30-Sep-2023, 09:26 PM
So I installed a Radiomaster RP1 on my Axis Manta 3.6 which is running a Argus Mini F7 stack and I'm running into quite the weird issue.
Wired everything up per the diagram on uart 2, double and triple checked the connections so I'm certain nothings mixed up.
The problem is that it seems that this RX seems to only receive inputs from the TX when powered via USB. Plugging in a lipo, the RX turns on, goes solid green as if its bound but get's absolutely no inputs from the TX
Swapping off of the lipo, and going via USB power, everything works as expected. Initially I thought maybe its a bad uart on the board, but heres the weird part. If I connect via USB power first, everything works as expected, from there I can plug in the battery and disconnect the usb and everything continues to work as expected.
Its only when powering initially from a Lipo that the RX doesn't seem to respond to any inputs, I'm sitting here kind of baffled at what it could be.
Everything is updated to 3.3.0, proper firmware, and at this point I feel like I've tried everything apart from swapping RX's.
