Wrecked my motors :(
My quad flew prop side down into the gutter at my house, and I must have not cut the throttle as quick as I thought. Heard a buzzing sound, and then nothing.
The leds still are responsive when they should be, and video still transmits just fine, so I’m assuming just the motors are shot.
So my question is, are all 8520 motors the same? When replacing them what should I look for. When only one burns out how do you ensure they are going to match the others?
They are not all quite the same. But they should work, because the FC will compensate for the mismatch.
  • Jakefpv
(14-Apr-2018, 01:19 AM)voodoo614 Wrote: They are not all quite the same. But they should work, because the FC will compensate for the mismatch.
Cool grabbed a box of hobby mate motors x2
Also gave the 2x spares from bg but who know when they will get here.
On the positive, I know my new batteries work well, just stinks I’m out of commission for a bit.
Gunna have to speed up my soldering learning because I still haven’t soldered anything on a fc yet
If you have an old PC motherboard or any old PCB that is not in use. Use that to practice.
The idea with soldering is to get everything up to temperature - pre-tin the pad and the wire, then apply the heat from the iron, while adding a little more solder from the roll, to get the solder on both the wire and the pad to "flow" together.
Try to work quickly, some components on the board are sensitive to temperature and should not be over heated, also the longer you apply heat the more likely the surface that you are heating will oxidize, if this happens you will need to apply flux and clean the pad before trying again.
A good quality iron and good quality solder are really important to good soldering.
[-] The following 2 users Like Tom BD Bad's post:
  • Fisherking, Jakefpv
(14-Apr-2018, 06:18 AM)Tom BD Bad Wrote: A good quality iron and good quality solder are really important to good soldering.
Very true!! I really struggled with a normal little DIY soldering iron on my first build. Got a proper soldering station and it changed my world.
Solder Wire: 60% Sn, 38% Pb, 2.0% Flux
Will this solder work?
Still waiting on the motors, however picked up an adjustable temp soldering iron, some flux, and that solder .
This is a great economy solder. It flows well and I have not had any bad joints since starting use of it. Not all solders are equal, despite the proportions they claim.
https://www.amazon.com/gp/product/B01IQN...UTF8&psc=1
SoCal Kaity :D
[-] The following 2 users Like kaitylynn's post:
  • Fisherking, sirdude
The key to soldering is to have a good tip, the correct temperature and to get in and out quickly.  Br sure everything is  clean going in...use a little alcohol on the pads if in doubt.  Takes a little practice, but you'll get it! Thumbs Up
[-] The following 1 user Likes sirdude's post:
  • kaitylynn
Will have to check it out later, and put my flying on hold until next payday. Went to the doctor with a fairly serious sinus infection as well as strept, so will be unable to get different solder until payday. Don’t wanna risk the solder I got if it’s not good.
On man....I bet you fee like  Poop.  I've had my share of sinus infections and strep.  Hope you feel better soon!
  • Jakefpv
(14-Apr-2018, 10:52 PM)sirdude Wrote: On man....I bet you fee like  Poop.  I've had my share of sinus infections and strep.  Hope you feel better soon!
Yeah absolutely feel awful.
Unfortunately with the frog being down can’t even practice inside.
Been looking at a second just for this reason. Gunna keep reading and save up before I just get one though
[-] The following 1 user Likes Jakefpv's post:
  • kaitylynn
I have a racer star f4s esc's all in one board, and one of the 5v capacitors came off. I was able to solder it back together, and it worked for a while(This capacitor supplies the 5v output for the buzzer, receiver, vtx, and camera. Now the voltage that goes through it dropped to 1.5 volts, and it isn't supplying power to any of my components. On top of that, the esc's won't fully boot up unless I connect it to betaflight. Does anyone know how to fix this?
(14-Apr-2018, 11:19 PM)Eli D. Wrote: I have a racer star f4s esc's all in one board, and one of the 5v capacitors came off. I was able to solder it back together, and it worked for a while(This capacitor supplies the 5v output for the buzzer, receiver, vtx, and camera. Now the voltage that goes through it dropped to 1.5 volts, and it isn't supplying power to any of my components. On top of that, the esc's won't fully boot up unless I connect it to betaflight. Does anyone know how to fix this?
Hello Eli.  You might get better results if you start your own thread regarding your issue.  This post is specific to a member and their own issue.
SoCal Kaity :D
  • Jakefpv
(14-Apr-2018, 11:10 PM)Jakefpv Wrote: Yeah absolutely feel awful.
I used to suffer seasonal sinus infections and dang...they sort of suck big time!  Feel better soon...chicken noodle soup, flat sprite and saltines.
If you have something to practice on with the solder you have, try making a few joints to see how the solder works.  What you have might work great, no way to know until you try it out.
SoCal Kaity :D
  • Jakefpv
(15-Apr-2018, 12:42 AM)kaitylynn Wrote: I used to suffer seasonal sinus infections and dang...they sort of suck big time!  Feel better soon...chicken noodle soup, flat sprite and saltines.
Been practicing on some dumper electronics I had lying around and I thought it was working but didn’t have anything really to base it off as it’s the only solder I’ve used.
Worst part about being budget Fpv is when your bird is down that’s all you got. Gunna get the frog flying again, and then test myself a secondary flyer.
  • Drone0fPrey
  Default BetaFlight 4.5 motors run hot EyeBotXander 35 818 20-Jun-2024, 08:40 PM
  Can $5 motors be any good? 1805-1550kv mstc 22 457 01-Jun-2024, 11:26 PM
  Help Motors not spinning polar223 16 540 31-May-2024, 09:50 PM
  Motors spin rough then stop MajorKook 4 162 18-May-2024, 08:53 PM
Last Post: MajorKook
  one of the motors does not arm balabushka 4 202 01-Apr-2024, 09:54 PM
