"Minimalist 112" build log
Hi all,
here i'll include the steps taken to build smallest brushless i've used so far...
it doesn't mean it is smallest ... it is jus smallest i've builded
challanges i see so far... patience to wait for the parts, small amout of space (so it needs to be a tidy build)
so far i've received motor (racerstar BR1103 @ 10000 kv) -daaaaaamn they are tiny - micro sd for scale...
https://drive.google.com/file/d/0ByAqK1b...sp=sharing
pico fc from banggood
Frame is ordered from aramantan (cant remember how it is called)
so... let's start:
first Frame from http://armattanproductions.com/ named Minimalist 112 - i like it for it's simplicity... unfortunately frame came with wrong top plate... awaiting for replacement...
will it stop me from building it ? hell no Smile
step one. wash the carbon parts, dry them and using third hand stabilization cover edges with CA (to strengthen the structure of carbon and make delamination harder).
[Image: y3meHQbkzIlUT_a9BeQ8CeFfNndJpfVF5kdABY8I...pmode=none]
as the frame is drying... let's work on the esc and remove excess of wrapping material
[Image: y3mQWD1HEpvdG9qLUZ9Kzvx3KigrZLe-DBEW6uEY...pmode=none]
next step is to check the replacement for typical standoffs - long screws
[Image: y3mMHSqrSgBxEn_sB8uAHQIIaAILWqiwhKAVBJdZ...pmode=none]
lets connect the motors to esc, replace original cables with battery plug, and add additional cables to power the fc...
first Poop moment when you can't place nuts lower as the electronics components are in the way... this esc could have been designed better Smile :
[Image: y3mrIIf0PAfhnUSSXK5gEwbXPIQ0_vpcwKTMWuNP...pmode=none]
LETS GO FOR THE HYPE OF SOFT MOUNTING!
[Image: y3mPQrujpY7bKe-C3I8CYrMpKRTjzd6HE07GeUbZ...pmode=none]
or after checking the screws provided with motor ... i will test the hype next time... softmount removed...
motors mounted:
[Image: y3mmdDapMsQRXJVClorgMUxZmYK6miQBBPVp83eN...pmode=none]
let me add low importance components like FC and RX... Kudos to Konrad for improving the "aluminium way" to filter the rx with electrostatic bag + heatshrink
[Image: y3mr0NNS8OTINpc1t0cJKoFGqwKr-aKDETbDQIPs...pmode=none]
ok so i'm missing top plate... lets find something that "should" fit and adapt it... oooh a NOX camera mount... a bit of filing and...
[Image: y3mpVj-GJpsGRQZUaRsIXecVZcALZgISMDieWimX...pmode=none]
i know... not perfect ... but it works for now ... other angle...
[Image: y3mtAaBx4kptLetGROr5VP2A9H1mMfjjgAIVu-oS...pmode=none]
i had to buy a scale for this shot Tongue
[Image: y3mNVd2ABKV3H7NX9obA7ZMEZ4BT5myIhf2I_Ajc...pmode=none]
so far this is my cleanest built... what i really like ist the esc that looks like "nothing is soldered to it"
awaiting slowboat to deliver 2 AIO cameras to test which will be a better fit... more to come...
All the best
Grzesiek (Grisha/ Greg)
thinking about building: 450
[-] The following 4 users Like Grisha0's post:
  • E.L.K., oyvinla, Tom BD Bad, tozes
I have built a similar quad... ok the same, but different ;p
I won't go into details, I'll just say, this must be the cleanest build so far... mostly because it has small amount of parts ;p I tried to use standard standoffs, but components on the FC are placed in a way that they prevented me from screwing them in the first place - I presume it's because of tiny differences in SMD placing that made Grisha use standard M3 nuts. I used standoffs provided with the frame - they are a bit thinner... but very tall instead.
When I had to think about the missing top plate, I immediately thought about thin plexiglass that I have laying around. So I got into drilling and hand-made "CNCing" using a dremel and vice.
Grisha asked me to "add a photo" Tongue  :
Smallest brushless motors ever!
[Image: y3mbnOT0rbl4armwd5vMQVzkudFF64x-9LTupNxL...pmode=none]
[Image: y3mqIT_ZVhSk6K8ilPteW6x_bvfMNDY6RuSyW_7X...pmode=none]
[Image: y3mGwln5dYbYWFo1tuiTSXE68xt-ALL2NlI0ZpM2...pmode=none]
A shot of wired FC:
[Image: y3mcuwtBX_893SG2aOcdKbznnN7RiyD0A1kCZbpQ...pmode=none]
And another with a regular motor for scale ;p
[Image: y3mEL2pS_hkhOYV4F1bVu_wXKCP_-bFW3wFbeWkw...pmode=none]
Plexi top plate:
[Image: y3mFOEZm4rzNft2wwsK05XgejgjkLtg3iXp7Zei2...pmode=none]
[Image: y3msTFMx_iVb6RTOlQXNqnT2Tlv9rruei4Jw7sGK...pmode=none]
Covered the edges of plexi with a hot glue bumper. Shiny:
[Image: y3m5Iox3ZP2LQzO5FXyLvfr2gUJBPJihg28xINIg...pmode=none]
Ohh! I forgot the scale 47.44g dry weight, 72.31g AUW ;p
[Image: y3m6fmp4fAyCyeyLrBvzzuS2SIB37ie60iOnPeT_...pmode=none]  [Image: y3m5tmfG943t_YWe6rchhgo1vsF7e7cx4EKLf6Yz...pmode=none]
Sorry, I forgot one prop, they weight almost nothing Wink
[-] The following 2 users Like KonradS's post:
  • Tom BD Bad, sloscotty
Heres my 112, great fun!
(14-Mar-2017, 10:38 AM)ZERONEST Wrote: Heres my 112, great fun!
Great little champ! 4s? What kv are those tornados?
Using those motors on my RS-90 - they're pretty impressive for their size!
Lovely build - are they the 66mm props BTW?
Grisha0 uses 3035, my pinky ones are 65mm racerstars (they break instantly). I am also using racerstar 2035, nice light prop for a quadblade, those motors handle them perfectly but with a little less punch. They are very delicate though, so best used with any kind of prop guards. I believe they would fit into your rs90 since it is designed for hubsan prop?
  • jimbo_wa
Poop
now i want to transform the little devil to 4s Smile
well 2x2s and i have 4s right Smile
now... i need to find 4in1 esc for 20-30a withing 20x20 mm block Smile
for the record i've burned my 6A esc... too heavy props and too much snow melting on the esc at the same time ... not smart
All the best
(15-Mar-2017, 12:44 AM)Grisha0 Wrote: now... i need to find 4in1 esc for 20-30a withing 20x20 mm block Smile
Like this?   http://www.banggood.com/Micro-20x20mm-20...33222.html
[Image: O010DKvl.png]
  • Grisha0
scotty, no idea how i missed it... pending restock and ordering... with 20 i shouldn't burn it on day one Smile
All the best
(14-Mar-2017, 05:34 PM)KonradS Wrote: Great little champ! 4s? What kv are those tornados?
yeah 850mah 4s! they are 3600kv bud
(15-Mar-2017, 01:12 AM)sloscotty Wrote: Like this?   http://www.banggood.com/Micro-20x20mm-20...33222.html
Been interested in this! just unsure how reliable a 20a 4in1 which is so small will be  Huh
ill tell you once it will be restocked Tongue
All the best
  AOS 3" Toothpick build SeismicCWave 21 273 11 hours ago
Last Post: SeismicCWave
  Build Meteor75 Build (Revision 4) :) Pathfinder075 9 583 14-Apr-2024, 03:28 AM
  3" 2S 1108 Build Pathfinder075 11 418 14-Apr-2024, 02:08 AM
  Build Armattan Tadpole 3" 2-3S Build brettbrandon 57 3,139 07-Apr-2024, 04:59 PM
  First FPV build. 3.5" help Pums 4 177 04-Apr-2024, 03:23 PM
