Threads: 1
Likes Received: 0 in 0 posts
Likes Given: 0
0 Hi everyone
I'm in the process og building my first quad and it is so exciting! However, the more I research the more I'm getting confused about how to wire up the components mentioned in the title.
Do I connect the camera and the Unify Pro directly to each other?
What do I solder to the PDB and where? Do I solder some things directly to the flight controller or do everything go to the PDB?
I hope you can clear up a bit of the confusion for me.
Thanks!
Threads: 30
Likes Given: 714
45 Hi and welcome yo the forum! Not many of us here use a KISS system but we'll definitely be able to help with your basic wiring. Firstly, could you please paste a link to the exact flight controller and pdb you are using. From the quick bit of research I did, it looks like the KISS FC is an AIO and you may not need a pdb
Dude, where's my quad?
Threads: 125
Likes Given: 99
388 Kiss doesn't have built-in OSD. So you will have to buy a separate OSD. The diagram is pretty self explanatory. What issue are you having?
Threads: 1
Likes Given: 0
0 Hi voodoo614
Thanks for your reply. The PDB has the osd capability. I am unsure of the wiring of the mentioned components. I have no diagram of the wiring of those components and as it is my first quad I could use some directions on how the components should be interconnected. Especially FC, PDB, VTX and camera.
Threads: 125
Likes Given: 99
388 Oh, I see.
So you wire the camera signal to video on pdb. Then the VTX signal to video out on pdb. You will power the VTX and camera with appropriate voltage supply.
Threads: 1
Likes Given: 0
0 Fantastic! I'll get right to it, then.
Thank you for your help!
