Hacking Trainer Plug to USB for Sim
Hey guys, I wanna splice a trainer port cable to a USB connector so I can use my radio in a sim.
Can I confirm I just need to connect the +5V, DATA+, and GND from the USB ...
[Image: ADJbU89.jpg]
... to the +V (pin 4), signal IN (pin 6), and ground (pin 2), respectively?
[Image: 4P98x7v.gif]
[-] The following 1 user Likes the.ronin's post:
  • hugnosed_bat
So ... yea ... FYI ... this doesn't work lol.   ROFL
I had tried just hooking up one of the USB data wires to the single signal wire on the trainer port.  No dice.  I suspect there's additional electronics in the USB adapters you see online.  Going to look for a proper trainer port to USB adapter.  I'm just glad I didn't fry my radio lol.
Have you seen this? https://www.banggood.com/Upgrade-USB-Don...rehouse=CN
Can be wireless using a ppm rx or can hook to trainer port with included cables (not sure about futaba trainer port, but you could probably tell from photos). Anyway, not a huge investment to try...
  • the.ronin
Thanks scotty. I got another one like that from Amazon (effortless returns) but it uses the trainer port rather than the servo connector to connect to USB. If that doesn't work, I'll return it and try the one you linked.
(29-Oct-2020, 05:09 PM)the.ronin Wrote: Thanks scotty.  I got another one like that from Amazon (effortless returns) but it uses the trainer port rather than the servo connector to connect to USB.  If that doesn't work, I'll return it and try the one you linked.
I think this one has both.  Direct cable-connect through the trainer port, OR wireless connect with a PPM Rx connected to the servo connector.  (I love my XSR-Sim wireless for using simulators - no cable!)
Rainbow EreaDrone 2023 - New sim! Eloujah 2 824 24-May-2024, 01:38 PM
Last Post: Eloujah
  Fpv sim - alternative to liftoff for low power machine Rosssiiii 10 1,931 29-Apr-2023, 02:10 AM
  Having success in a sim Rob Axel 3 630 29-Apr-2023, 12:45 AM
Last Post: segler999
  Making a specific model on your tx for sim use? ph2t 3 594 23-Jul-2022, 05:50 AM
Last Post: Bad Raven
  AI Drone Simulator - new sim JinxFPV 21 4,299 19-May-2022, 02:47 AM
Last Post: fpvsquirrel
