11-Mar-2017, 12:39 AM
Anyone knows if the old runcam swift will fit in a swift 2 case?
Will the runcam swift PCB fit in a swift 2 case? |
11-Mar-2017, 12:39 AM Anyone knows if the old runcam swift will fit in a swift 2 case? 16-Apr-2017, 01:07 AM I'm sure you've figured this out already but yes, it should. I dont believe you can go the other direction without trimming the connector notch to account for the larger plug. 16-Apr-2017, 08:01 AM (16-Apr-2017, 01:07 AM)Khutchinson22 Wrote: I'm sure you've figured this out already but yes, it should. I dont believe you can go the other direction without trimming the connector notch to account for the larger plug. Thanks, You are right, I did and it worked fine. The only "issue" was that my old swift had a bottom mount connector and I had to use the old back plate. It doesn't fit unless I trimmed a small piece of it close to the connector. |
Runcam Mini DVR - Remote Trigger Wiring Question | Pathfinder075 | 4 | 1,070 | 24-Aug-2022, 04:37 PM Last Post: Pathfinder075 | |
Help Runcam Hybrid 2 weird issue | PeladoMat | 2 | 679 | 15-Mar-2022, 01:02 AM Last Post: kafie1980 | |
Data Stand Off Height to Fit the Runcam Hybrid 2 | Black Eagle | 2 | 371 | 30-Nov-2021, 10:20 PM Last Post: Rob Axel | |
Vtx and dvr with runcam Phoenix 2? | stoogecurly | 4 | 1,087 | 29-Jun-2021, 05:08 AM Last Post: stoogecurly | |
Runcam Split 3 on Softserial RX / TX | Kadirjabbar | 7 | 1,937 | 10-Feb-2021, 10:02 AM Last Post: SnowLeopardFPV |
