Whats up with my current amp draw reading?
Hey, what does the current amp draw reading in my OSD lower left keep jumping all over the place even when just cruising at mostly constant throttle? This on a 7 inch and it flies fine except that I think the efficiency isn't great. I'm using xing 2806.5 1300kv and Geprc BLHeli32 50A ESC from my Mark5 BNF with a SpeedyBee F7 FC.
https://www.youtube.com/watch?v=8iX8ER07yHE&ab_channel=MajorKook
I had something similar happen the other day, turns out there was a small bit of moisture somewhere on the board. After blowing it off and letting it sit for 20 minutes it was back to its old self.
This isn't actually a new thing. I checked some of my old DVR recordings and its also there.
  ESC current sizing rule of thumb? B4tn 16 738 19-Jun-2023, 04:12 AM
Last Post: B4tn
  Help Current Meter Problem with T-Motor F7 Mini Stack ÄndyRändy 25 6,309 30-Jan-2022, 05:17 PM
Last Post: repli
  Why 63.5A Limit on ADC current reading (Amperemeter Apere Meter) jasc 8 1,094 22-Sep-2021, 11:30 AM
  Unknown Motor Current Draw 2550Kv 2207 motor Kadirjabbar 9 1,016 03-Jul-2021, 10:45 PM
Last Post: voodoo614
  Is there a way to calculate a motor's amp draw? Ryskream 1 829 10-May-2021, 11:48 PM
Last Post: bffigjam
