ZMR250 build spinning uncontrollably
(13-Apr-2016, 06:04 AM)kandelin16 Wrote: Well crap. You're right.
Sorry guys! Please excuse my ignorance. I'll let you know how things go after I re-solder everything.
And thank you very much to everybody!
lol, i had this on one of my quad  once , it took me awhile to figure it out   Wink .   it's when things go wrong you start to learn , good luck bud .
(13-Apr-2016, 08:41 PM)Trollhammered Wrote: It's probably to late to say but you can change the motor direction in BLHeli suite
Really? I never looked! now I feel ignorant! Going to do this next time instead of switching leads!
I am a developing Racer - getting better.....
BNF Quads: <250 Eachine>; <250 Walkera Advanced CC3D>; <250 Vortex Pro>
Built: Dronz Fury 252 RX ; Speed Addict 210-R
Building: <Deciding on Third build - Suggestions?>
That is IF he is using blheli.
That happened to me once when I flashed my 9x from stock to openTX. My issue was that I had mapped the wrong channels on the tx an yaw had a constant input from a switch.
#19
Can we assume that you have also calibrated your ESCs?
When you calibrate your ESCs, and in CleanFlight through the motors tab, if you control each motor individually, do they all "sound" the same when you rev. them up? I've had ESCs that calibrate, but don't spin to the same speed as the others. That caused an issue for me similar to yours. Once I changed out the ESC it ran fine.
Don't know what others see, I see about a 25% failure rate of new ESCs. BUT, I've only used DYS SN20A ESC so far (~16). I really like them other than the failure rate. I should note that some of the 25% I have managed to repair. Most times just touching up the solder connections takes care of the issue.
#20
So my ZMR has spent the last couple months as a autonomous hovercraft for an engineering class. Now that im done Im ready to start working on this again! can this be done for simonk escs as well?
  Who wants to help me to build my first FPV? Several questions and concerns about how phelipems 3 95 13-Apr-2024, 12:09 AM
  BFC REORDER MOTORS NOT SPINNING soky157 4 92 08-Apr-2024, 05:38 AM
  First Build - prevent antenna chop? JohnnyCornRocket 5 197 28-Mar-2024, 02:16 PM
  Best Battery Option for Build - Begginer Arkadius27 7 221 19-Mar-2024, 04:40 PM
Sad What to check for short in a build? Yesnok 1 143 03-Mar-2024, 12:06 PM
