100mm true-X frame, 8520's and F3 EVO brushed build log
X100 true-X frame kit (designed to fit Inductrix/E010 style canopies)
8520 brushed motors
F3 EVO Brushed flight controler
FrSky XM+ reciever
Eachine TX03 AIO and 3D printed mount
The necessities arrived yesterday! The rest I had laying around Wink
[Image: xxaiJtJl.jpg]
Edit: Added some pics of frame weights for everyone. (Frame is fairly new from BG so there isn't much info about it yet)
[Image: R0FMsRKl.jpg]
[Image: sRjJWoJl.jpg]
[Image: hKzndcsl.jpg]
[Image: UCekxVdl.jpg]
[Image: Zw7JYXil.jpg]
Frame prepared. Parts organized.... bench is not Wink
[Image: RlVFjlcl.jpg]
More to come throughout the build. Big Grin
The Obsession IS Real!
[-] The following 6 users Like Drone0fPrey's post:
  • Oscar, jimbo_wa, Tom BD Bad, Carl.Vegas, unseen, KonradS
Didn't get much time at the bench this morning. Everything is ready to find its place. (I'll update this with more detailed peparations this evening) but here is where she's at for now.
[Image: MpVi5upl.jpg]
[-] The following 3 users Like Drone0fPrey's post:
  • Tom BD Bad, unseen, sloscotty
What's the heat shrink for on the arms?
Every gramme counts on these. If something isn't 100% necessary, don't fit it. If a wire is 10mm longer than it needs to be, cut it back. While twisted wires look nice, the actual wires have to be longer. An XM+ on a micro brushed build is overkill. The lighter you make it, the better it will fly and the longer the motors will last.
I'm not trying to be picky here. When your target weight for a build is in the 35g range, even 0.5g counts!
I would say rawr here... but on a micro... it's kinda... more like a "mreow!"
looks like fun!
carl.vegas
  • Drone0fPrey
Popcorn...
(05-May-2017, 09:00 PM)unseen Wrote: What's the heat shrink for on the arms?
Thanks for the tips Unseen, no worries here. Smile This is my first 'ground up' micro build. Before this was hacked/modded toy quads Wink
I did remove the heat shrink from the arms and battery lead, 0.6g Wink and the wires I always leave extra long while I am working out component locations.
I tried to leave just enough length I can "pop-the-top"
[Image: vCrMaAQl.jpg]
[Image: OWkNbfBl.jpg]
Had to remove the giant glob of epoxy and re-solder power leads on the TX03 just to get it fitted in the mount.
[Image: 7GsCSs6l.jpg]
The XM+ is overkill but I kind of wanted to try it out. I will eventually move it over to my NOX5R (if I dont build another quad first. Wink )
Everything soldered, checked for shorts and ready for conconfiguration.
[Image: UfXNNFPl.jpg]
[-] The following 2 users Like Drone0fPrey's post:
  • unseen, sloscotty
Nicely built!
I've been using the FD800 receivers on my micro builds and they are great for the price.
A couple of tie wraps and some heat shrink will keep your XM+ antennas out of the props at the expense of a little more weight.
That antenna won't last long unless you do something to protect it though. In the worst case, the part of the PCB where it is soldered to will snap off. The fact that your TX03 is firmly held in the mount probably adds to the risk.
I did a similar build a while back and printed a bow that sits over the antenna and provides a little defence for it in a crash.
[Image: IMG_20170507_111402_zpsbe09qah8.jpg]
  • Drone0fPrey
Thanks for the tips Unseen. I just put the FD800 in my cart on BG Wink
I'm going to see how the antennas work like this for now. she is a porker Tongue at 43g without lipo.
[Image: 1MPFlpLl.jpg]
[Image: NDOhyvcl.jpg]
[Image: O9ZLqIFl.jpg]
I was thinking of taking apart a rubber ducky antenna to solder on. Would that work? I haven't research anything about it yet but had the idea last night. I have seen where people have broken the PCB right there and dont have the weight to spare for protecting it at the moment.
  • Carl.Vegas, unseen, sloscotty
Nice build! Like what you did with the Rx antennas!
  • Drone0fPrey
Those antennas look pretty safe, nicely saved!
If you can extract the dipole from a 5.8GHz rubber ducky antenna, it will probably save you a little weight as well. It'll certainly work OK. You just need to be careful when you remove the current one that you don't strip the tracks off the PCB.
  • Drone0fPrey
(07-May-2017, 07:06 PM)unseen Wrote: Those antennas look pretty safe, nicely saved!
Thanks and thanks. Big Grin
  • unseen
An updated picture just for fun.
The TPU mounts did not hold up well Dodgy
[Image: z6Znsjol.jpg]
My latest Brushed Video DVR from the X100
  • sloscotty
  First FPV build. 3.5" help Pums 18 500 16-May-2024, 08:55 PM
  Build BetaFPV Meteor65 Pro 1S Build brettbrandon 30 822 14-May-2024, 06:03 PM
Last Post: brettbrandon
  AOS 3" Toothpick build SeismicCWave 38 869 07-May-2024, 08:23 PM
  Meteor65 pro walksnail build, 24g. ph2t 2 171 07-May-2024, 04:11 AM
Last Post: FPVme
  Build Meteor75 Build (Revision 4) :) Pathfinder075 9 644 14-Apr-2024, 03:28 AM
