Threads: 12
Likes Received: 3 in 2 posts
Likes Given: 46
0 I want to build a 3 Inch Freestyle Quad. Its all up weight is going to be, depending on the Motors, about 200g.
Now i am wondering which motorsize I should use, cause all I have read was eather 1404s or way bigger like 1408s or 1507... For the props i would use, also depending on the Motors, maby HQ 3,2,3 or HQ 3,3,3. Designwise i would like to use the 3,2,3s.
Can you guys give your oppinions and expieriences.
Thanks
Threads: 29
Likes Received: 405 in 305 posts
Likes Given: 323
18 06-Oct-2023, 03:02 PM (This post was last modified: 06-Oct-2023, 03:03 PM by Suros.) At that weight, grab the 1404s. They're basically perfect for it. Only reason to get bigger ones is if you're trying to drive some insanely aggressive props. Honestly wishing I had gone a bit smaller on mine (1407 currently), but I'm converting it to 4" soon so it evens out.
Threads: 118
Likes Given: 126
20 My Betafpv twigxl has 1404s I think .. and it is a ripper on 4s.. been flying it with 3.5” props.. crazy fast..
Threads: 75
Likes Given: 3,949
121 I’m a big fan of high kv 1408, 1506, or 1507 combined with 3x5x3 props.
But since it sounds like you plan on using lower pitch props, the 1404’s will suit you just fine.
Dangerous operations.
