02-Oct-2023, 01:21 PM
Hi, Friends!
I'm using a copter with Speedybee F405 v3 FC board stack.
I'd like to use some of the FC controller pins as PINIO pins but have certain problems. For example when I use LED_STRIP pin Is working properly but if I use SERIAL#6 TX/RX pins there are problems that I cannot explain -- lack of power or signal interruption or anything else. When I use LED#1 and LED_STRIP then the signal on the LED#1 is changes synchronously to the LED_STRIP pin:
Can anybody give any recommendation which MCU pins are the best as PINIO and how the FC board pins are mapped to MCU pins? Is there any document that lists MCU/board pin mapping?
I would be glad to hear the expert opinions.
Thanks!
C03: PINIO 1
C04: GYRO_EXTI
C05: BEEPER
C06: FREE
C07: FREE
C08: PINIO 4
C09: PINIO 3
# get pinio
pinio_config = 129,1,1,1
Array length: 4
pinio_box = 0,255,41,40
Array length: 4
Default value: 0,255,255,255
Thanks!
