ZMR quick change setup
[Image: iVj1qcUl.jpg][Image: 2gQgBCql.jpg]Just wanted to see what you guys thought of a quick change setup for quads. This is for the Zmr but really it could be done with any quad. The lumenier pdb is a good idea to eliminate soldering so I wonder what some of you with Zmr's think of something like this. It has terminals posts for the motor power wires so you just slide the bare wire in and screw the grub screw down to tighten. The ESC signal wires have the balance plugs m/f (jst-xh) to connect the signal, ground and bec 5v if necessary. We saw in Dubai the pit stop element coming into play with big fpv events. With this setup if you blow a motor or esc you can swap out within seconds. I tried it by having a spare arm with motor and ESC already mounted to see how quick you could change it out with this setup. Let me know what you guys think.
Edit: won't let me load the pics, there too big so I will update shortly. Its the zmr integrated pdb modified for the quick change.
If it isn't broke, fix it anyways!
friendly reminder: upload large images using IMGUR tool on the left hand side of the ediotr under the smilies Smile
(18-Mar-2016, 11:32 PM)Oscar Wrote: friendly reminder: upload large images using IMGUR tool on the right hand side of the ediotr under the smilies Smile
Is is not on the left hand side Huh
lol FPV
Ragg-e WBX 5"
BUILD
MY CHANNEL
(19-Mar-2016, 12:29 AM)lolFPV Wrote: Is is not on the left hand side Huh
your right! Smile
(19-Mar-2016, 12:42 AM)Oscar Wrote: your right! Smile
As Chopper Reid would say "The other F*&ing Left"
  Announcement FAA Making CBO's Change Their Rules SnowLeopardFPV 2 478 24-Mar-2023, 02:05 PM
  Frame FPVModel ZMR-X210 mm Quadcopter Frame: Review, Timelapse Build & Suggested Components Michael Grabner 1 1,365 19-Apr-2016, 10:55 AM
Last Post: BigglesFPV
  PDB Lumenier 4Power Quick Swap PDB CurryCat 3 2,029 17-Mar-2016, 02:51 AM
Last Post: MacFly90
  Frame ZMR 180 - The lil' whiner NorbertT 0 1,667 15-Jan-2016, 08:55 PM
Last Post: NorbertT
