Threads: 125
Likes Given: 99
388 You need to turn on telemetry in the configuration tab or run the following CLI commands
feature TELEMETRY
Save
Threads: 125
Likes Given: 99
388 I am assuming that you are using a harness between the ESC and the FC. And that you have the pigtail of the lipo going to the ESC. If this is not true, then you need to tell me how you have it setup.
If true, then there could be a few issue. First issue, the ESC is not sending current draw data through ESC sensor. If that is the case, you need to change current source to "onboard ADC".
As for the voltage, that is really weird. Can you confirm that the voltage on your lipo is different than 11.3V? That means check your lipo voltage with a DMM or battery checker.
Threads: 125
Likes Given: 99
388 That is weird. Have you tried updating the ESC firmware?
Threads: 5
Likes Received: 0 in 0 posts
0 I just tried down and upgrading my firmware and still have the same problem and nothing changed
im starting to think its a hardware problem and if so i might buy an external voltage and current sensor
Threads: 125
Likes Given: 99
388 If the voltage ADC is not working, even an external voltage will not work. I don't see where you can connect the external voltage sensor to the FC.
Threads: 5
0 I thougt of souldering the sensor to the corrisponding tabs of the wiringharnas but if us say that it wont work i have no idea what to do.
So it must be a hardware problem i guess?
Threads: 125
Likes Given: 99
388 With troubleshooting and ruling things out, it is hard to say what the source of the problem is.
Threads: 125
Likes Given: 99
388 Have you tried changing voltage to ADC?
Threads: 5
0 Yes if i change to ADC I get a reading of 0 volts and 0 amps
Threads: 125
Likes Given: 99
388 So after your post, two other members here are having issue with Tmotor ESC and telemetry. If I were you, I would see if I can get a refund for the esc.
Threads: 5
0 So i should i get an other t-motor esc or one of an other brand
Threads: 125
Likes Given: 99
388 I would probably get another brand.
