Posts: 47 Threads: 13 Likes Received: 1 in 1 posts Likes Given: 28 Joined: Jan 2021 Reputation: 0 Hi i would like to have at least 1km of range .But idk what receiver / transmitter choose. I know there is flysky but they only have 500m of range and if i want more i have to buy a module and a transmitter that support a module. Does anyone knows is there is a receiver that have 1km or + range without a module ? (s bus or ibus with failsaife of course) Thank you • Posts: 6,157 Threads: 172 Likes Received: 2,297 in 1,844 posts Likes Given: 4,753 Joined: Feb 2019 Reputation: 103 all transmitters has an internal module. to do range, tbs crossfire system is the ways to go. it can provide much more range than one km. a tbs tango 2 would be a nice transmitter and a crossfire nano receiver. a less expensive way, a littlebit less: would be the jumper T-lite and an additional crossfire module and a cresf nano rx. • Posts: 47 Threads: 13 Likes Received: 1 in 1 posts Likes Given: 28 Joined: Jan 2021 Reputation: 0 (30-Jan-2021, 09:37 AM)hugnosed_bat Wrote: all transmitters has an internal module. to do range, tbs crossfire system is the ways to go. it can provide much more range than one km. a tbs tango 2 would be a nice transmitter and a crossfire nano receiver. a less expensive way, a littlebit less: would be the jumper T-lite and an additional crossfire module and a cresf nano rx. how much does the less expennsive way cost ? • Posts: 6,157 Threads: 172 Likes Received: 2,297 in 1,844 posts Likes Given: 4,753 Joined: Feb 2019 Reputation: 103 60 bucks for the nice jumper t-lite 70 bucks for the external module 30 bucks for a receiver 160 bucks the tbs tango 2 is about 200bucks, 230 with a receiver. Posts: 47 Threads: 13 Likes Received: 1 in 1 posts Likes Given: 28 Joined: Jan 2021 Reputation: 0 • Posts: 6,157 Threads: 172 Likes Received: 2,297 in 1,844 posts Likes Given: 4,753 Joined: Feb 2019 Reputation: 103 of you dont like "gamestyle" controllers, you would need a jumper or radiomaster tx16s, but it would go more expensive than the tango, paired with a module and receiver. • Posts: 47 Threads: 13 Likes Received: 1 in 1 posts Likes Given: 28 Joined: Jan 2021 Reputation: 0 (30-Jan-2021, 09:49 AM)hugnosed_bat Wrote: of you dont like "gamestyle" controllers, you would need a jumper or radiomaster tx16s, but it would go more expensive than the tango, paired with a module and receiver. yeah it's not my cup of tea but 200 $ for a radio is a little bit too much • Posts: 6,157 Threads: 172 Likes Received: 2,297 in 1,844 posts Likes Given: 4,753 Joined: Feb 2019 Reputation: 103 just to mention about a goggle or transmitter last long, they dont crash... its a good idea to spend money there if you can crossfire is faraway ahead, the receivers are expensive at 30, but its worse the money :-) • Posts: 47 Threads: 13 Likes Received: 1 in 1 posts Likes Given: 28 Joined: Jan 2021 Reputation: 0 (30-Jan-2021, 10:07 AM)hugnosed_bat Wrote: just to mention about a goggle or transmitter last long, they dont crash... its a good idea to spend money there if you can crossfire is faraway ahead, the receivers are expensive at 30, but its worse the money :-) True . with a 700$ machine in the air it will be stupid to crash because of cheap stuff on the ground • Posts: 1,492 Threads: 93 Likes Received: 574 in 468 posts Likes Given: 0 Joined: Nov 2020 Reputation: 27 31-Jan-2021, 07:13 AM (This post was last modified: 31-Jan-2021, 07:16 AM by romangpro.) You mentioned Flysky. Its not bad. Few good receivers. I did antenna mod on FS i6. A lot depends on antenna placement, and line of sight. Did 700m and 900m tests 2 years ago: X6B. Fli10. Flit14+(replaced antenna). Most where weak, but ok (sig8-10, 40%+). Better with patch antenna. Sadly, I had lots of failsafe fall outa sky doing turns/flips, where antenna was poor position. Similar to QX7 and R-XSR, More recently bought XR602T-A. It claims 2km range. Posts: 47 Threads: 13 Likes Received: 1 in 1 posts Likes Given: 28 Joined: Jan 2021 Reputation: 0 (31-Jan-2021, 07:13 AM)romangpro Wrote: You mentioned Flysky. Its not bad. Few good receivers. I did antenna mod on FS i6. A lot depends on antenna placement, and line of sight. Did 700m and 900m tests 2 years ago: X6B. Fli10. Flit14+(replaced antenna). Most where weak, but ok (sig8-10, 40%+). Better with patch antenna. Sadly, I had lots of failsafe fall outa sky doing turns/flips, where antenna was poor position. Similar to QX7 and R-XSR, More recently bought XR602T-A. It claims 2km range. i will go for a taranis qx7 and a xm+ receiver .it should do the job • Posts: 1,492 Threads: 93 Likes Received: 574 in 468 posts Likes Given: 0 Joined: Nov 2020 Reputation: 27 All the old 2.4ghz are pretty much the same. With proper 30.5mm antenna, especially 10-14dbm patch/directional on Tx, you can stretch typical 1km, to 4-6km. And all radio can be mod to output higher power. But, regardless, when behind dense trees, it will fail. Its 2.4ghz. Flysky/Frsky/Spectrum/Futaba - doesnt matter. If you want "real" and stable 1km+ (or 20km+): 900Mhz TBS Crossfire (CSS modulation) - excellent support 900Mhz Frsky R9M 2.4Ghz Flysky ADH3 - new and very limited compatibility 2.4Ghz ImmersionRC Ghost (CSS modulation) 900/2.4 ExpressLRS <<-- I ordered PCBs and building 900 mini RX on top of flashing R9M In terms of performance, ExpressLRS claims to be #1. But its still "beta". Likewise, Ghost is very good, but very new. Proven and full support - Crossfire. But 900Mhz antenna are big for micros. • Posts: 3,288 Threads: 129 Likes Received: 2,740 in 1,644 posts Likes Given: 2,969 Joined: Apr 2017 Reputation: 65 My QX7 and XM+ RX’s have been out to 1200 meters. Not a lot of confidence, but they will work. I have never had a failsafe with that combination inside of 700 meters. My R9M on my seven inch cruiser has been out to 3.5km and it had a strong connection, even behind cover that caused my video to cease to be viable. Thankfully the craft in an INAV build and the waypoint navigation worked to get it back into video range. I have been flying 900mhz for a while now, even on my micros. The antenna are not that big, even the T style. This is my Japalura with an R9MM receiver. The T antenna kept catching on things so I shifted back to the stock antenna and ran it out on the arm. It has been out to 2km in that configuration, but the battery came back deflated...this thing is not at all efficient. The 900mhz systems will allow you better connectivity. SoCal Kaity :D OMG, no one told me it would be this much fun! Addicted :) • |
