Threads: 18
Likes Received: 1 in 1 posts
0 Thank you so much snow Leopard FPV, I was able revert back to the old driver at first it was greyed out. Now the problem is setting up on velocidrone and to get started on there and start practicing flying
I’m not why it seem it is challenging on velocidrone
I was using DRL under the training mode but it got boring and the drone seem lighter and floating so I was discourage. I downloaded velocidrone on Saturday and still I haven’t started flying and know what I am doing. I would appreciate your help
Threads: 587
Likes Received: 8,962 in 6,632 posts
Likes Given: 1,425
787 The first thing you will need to do is to set up your transmitter in VelociDrone if you haven't already done that. The video below shows you the procedure for doing that...
If you get issues with the quad feeling floaty then you need to adjust your screen quality settings to get a higher frame rate. The higher the frame rate you can get, the more realistic things will start to feel. Maybe this is the issue you were having with DRL (i.e. low frame rate). The video below explains and demonstrates what each of the important video quality settings in VelociDrone do...
Threads: 18
0 Snow leopard I appreciate your help, I did watch the YouTube on rolling back to the previous driver. I was able to roll it back. I restarted the computer wouldn’t save and then I tried using the stick on velocidrone but it wouldn’t work. I am sure to do Ii thought about using the DRL I am bomb out using this program after purchasing it and it is still not working
I would like to learn how to fly and get better with it. I am fully invest in it. I am on the verge of building my first quad. I have a couple of tiny hawk. Just read to go and it seem like I am always running into Obstacle
Threads: 49
Likes Received: 192 in 157 posts
Likes Given: 186
11 Don't give up! You will get there with persistence. I've invested a lot in this since March and it can be really frustrating at times!!. You've come to the right place my friend. These people on here have all been through the same thing and really know their stuff! It will be worth the time. There's nothing like soaring with the birds and the wind crackling through your ear buds! I did find the simulators harder to fly than the actual drone. The way drones corner is not exactly like real life on a simulator. You cant "feel" the drone like you can when actually flying. Hang in there I think you will find its worth every hour in the long run! If your using Win 10 try going to settings-Bluetooth or other devices, and click on add device. If you can see it working on there you should be able to use it on the simulator. Not sure how your connecting to the computer with your radio though.
