Threads: 172
Likes Given: 4,718
100 give it a short try outside with props on.
while it doesnt sound like it should, testing without rotors doesnt give usable informations.
Threads: 1
Likes Received: 0 in 0 posts
0 It functions fine still makes the noise though.
Threads: 10
Likes Received: 61 in 50 posts
Likes Given: 18
2 Sounds more like a loose magnet or two.
Props off.
In the motors tab of betaflight, run each motor one at a time.
Is the sound across all of them?
Threads: 172
Likes Given: 4,718
100 tell us more about the build, maybe some pictures
is there a capacitator attached?
Threads: 5
Likes Received: 14 in 7 posts
Likes Given: 5
1 19-Jul-2023, 11:58 AM (This post was last modified: 19-Jul-2023, 12:18 PM by Jonosg.) It's generally a bad idea to run motors from the radio with the props off, use the motors tab in BF. The PID controller is expecting some resistance from props and strange things can happen when it doesn't get that. If it doesn't occur when flying with the props on nor when using the motors tab I wouldn't worry about it.
Have you tuned it yet? Pulling a few punch outs, flips, rolls and yaw spins with BF defaults somewhere reasonably safe and checking out the black box logs may give more useful info
Threads: 172
Likes Given: 4,718
100 what motors and esc do you use?
