ledstrip_profile = STATUS set ledstrip_race_color = ORANGE set ledstrip_beacon_color = WHITE set ledstrip_beacon_period_ms = 500 set ledstrip_beacon_percent = 50 set ledstrip_beacon_armed_only = OFF set osd_units = METRIC set osd_warn_arming_disable = ON set osd_warn_batt_not_full = ON set osd_warn_batt_warning = ON set osd_warn_batt_critical = ON set osd_warn_visual_beeper = ON set osd_warn_crash_flip = ON set osd_warn_esc_fail = OFF set osd_warn_core_temp = ON set osd_warn_rc_smoothing = ON set osd_warn_fail_safe = ON set osd_warn_launch_control = ON set osd_warn_no_gps_rescue = ON set osd_warn_gps_rescue_disabled = ON set osd_rssi_alarm = 20 set osd_cap_alarm = 2200 set osd_alt_alarm = 100 set osd_esc_temp_alarm = -128 set osd_esc_rpm_alarm = -1 set osd_esc_current_alarm = -1 set osd_core_temp_alarm = 70 set osd_ah_max_pit = 20 set osd_ah_max_rol = 40 set osd_ah_invert = OFF set osd_tim1 = 2560 set osd_tim2 = 2561 set osd_vbat_pos = 2091 set osd_rssi_pos = 2081 set osd_link_quality_pos = 234 set osd_tim_1_pos = 54 set osd_tim_2_pos = 2102 set osd_remaining_time_estimate_pos = 234 set osd_flym • Posts: 21,263 Threads: 587 Likes Received: 8,969 in 6,637 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 788 The settings that I can see all look fine but your dump has been truncated including the important SPI binding data entries. If you switch to the Receiver tab in Betaflight Configurator with your transmitter switched on and solid red/white LEDs on the board, are you definitely not getting the bars moving when you move the sticks? • Posts: 24 Threads: 11 Likes Received: 1 in 1 posts Likes Given: 2 Joined: May 2020 Reputation: 0 No, nothing in betaflight, and the red and white are flashing again. go completely when I try to bind, then flash again • |
