Threads: 3
Likes Received: 0 in 0 posts
Likes Given: 1
0 Hi
I've a DarwinFPV BabyApe PRO, i've some problem with this drone.
does anyone have the same model for share CLI configuration and firmware?
i've a lot of problem with motors, I would like to try a working setup to rule out any software issues
Thanks and have a nice day
Threads: 76
Likes Received: 1,393 in 1,044 posts
Likes Given: 815
41 This one?
https://darwinfpv.com/products/darwin-baby-ape-pro-v2 Firmware is in the FAQ on that page.
Can't help on the dump and diff, but you could start with the default config, bind a receiver to the quad, add arm to a switch for basic testing in LoS. To get the VTX to work you need the VTX table. It doesn't appear to be on the VTX page.
I think a few people have one, so you will probably get a CLI dump without too much issue.
Try Not, Do or Do Not
- Yoda
Threads: 76
Likes Given: 815
41 I'd change brands. If they won't offer a refund, then why would you use them again. At the same time, you need to test everything, so test the motors on a different esc. Things go wrong on quads and you have to be very good at troubleshooting problems. It's just part of the hobby. Everything in this hobby is beta level. Nothing is stable. Problems happen and you run the checklist and if you are lucky you get it working.
- Yoda
